Seger 123 Posted June 29, 2019 Posted June 29, 2019 (edited) @@Angelblue05 @@Luke Hello friend, I have recently the problem that in my series the banners take a long time to load and then disappear eventually. There are many mistakes in the Kodi Log in this regard. Do you see what it could have done? Updated Emby for Kodi and Embuary to the latest version and did a full database scan today (ie with both new versions). Many Greetings, Seger kodi.log Log_EmbyServer.log Edited June 29, 2019 by Seger
Luke 42237 Posted June 29, 2019 Posted June 29, 2019 I'm not quite sure. The server log looks OK from here.
Angelblue05 4132 Posted June 29, 2019 Posted June 29, 2019 @@Luke What is the worst that could happen if for example, we call /Images/{Type}/0?.... if there's no index for that image type? Would that cause any issues?
Luke 42237 Posted June 29, 2019 Posted June 29, 2019 You mean if no image exists? You'd get a 404 not found error.
Angelblue05 4132 Posted June 29, 2019 Posted June 29, 2019 This here is not very clear The url required to download images will vary depending on what kind of item you're downloading for. For example, for users, the url's are /Users/{Id}/Images/{Type} and /Users/{Id}/Images/{Type}/{Index}. For media items, it's /Items/{Id}/Images/{Type}, as well as /Items/{Id}/Images/{Type}/{Index} This is what I use: /Items/{Id}/Images/{Type}/{Index} but I've just seen this /Items/{Id}/Images/{Type}. So I'm wondering if for example calling images/banner/0 would cause issues, because there's no index, the server only holds one of that image. Should I drop the index for everything except backdrops?
Luke 42237 Posted June 29, 2019 Posted June 29, 2019 No, that won't cause issues. That will be fine. 1
Angelblue05 4132 Posted June 29, 2019 Posted June 29, 2019 (edited) @@Seger I do see something odd with your banner urls, they contain multiple tag values. I'm not sure how that is possible. Maybe some lingering urls in the texture database. What I would try to do is probably delete the textures13.db and see if that resolves it. Edited June 29, 2019 by Angelblue05
Seger 123 Posted June 30, 2019 Author Posted June 30, 2019 (edited) @@Angelblue05 Hello, Good point, I had already thought of it yesterday. Had the textures13.db already pictorial in mind, but did not press delete. Do it later and see how it works. Maybe report me again. Thank you and have a nice sunday, you're both crazy about your job: @@Luke @@Angelblue05 Many Greetings, Seger Edited June 30, 2019 by Seger 1
