SonnyMN 1 Posted June 26, 2019 Posted June 26, 2019 Is this a supported device? The documentation does not specify and this is a network based tuner.
Luke 42239 Posted June 27, 2019 Posted June 27, 2019 Hi, does device run with the Hauppauge WinTV app, do you know?
Happy2Play 9811 Posted June 27, 2019 Posted June 27, 2019 Hi, does device run with the Hauppauge WinTV app, do you know? Looks like it.
BillOatman 597 Posted June 28, 2019 Posted June 28, 2019 Now if only Spectrum didn't absolutely SUCK about cablecards
SHSPVR 125 Posted June 29, 2019 Posted June 29, 2019 Just so all know the WinTV-DCR-3250 is same hardware as HDHomeRun Prime with cosmetic changes and no you can't used the HDHomeRun Prime firmware 1
Sammy 791 Posted August 16, 2019 Posted August 16, 2019 Now if only Spectrum didn't absolutely SUCK about cablecards How? I've used them for years now with CableCARDs.
SHSPVR 125 Posted August 16, 2019 Posted August 16, 2019 How? I've used them for years now with CableCARDs. Keep in mind Sammy just because it work for you it may not work for other in diff state or in a diff town just down road
Sammy 791 Posted August 16, 2019 Posted August 16, 2019 Keep in mind Sammy just because it work for you it may not work for other in diff state or in a diff town just down road True dat! In the early days it was a PITA but nowadays it seems to be pretty darn good in my specific area.
