Luke 42237 Posted June 2, 2014 Author Posted June 2, 2014 it doesn't look like the server wmc program was updated. either that or there's still a bug in it's return data.
Latchmor 584 Posted June 2, 2014 Posted June 2, 2014 Ok, no idea what happened on first test but it was defo MP4. Now I've tried 4 HD channels and all play fine and are using WebM. ServerWMC shows latest build of 1138. Just tried Android again while I'm here and I got chucked back to dashboard settings and transcode folder was filling up again. Reset Tuner and cleared them out. http://pastebin.com/Rd7fEi9C
krustyreturns 191 Posted June 3, 2014 Posted June 3, 2014 @@Latchmor, I'm not clear on whether you are using the experimental build of serverwmc that I made for you guys to test. It that's not what you are using let me know and I'll PM you the link. I
Luke 42237 Posted June 3, 2014 Author Posted June 3, 2014 thanks krusty. I'm also going to have the next dev build validate and strip out any data that will cause issues.
krustyreturns 191 Posted June 3, 2014 Posted June 3, 2014 @@Latchmor I put a new experimental build of swmc (1140) at that same link, it does a better job at getting the video stream bitrate than the older version. If you could try this sometime while you are working through stuff with Luke that would be great.
Latchmor 584 Posted June 3, 2014 Posted June 3, 2014 @@Latchmor, I'm not clear on whether you are using the experimental build of serverwmc that I made for you guys to test. It that's not what you are using let me know and I'll PM you the link. I Hi Krusty, I have a link (from an earlier PM) that now points to a build 1139. Let me know if this is the one and @@Luke can get me to test when he's ready. Cheers
krustyreturns 191 Posted June 3, 2014 Posted June 3, 2014 That's the right one (at least for now ). Luke if the passed parameters still have issues, besides fixing them on your end, let me know that they are on my end too. I would like to get this stuff resolved before the next real release.
Latchmor 584 Posted June 3, 2014 Posted June 3, 2014 Ok, I'll download, install and wait for my orders
Latchmor 584 Posted June 3, 2014 Posted June 3, 2014 Ok I'll give it a go tomorrow evening. Sleepy now! Cheers Sent from my Nexus 4 using Tapatalk
krustyreturns 191 Posted June 3, 2014 Posted June 3, 2014 ?? Really? You are getting zeros instead of null values? The bitrate is still zero for h264 streams? Maybe I make a mistake in the installer I uploaded.
Latchmor 584 Posted June 3, 2014 Posted June 3, 2014 Desktop, Chrome, Web Client: Working As above with Firefox: Working Android: Working When it transcodes for Android is it supposed to have loads of files? 1min 45secs of playback shows 90 files around 1mb each. Cheers
Latchmor 584 Posted June 3, 2014 Posted June 3, 2014 ?? Really? You are getting zeros instead of null values? The bitrate is still zero for h264 streams? Maybe I make a mistake in the installer I uploaded. He may have been talking to me! I.E. do the same tests as before 1
krustyreturns 191 Posted June 3, 2014 Posted June 3, 2014 lol. Okay, I await further instructions too.
Luke 42237 Posted June 3, 2014 Author Posted June 3, 2014 krusty you're fine. and latchmor, good, thanks. yes those little files are what android wants.
Luke 42237 Posted June 3, 2014 Author Posted June 3, 2014 i need the log though because the purposes of this wasn't to test working/not working.
Latchmor 584 Posted June 3, 2014 Posted June 3, 2014 Just added IE to the list Desktop, Chrome, Web Client: WorkingAs above with Firefox: Working As above with IE11: WorkingAndroid: Working
Latchmor 584 Posted June 3, 2014 Posted June 3, 2014 Hi @@Luke, did another Firefox test with Krusty's 1140 build mentioned above. It plays ok for a minute or 2 then stops, player window vanishes. Cheers http://pastebin.com/i8dBG8Zu
george 0 Posted October 23, 2014 Posted October 23, 2014 Hi Luke I can test it as well. Even I am located in Canada my TV server is in Europe I have 2 DVB-T tuners Let me know if you need something to test
