BP_Tec 0 Posted June 23, 2019 Posted June 23, 2019 Hi all, So I'm having problems setting up my library on only one of my drives. I know this is probably a permissions issue, but I just cant figure out what the problem is. These are my media locations, the first two work fine, but the USER_DATA drive does not, and i get the error. All locations are accessible from my Linux machine. /home/alex/Videos /mnt/BACKUP_DRIVE/media /mnt/USER_DATA/media1 /home/user/Videos drwxr-xr-x 6 alex alex 4096 Jun 22 15:43 Videos /mnt/BACKUP_DRIVE/media drwxr-xr-x 2 root root 4096 Jun 23 12:23 media /mnt/USER_DATA/media1 drwxr-xr-x 2 root root 4096 Jun 23 12:23 media1 If i change the owner and group on media1 to alex, i still get the same issue chown alex:alex media1 drwxr-xr-x 2 alex alex 4096 Jun 23 12:23 media1 If I change it to emby:emby still exactly the same error. I also restated the emby service after each attempt. So any help at all in understanding what is happening here would be awesome. Kind regards
mastrmind11 722 Posted June 23, 2019 Posted June 23, 2019 are all 3 shared the same way? mounted the same way? network shares?
BP_Tec 0 Posted June 23, 2019 Author Posted June 23, 2019 Ah I think i discovered the issue... on the root of /mnt/USER_DATA there was no (group) and (all) permissions set. drwx------ 16 alex alex 4096 Jun 23 12:23 USER_DATA After trying different restrictive permissions, it looks like at the very minimum, the permissions need to be 755 /mnt/USER_DATA/media1 Could someone confirm that the emby account lies under the (all) group?
BP_Tec 0 Posted June 23, 2019 Author Posted June 23, 2019 Actually those permission needed to be applied to /mnt/USER_DATA
BP_Tec 0 Posted June 23, 2019 Author Posted June 23, 2019 (edited) What are the minimum permissions that the emby group requires for a library it to operate? It obviously needs read permission, but does it also need write and execute? I'm guessing write is only needed if it need to store metadata or thumbs... Edited June 23, 2019 by BP_Tec
Luke 42246 Posted June 23, 2019 Posted June 23, 2019 I'm guessing write is only needed if it need to store metadata or thumbs... Correct. If not, then read is enough. Please let us know if this helps. Thanks.
BP_Tec 0 Posted June 23, 2019 Author Posted June 23, 2019 (edited) When I remove the execute permission I cant play my files, so I guess it needs at a minimum, Read and Execute ? Edited June 23, 2019 by BP_Tec
Q-Droid 1011 Posted June 23, 2019 Posted June 23, 2019 (edited) The emby user needs access to every directory along the path to the final directory with the media files. This comes up often enough that it should be included in bold letters in a sticky. All directories need 'r' and 'x' in order for any user to access them. If you want emby to be able to create files in the directory then write permissions are also needed in the specific directory. This could be done with ownership or group access or everyone access. Edited June 23, 2019 by Q-Droid
