psybertech 33 Posted January 16, 2020 Posted January 16, 2020 We finished testing. You want to try it? I do! 1
GugZi 2 Posted January 16, 2020 Posted January 16, 2020 (edited) Yea i do want to try it Edited January 16, 2020 by GugZi
BillOatman 597 Posted January 19, 2020 Author Posted January 19, 2020 (edited) I'm back now. The plugin is in the catalog now under a different name. There is a problem with how it installs, but @@chef will get that solved quickly. It looks nice and works great! Update: The install is corrected. Edited January 19, 2020 by BillOatman
WilhelmStroker 107 Posted January 20, 2020 Posted January 20, 2020 I'm back now. The plugin is in the catalog now under a different name. There is a problem with how it installs, but @@chef will get that solved quickly. It looks nice and works great! Update: The install is corrected. I just tried to install the new plugin and it looks like the file gets copied to the correct location but without the .dll extension. Had to rename it to dll and restart emby for it to show up.
chef 3811 Posted January 20, 2020 Posted January 20, 2020 I just tried to install the new plugin and it looks like the file gets copied to the correct location but without the .dll extension. Had to rename it to dll and restart emby for it to show up. Yes there was a problem with the admin account, but it's has been fixed. Thanks WilhelmStroker
BillOatman 597 Posted January 20, 2020 Author Posted January 20, 2020 There is another issue related to the start time that Chef is correcting. We are working together now to get this finished up.
julianb 39 Posted January 21, 2020 Posted January 21, 2020 I just installed the new plugin you guys made: "Philips Hue" instead of the old "HueMoodLighting". I can connect to the brigde just fine, but none of my scenes is showing. So I can't do anything with it yet. Is there a solution for this problem?
chef 3811 Posted January 21, 2020 Posted January 21, 2020 (edited) I just installed the new plugin you guys made: "Philips Hue" instead of the old "HueMoodLighting". I can connect to the brigde just fine, but none of my scenes is showing. So I can't do anything with it yet. Is there a solution for this problem? Did you remove the old plugin? Can you post a log please. Edited January 21, 2020 by chef
BillOatman 597 Posted January 21, 2020 Author Posted January 21, 2020 And can you post what your scene names are as well @@julianb ?
julianb 39 Posted January 21, 2020 Posted January 21, 2020 Did you remove the old plugin? Can you post a log please. Nope, I haven't removed the old plugin yet. I can uninstall it tomorrow and see if this helps. If not I can post log, not at the computer atm. Sent from my BLA-L29 using Tapatalk
julianb 39 Posted January 21, 2020 Posted January 21, 2020 And can you post what your scene names are as well @@julianb ?My scene names are: LightsOn, LightsPause, LightsOff Sent from my BLA-L29 using Tapatalk
chef 3811 Posted January 21, 2020 Posted January 21, 2020 Nope, I haven't removed the old plugin yet. I can uninstall it tomorrow and see if this helps. If not I can post log, not at the computer atm. Sent from my BLA-L29 using Tapatalk That is your problem. Remove the old plugin. Then restart the server.
BillOatman 597 Posted January 22, 2020 Author Posted January 22, 2020 (edited) Current version is working now thanks to @@chef.. You will have to restart Emby to get it to update. And important safety note ... uninstall huemoodcontrol. Edited January 22, 2020 by BillOatman
pir8radio 1313 Posted January 22, 2020 Posted January 22, 2020 Current version is working now thanks to @@chef.. You will have to restart Emby to get it to update. And important safety note ... uninstall huemoodcontrol. If it is removed from the emby plugin store, does it auto un-install from servers?
BillOatman 597 Posted January 22, 2020 Author Posted January 22, 2020 There is a problem with remote users triggering scenes being set which is being worked on. But if you use one emby client you should be fine. The symptom is your lights will do unexpected things.
julianb 39 Posted January 22, 2020 Posted January 22, 2020 That is your problem. Remove the old plugin. Then restart the server. Thanks, that was the problem! Works flawless now!
julianb 39 Posted January 22, 2020 Posted January 22, 2020 Btw, I would love to have an "End Credit" scene with the possibility to set the timer. Like this: Choose a scene to execute when end credits start. Choose time to execute "end credits scene" (example: 10 minutes before the movie ends)
chef 3811 Posted January 22, 2020 Posted January 22, 2020 Btw, I would love to have an "End Credit" scene with the possibility to set the timer. Like this: Choose a scene to execute when end credits start. Choose time to execute "end credits scene" (example: 10 minutes before the movie ends) Are you sure you want the server processing that data behind the scenes? Monitoring when media is about to finish playing?
julianb 39 Posted January 22, 2020 Posted January 22, 2020 I don't know, do you think it will be a lot to process? I thought Emby already knew when a movie was ending? (Ends at 18:45). Can't it just calculate +/- that time? If it would make a lot of stress on the server then it won't be worth it
chef 3811 Posted January 22, 2020 Posted January 22, 2020 I don't know, do you think it will be a lot to process? I thought Emby already knew when a movie was ending? (Ends at 18:45). Can't it just calculate +/- that time? If it would make a lot of stress on the server then it won't be worth it Emby will calculate the endtime, but we'd have to check every time the progress event is fired. Maybe it wouldn't be very taxing. We do currently check paused state right now. But, checking state is a bit different then calculating a new condition each time the progress counter increments and pulling data from the config as well. Unless we hold the variable when the media item starts playing and check against it in memory.but we would still be iterating a list every second or so. It'll take a second or two to code.
WilhelmStroker 107 Posted January 22, 2020 Posted January 22, 2020 I don't know, do you think it will be a lot to process? I thought Emby already knew when a movie was ending? (Ends at 18:45). Can't it just calculate +/- that time? If it would make a lot of stress on the server then it won't be worth it I've never really properly looked at the end time, but as far as I remember, once you stop a movie and then restart it, the end time is still calculated from the original length of the movie so I don't think that will be consistent.
