Jacques 0 Posted June 26, 2019 Posted June 26, 2019 Hello, I have recently tried to restore Emby from a backup which was created by the backup and restore app. I have downloaded the latest version of Emby server for Windows and tried to restore from the plugin. I have it working so the plugin can see the restore point I want and I can see it can read the correct settings. When I click restore nothing happens at all. It just closes the point in which it says are you VERY sure? and I click okay or yes and nothing happens apart from closes that screen. Anybody else had this issue and is there a fix?
Happy2Play 9806 Posted June 26, 2019 Posted June 26, 2019 Can you post the server log corresponding with this action.
Luke 42221 Posted June 26, 2019 Posted June 26, 2019 It should restart the server at that point, other than that there isn't much that will actually happen other than things being restored.
Jacques 0 Posted June 26, 2019 Author Posted June 26, 2019 Hi Luke, Thanks for the reply. I have looked to see if Emby is restarting after I press restore and it isn't restarting. If I do a restart it doesn't restore any of the data.
PenkethBoy 2068 Posted June 26, 2019 Posted June 26, 2019 Are you expecting it to restore your library - because it wont - it restores user settings etc - not your database?
Jacques 0 Posted June 26, 2019 Author Posted June 26, 2019 No I'm well aware of that. I have a backup of my library. I just want it to restore my config of emby which it isn't doing. I am worried I am facing this issue https://emby.media/community/index.php?/topic/21787-how-do-i-restore-from-a-backup/
Happy2Play 9806 Posted June 26, 2019 Posted June 26, 2019 Can you post a server log. What browser are you using? Have you tried a different browser?
Jacques 0 Posted July 11, 2019 Author Posted July 11, 2019 Hi Luke. Yes I still can't restore a backup although I have just taken the shortcut from my old windows profile and I am using the original windows install now instead. Not ideal but it will do the job.
Luke 42221 Posted July 11, 2019 Posted July 11, 2019 @@Jacques Can you please provide an emby server log from a restore attempt? thanks.
