Angelblue05 4132 Posted July 8, 2019 Posted July 8, 2019 Simply disable force http in the addon settings > playback.
Angelblue05 4132 Posted July 8, 2019 Posted July 8, 2019 (edited) Your files are playing over http anyway because Kodi can’t locate your files. For direct play to work, Kodi has to be able to locate your files directly. In this case it has to be able to access \\Movies\ Edited July 9, 2019 by Angelblue05 1
Angelblue05 4132 Posted August 13, 2019 Posted August 13, 2019 (edited) The audio/subs selection with direct stream should be resolved with 4.1.13. Edited August 13, 2019 by Angelblue05 1
AntaresFR 9 Posted August 14, 2019 Author Posted August 14, 2019 Oh nice, i'll try this after coming back home in 3 days. Thank you
AntaresFR 9 Posted September 13, 2019 Author Posted September 13, 2019 (edited) I tried a couple of seconds ago. Same as before. I ask to play audio index 1, 2 , 3 etc.... or whatever else without result. It always plays the "default" language and default subtitle without taking into account the request i made. I have 4.1.14. Edited September 13, 2019 by AntaresFR
