kauzi 2 Posted June 17, 2019 Posted June 17, 2019 Hi Emby-community, I'm new to Emby and using it for 2 month now. I like Emby very much and most things are working nice. But there is one thing I would ike to optimize: I have tons of movies recorded in transport stream fomat (*.ts) from TV using DVB viewer. The naming scheme of these ts files is as follows (example): 2018-02-04_00-13-44_zdf_neo HD_Pitch Black - Planet der Finsternis.ts I already have a basic nfo-file for each of that recordings, containing movie name and contents description from EPG. If Emby scans all these .ts files it mostly fails scraping (I guess 60% are not detected at all). Any ideas, why the scraper fails so often? Does the scraper take into account an exisiting nfo file when scraping a movie file? Is the naming scheme mentioned above inconvenient for the scraper to identify the correct title? Thanks already for clarification, Michael
pünktchen 1410 Posted June 17, 2019 Posted June 17, 2019 The nfo file has to be named the same way as the video file then you should at least get the description from your nfo files. Please attach some of your nfo files.
kauzi 2 Posted June 17, 2019 Author Posted June 17, 2019 Thanks for your fast reply. Yes, the nfo files are all named identical as the ts files (2018-02-04_00-13-44_zdf_neo HD_Pitch Black - Planet der Finsternis.nfo). File attachement does currently not work, so I paste in the content of the nfo: <?xml version="1.0" encoding="UTF-8" standalone="yes" ?> <movie> <title>Pitch Black - Planet der Finsternis </title> <plot>=USA 2000|Das Jahr 2676: Durch einen einschlagenden Meteoritenschauer wird das Notfallsystem des interstellaren Frachters "Hunter Gratzner" ausgelöst und die im Kälteschlaf reisende Besatzung geweckt.|Mit größter Mühe gelingt eine Notlandung auf einem wüstenhaften Planeten, die nur elf Passagiere, unter ihnen der berüchtigte Schwerverbrecher Riddick (Vin Diesel), überleben. Durch den Aufprall schafft es Riddick, sich zu befreien, und ihm gelingt die Flucht.|Darsteller:|Fry - Radha Mitchell|William J. Johns - Cole Hauser|Richard B. Riddick - Vin Diesel|Imam - Keith David|Paris - Lewis Fitz-Gerald|Shazza - Claudia Black|Regie: David Twohy|HD-Produktion|Altersfreigabe: 16|[16:9] [H.264] [HD]|[stereo] [deu]|[stereo] [mul]|[stereo] [mis]|[Dolby Digital 5.1] [deu]|PDC: 04.02. 00:05 (135173) </plot> <runtime>01:40:00 </runtime> <tag></tag> <aired>04.02.2018 00:13:44 </aired> <status>zdf_neo HD </status> </movie> Best, Michael
pünktchen 1410 Posted June 17, 2019 Posted June 17, 2019 I think the problem is your nfo doesn't contain a imdb or tmdb provider id. Emby first reads from your nfo and after that tries to download missing informations from online providers. But this will fail because of your unsupported file naming convention: https://github.com/MediaBrowser/Wiki/wiki/Movie-naming Either put ids to your nfo files, change your file names or just disable the online metadata providers. 1
kauzi 2 Posted June 17, 2019 Author Posted June 17, 2019 Thanks for your answer. I will try to add provider ids. I will report back.
pünktchen 1410 Posted June 17, 2019 Posted June 17, 2019 You have to use the Kodi 16 nfo format for provider ids, Emby doesn't understand "unique id..." yet.
kauzi 2 Posted June 18, 2019 Author Posted June 18, 2019 OK, I just realized that I have to set the correct IMDB ID for each movie. I thought I can set a placeholder ID and Emby will correct that. So adding the correct IDs to the nfo is too much work. I will try to rename the files to get a better scraping result. I will report back. Thanks, Michael 1
Luke 42221 Posted June 18, 2019 Posted June 18, 2019 What is a place holder ID? You don't have to set an Imdb Id, you can just have it be blank. 1
kauzi 2 Posted June 24, 2019 Author Posted June 24, 2019 On the weekend I had time to play around with the NFO files, but at the end modifying the NFOs is a lot of work. So finally I decided to simply rename all my recordings uisng small Python script. Scaping woked fine after that. I also reconfigured my recording server to use a different file naming scheme from now on. Thanks again for your help!
