Andrew0991 0 Posted June 24, 2019 Posted June 24, 2019 Hi, During installation Emby Theater on windows i found small typo. Language: Polish Now is: "[...]i innych urządzeni[...]" Should be: "[...]i innych urządzeń[...]" Best regards.
Luke 42242 Posted June 24, 2019 Posted June 24, 2019 Hi there, thanks for reporting! @@Beardyname or @@Sven, what do you think?
Luke 42242 Posted June 24, 2019 Posted June 24, 2019 @@Andrew0991, if you'd like to help translate you can actually update this on OneSky and then it will go into our next app update. Thanks !
Andrew0991 0 Posted June 25, 2019 Author Posted June 25, 2019 @@Luke Thanks for information. Translation updated on OneSky.
