Guest Posted June 23, 2019 Posted June 23, 2019 Hi, Now that the external subtitles in strm have been corrected for the next version of EmbyServer, I bring a new problem. Is it possible to have files with two audios so that the user can choose which audio to play? This also strm file. Currently, files with two audios keep the video mute. Thank you
Luke 42221 Posted June 23, 2019 Posted June 23, 2019 Yes you'll be able to pick, but i think currently only on the second time playing, not the first time.
drikosv8 25 Posted June 23, 2019 Posted June 23, 2019 Yes you'll be able to pick, but i think currently only on the second time playing, not the first time. @@Luke I converted the file to mp4 and put the two audios aac, and the result was as follows: audio 1 plays normal, audio 2 does not change, maintains audio 1 If I allow transcoding, everything goes well with the two audio tracks, more like transcoding the CPU usage, I would like direct playback.
drikosv8 25 Posted June 24, 2019 Posted June 24, 2019 Well you have to make a choice, sorry. In addition, the file follows the pattern in the Emby Direct Playback Wiki. If this is the only solution, unfortunately transcoding is not an option.
Luke 42221 Posted June 24, 2019 Posted June 24, 2019 The browsers don't support changing audio tracks, so once you select the secondary audio track, the only way it will work is with remuxing to change the attributes of the track. So that is why you have to make a choice. 1
drikosv8 25 Posted June 24, 2019 Posted June 24, 2019 (edited) Thanks for the explanation Luke. To solve this, I will put 2 versions of the same file with different languages, and at the time of the reproduction just choose the language. It will be possible in the series, when I choose version 2 of episode 1, when I automatically switch to the next episode 2 he keep version 2 of the next episode, because I will always put 2 versions in English and Portuguese, so if I put Portuguese in the first, keep for the other Portuguese episodes too, so the files will never transcode Edited June 24, 2019 by drikosv8
