eraser8 55 Posted June 28, 2019 Posted June 28, 2019 Hi guys, Not a current big problem but during some testing, I saw a small bug with the ffmpeg management when I changed the movie quality. When we going down in Mbps, the current FFMPEg is killed and a new one is started. But when we going UP in quality, the current FFMpeg process is NOT killed and it start a new one. For example I have a movie with 5 mbps original video bandwidth. I firstly set it to 2 MBps, works great. After, I set it to 3 MBps and it does seems to works great but when I check my process, I have 2 FFMPEG process that working. I don't think I need to send the server log for that since it should be a simple fix. But if you need it, I could reproduce it easily and send you a clean log. Thanks 1
Luke 42239 Posted June 28, 2019 Posted June 28, 2019 Hi there, let's look at an example. Please see how to report a problem. thanks.
