chef 3811 Posted January 22, 2020 Posted January 22, 2020 (edited) I've never really properly looked at the end time, but as far as I remember, once you stop a movie and then restart it, the end time is still calculated from the original length of the movie so I don't think that will be consistent.There seems to be runtime in the baseItem object. So calculating runtime ticks minus position ticks, in the progress event, minus whatever the user says is the moment to target, would most likely give us the answer, but we'd be doing that on progress events, and that's where I'm not sure if it's worth the cost. Dunno. Was it taxing before Bill? Edited January 22, 2020 by chef
BillOatman 597 Posted January 22, 2020 Author Posted January 22, 2020 (edited) There seems to be runtime in the baseItem object. So calculating position ticks, in the progress event, minus the runtime ticks, minus whatever the user says is the moment to target, would most likely give us the answer, but we'd be doing that on progress events, and that's where I'm not sure if it's worth the cost. Dunno. Was it taxing before Bill? It didn't seem to be. But I have a decent server box and never more than 3 clients connected at once. Plus we are already processing the progress event anyway for other things. It should be made optional like the others in case it is taxing for some servers. The only real problem I saw was the very rare case where a movie etc. had no, or extraordinarily short, end credits. In that case the lights start to ramp up while the movie etc. is still playing. Another reason to make it optional Edited January 22, 2020 by BillOatman
chef 3811 Posted January 22, 2020 Posted January 22, 2020 It didn't seem to be. But I have a decent server box and never more than 3 clients connected at once. Plus we are already processing the progress event anyway for other things. It should be made optional like the others in case it is taxing for some servers. The only real problem I saw was the very rare case where a movie etc. had no, or extraordinarily short, end credits. In that case the lights start to ramp up while the movie etc. is still playing. Another reason to make it optional Then consider it done! 1
pir8radio 1313 Posted January 23, 2020 Posted January 23, 2020 unrelated, where have i seen the ability to set the ramp rate of a scene? I dont remember... lol but i recall seeing it somewhere... How can I set my stop scene to ramp up slowly.
hstamas 179 Posted January 23, 2020 Posted January 23, 2020 (edited) unrelated, where have i seen the ability to set the ramp rate of a scene? I dont remember... lol but i recall seeing it somewhere... How can I set my stop scene to ramp up slowly. You need to set that up in a 3rd part Hue app. Strangely, the official apps don’t support it. Bill recommends the app for Windows called Huetro. Works really well: https://www.microsoft.com/en-us/p/huetro-for-hue/9wzdncrfjj3t?activetab=pivot:overviewtab Edited January 23, 2020 by hstamas 1
pir8radio 1313 Posted January 23, 2020 Posted January 23, 2020 (edited) @@chef can a transition time feature be added to the plugin some how? to "modify" the scene via the plugin? Note that you can also create scenes with a transition time which will be used when the scene is recalled. e.g. {"name":"Romantic dinner", "lights":["1","2"], "recycle":true, "transitiontime":50} Edited January 23, 2020 by pir8radio
chef 3811 Posted January 23, 2020 Posted January 23, 2020 (edited) <p> @@chef can a transition time feature be added to the plugin some how? to "modify" the scene via the plugin? Note that you can also create scenes with a transition time which will be used when the scene is recalled. e.g. {"name":"Romantic dinner", "lights":["1","2"], "recycle":true, "transitiontime":50} Let me see about that. You would just want a transition time added to the scene call if that is possible? Modifying scenes in hue gets kinda tough because you have to get a bunch of states and IDs for each device to reset the scene with new info. It gets pretty in-depth. Edited January 23, 2020 by chef
pir8radio 1313 Posted January 23, 2020 Posted January 23, 2020 Let me see about that. You would just want a transition time added to the scene call if that is possible? Modifying scenes in hue gets kinda tough because you have to get a bunch of states and IDs for each device to reset the scene with new info. It gets pretty in-depth. Yea i looked through the api, didnt see where you could add the transition during recall. It looks like you need to "modify" the scene as stored in the hue. So if that is true, maybe just an option below each scene selection that says "Ramp Rate" or "Transition Time" in seconds and a save button that edits that scene via the plugin?
pir8radio 1313 Posted January 23, 2020 Posted January 23, 2020 oh i see what you are saying, you basically have to rewrite the whole scene? you cant just say scene name, transition x. You have to re-input all of the lights and crapl
pir8radio 1313 Posted January 23, 2020 Posted January 23, 2020 I ended up finding an ios app "Hue Lights" by LapApps, LLC that let me change the transition time pretty easily 1
BillOatman 597 Posted January 23, 2020 Author Posted January 23, 2020 (edited) All correct, you can't specify the transition time in the call to set the scene. It needs to be defined in the scene setup itself. Not all scene editors allow you to set transition time. I mentioned one way earlier in this thread that does for Windows and is free. Oh yes, mentioned on page 9 as well .. Huetro I also thought trying to redefine the scene transition from the plugin config was above and beyond the call of duty Edited January 23, 2020 by BillOatman
WilhelmStroker 107 Posted January 23, 2020 Posted January 23, 2020 2 small issues with the current version: 1) My Roku stick doesn't seem to have an icon in the plugin. It does have one in the devices section in Emby and my Xbox and Emby Theater show up fine. 2) I've configured all settings, and when I go back into the settings, whatever is configured for Series is not readable. Movies and Live TV are still fine. Disabled Ublock but that didn't make any difference. The plugin still works though Thanks.
BillOatman 597 Posted January 23, 2020 Author Posted January 23, 2020 2 small issues with the current version: 1) My Roku stick doesn't seem to have an icon in the plugin. It does have one in the devices section in Emby and my Xbox and Emby Theater show up fine. 2) I've configured all settings, and when I go back into the settings, whatever is configured for Series is not readable. Movies and Live TV are still fine. Disabled Ublock but that didn't make any difference. The plugin still works though Thanks. Did the previous plugin (huemoodcontrol) icon work on the stick?
chef 3811 Posted January 23, 2020 Posted January 23, 2020 Did the previous plugin (huemoodcontrol) icon work on the stick? I think he means the push discovery image in the plugin UI.
BillOatman 597 Posted January 23, 2020 Author Posted January 23, 2020 I think he means the push discovery image in the plugin UI. Ohhhhhhh yeah. That is a pretty one
WilhelmStroker 107 Posted January 23, 2020 Posted January 23, 2020 I think he means the push discovery image in the plugin UI. Yup! All my other devices show an icon, apart from my Roku.
chef 3811 Posted January 23, 2020 Posted January 23, 2020 (edited) Yup! All my other devices show an icon, apart from my Roku. Ohh, that icon. That's an easy fix. Thanks! It's fixed for the next release thanks guys! Edited January 23, 2020 by chef 1
julianb 39 Posted January 23, 2020 Posted January 23, 2020 Not that it matters, but the icon for Kodi does not show either. Maybe we should have a "generic" icon also
chef 3811 Posted January 23, 2020 Posted January 23, 2020 Not that it matters, but the icon for Kodi does not show either. Maybe we should have a "generic" icon also I'll add them all for 1.0.0.9 I was a bit choosey for time sake. Consider it done! 2
chef 3811 Posted January 23, 2020 Posted January 23, 2020 It's all been added in 1.0.0.9 which means dual update. Interested in how the credit scenes work out. Like I say, I don't have a hue, I wrote this thing from the API docs. This means I can't test it like it should be. Pretty sure the logic makes sense.
chef 3811 Posted January 23, 2020 Posted January 23, 2020 (edited) private List<string> CreditSessions = new List<string>(); //That list of session IDs we need to ignore private void PlaybackCredits(PlaybackProgressEventArgs e, PhillipsHueSceneEmbyProfile profile, PluginConfiguration config) { if (profile.MediaItemCredits == null) return; //Users not using it. if (CreditSessions.Exists(s => s.Equals(e.Session.Id))) return; //We've already triggered the event, it's in the list - move on //So much calculations every second!! var runTime = e.Item.RunTimeTicks; var playbackPosition = e.Item.PlaybackPositionTicks; var positionTriggerSeconds = runTime - (profile.MediaItemCreditLength * 20); //20 ticks in a second (we've asked the user to think of this input in seconds) if (playbackPosition < positionTriggerSeconds) return; //It's not time yet, move on CreditSessions.Add(e.Session.Id); //Add the session ID to the list so this event doesn't trigger again logger.Info($"Phillips Hue Reports {e.MediaInfo.Type} will trigger Credit Scene on {e.DeviceName}"); //Log that shit. RunScene(JsonSerializer.SerializeToString(new SceneRequest { scene = profile.MediaItemCredits }), config); } Make sense to anyone else? Empty the list on stop events (if the session exists in the list). Person might have stopped playback during the credits. Edited January 23, 2020 by chef
julianb 39 Posted January 23, 2020 Posted January 23, 2020 It's all been added in 1.0.0.9 which means dual update. Interested in how the credit scenes work out. Like I say, I don't have a hue, I wrote this thing from the API docs. This means I can't test it like it should be. Pretty sure the logic makes sense. Just installed the new version. Gonna check it out now Sent from my BLA-L29 using Tapatalk
