mattirawks 0 Posted June 25, 2019 Posted June 25, 2019 I cannnot connect remotely. Everything was working fine for years until it stopped. My 8096 port is open and is confirmed using canyouseeme.org If i try connecting to my remote address using smartphone browser i get 'This site can't be reached' .. . but on my Emby dashbooard it does recognise a connection 'successfully authenticated 25/06/2019, 17:26:34' i've tried resetting router after seeing some users say that worked for them....but nothing any help appreciated. Thanks
Luke 42221 Posted June 25, 2019 Posted June 25, 2019 Hi there, have you setup port forwarding in your router?
mattirawks 0 Posted June 25, 2019 Author Posted June 25, 2019 Hi there, have you setup port forwarding in your router? Yes port forwarding is setup. It all stopped working for seemingly no reason. I hadn't changed my setup or any settings, i've just been unable to connect for around 2 weeks.
Luke 42221 Posted June 25, 2019 Posted June 25, 2019 What about with the online web app at http://app.emby.media . Can you try that?
rbjtech 5338 Posted June 25, 2019 Posted June 25, 2019 Has your ISP moved to Carrier Grade NAT ? (https://en.wikipedia.org/wiki/Carrier-grade_NAT) - if they have, then call them and ask to be put back on a proper public IP - which will mean you can then host your Emby server ...
mattirawks 0 Posted June 26, 2019 Author Posted June 26, 2019 What about with the online web app at http://app.emby.media . Can you try that? Yes, this does not work either Has your ISP moved to Carrier Grade NAT ? (https://en.wikipedia.org/wiki/Carrier-grade_NAT) - if they have, then call them and ask to be put back on a proper public IP - which will mean you can then host your Emby server ... I've never heard of this but it could be a possibility as it stopped working out of the blue. Thanks i'll look into it.
Luke 42221 Posted June 28, 2019 Posted June 28, 2019 @@mattirawks were you able to find out the answer?
