borngborn 0 Posted June 16, 2019 Posted June 16, 2019 (edited) The Anime Plugin does not work correctly at all. It barely grabs any metadata from anidb and the rest of the like anilist and MAL it will never find or match anything just a blank colored box any help please im on linux latest emby version the shows that it have the metadata in last screenshot i hada do myself with tvdb which i hate using for anime Uploaded screenshot and log log Edited June 16, 2019 by borngborn
Luke 42255 Posted June 16, 2019 Posted June 16, 2019 Hi there, please see how to report a problem. thanks.
Luke 42255 Posted June 26, 2019 Posted June 26, 2019 hi @@borngborn thanks for reporting. These issues are resolved for the next update to the anime plugin. Thanks !
szalkerous 1 Posted November 26, 2019 Posted November 26, 2019 I too have had this issue with the anime plugins. I have found for a few years I have to manually push the metadata for every series. It won't even recognize extremely well-known series like Trigun, Samurai Champloo, or Cowboy Bebop. I've made sure the filenames and folder structures are "standardized" and still no luck.I still haven't figured out how to categorize my Anime folder, since it has both TV and Movies, is there one better than the other?
Luke 42255 Posted November 28, 2019 Posted November 28, 2019 I too have had this issue with the anime plugins. I have found for a few years I have to manually push the metadata for every series. It won't even recognize extremely well-known series like Trigun, Samurai Champloo, or Cowboy Bebop. I've made sure the filenames and folder structures are "standardized" and still no luck. I still haven't figured out how to categorize my Anime folder, since it has both TV and Movies, is there one better than the other? hi there, can you please go over examples of how you've organized? Thanks.
