Jrod696 28 Posted June 30, 2019 Posted June 30, 2019 (edited) I ran the FreeNAS plugin for quite a while but several months back I switched to a windows 10 machine as the server. Before on the plugin version the Library folder images would updated every once and a while to show 4 different random poster images from the library. In the windows version I can't seem to find anywhere to set that option back up. Currently I have on the front page a library with 4 posters on it that don't even have those movies in the library any longer. Is it possible to set that feature up or manually refresh the library image? Edited June 30, 2019 by Jrod696
Solution Luke 42221 Posted June 30, 2019 Solution Posted June 30, 2019 Hi there, it's resolved for the next release, but will require a one-time manual deletion of existing images. Thanks. 1
Jrod696 28 Posted June 30, 2019 Author Posted June 30, 2019 (edited) Hi there, it's resolved for the next release, but will require a one-time manual deletion of existing images. Thanks. Thanks for the quick response, I guess one quick question just to finish off the thread and ask the inevitable question, after the next release what are the steps to delete the existing images? Edited June 30, 2019 by Jrod696
Luke 42221 Posted June 30, 2019 Posted June 30, 2019 You can just use the image editor tools built into the emby web interface to manually delete them. Just select edit images from the 3-dot menu on a library. 1
