BillOatman 597 Posted October 8, 2019 Author Posted October 8, 2019 I have the same problem as you. I tried setting this up with current beta server over last few beta releases and all i get is spinning circle when trying to save setup. Krs Mark Sent from my SM-N976B using Tapatalk I'd report that in the beta forum so it can get addressed. The plugin works fine with current stable release, and apparently it worked OK with the first few beta releases as well.
maegibbons 1287 Posted October 8, 2019 Posted October 8, 2019 I'd report that in the beta forum so it can get addressed. The plugin works fine with current stable release, and apparently it worked OK with the first few beta releases as well.I don't think it works like that! @@Luke will not debug your plugins for you. If you can find the error he will work with you to fix it if it is a server side issue. Krs Mark Sent from my SM-N976B using Tapatalk
BillOatman 597 Posted October 9, 2019 Author Posted October 9, 2019 I don't think it works like that! @@Luke will not debug your plugins for you. If you can find the error he will work with you to fix it if it is a server side issue. Krs Mark Sent from my SM-N976B using Tapatalk So you think it works in the release version, doesn't in a beta, it's the plugin that needs to be debugged?
maegibbons 1287 Posted October 9, 2019 Posted October 9, 2019 So you think it works in the release version, doesn't in a beta, it's the plugin that needs to be debugged? Yes.. the server API is changing all the time with some calls deprecated from version to version. You will have to release compatability updates from time to time. Krs Mark Sent from my SM-N976B using Tapatalk
BillOatman 597 Posted October 9, 2019 Author Posted October 9, 2019 (edited) @Luke I don't run beta software, but this is the exception from the browser console that someone sent me. Happens in the beta server but not in the stable release. I don't have any javascript "promise" logic in the plugin anywhere. Is this known to be broken, or has something intentionally changed in the beta? [Error] TypeError: undefined is not an object (evaluating 'this.labelElement.htmlFor=this.id') _connectedCallback (emby-input.js:1:1101) value (emby-input.js:1:1679) o (custom-elements-builtin.js:1:754) u (custom-elements-builtin.js:1:836) o (custom-elements-builtin.js:1:692) (anonyme Funktion) (custom-elements-builtin.js:1:1453) [Log] Requesting url without automatic networking: http://192.168.178.7:8096/emby/Plugins/682B32EB-CD95-447A-AA5E-B3BD7E9F8615/Configuration (apiclient.js, line 1) [Log] Requesting url without automatic networking: http://192.168.178.7:8096/emby/Devices?SupportsPersistentIdentifier=true (apiclient.js, line 1) [Log] Requesting url without automatic networking: http://192.168.178.7:8096/emby/GetScenes?BridgeIP=192.168.178.66 (apiclient.js, line 1) [Error] Unhandled Promise Rejection: TypeError: undefined is not a function (near '...})).selectmenu('refresh').trigger(...') (anonyme Funktion) (Skriptelement 2:88) promiseReactionJob [Log] Requesting url without automatic networking: http://192.168.178.7:8096/emby/Plugins/682B32EB-CD95-447A-AA5E-B3BD7E9F8615/Configuration (apiclient.js, line 1) [Error] Unhandled Promise Rejection: TypeError: $('#chkEnabled', page).checked is not a function. (In '$('#chkEnabled', page).checked(hueConfig.Enabled || false)', '$('#chkEnabled', page).checked' is undefined) (anonyme Funktion) (Skriptelement 2:135) promiseReactionJob Edited October 9, 2019 by BillOatman 1
Luke 42251 Posted October 9, 2019 Posted October 9, 2019 Yes just convert that to vanilla js and then it will work with both servers. 1
BillOatman 597 Posted October 9, 2019 Author Posted October 9, 2019 Bye bye jQuery I'm sure there is a reason, but feels like a step backwards.
Luke 42251 Posted October 9, 2019 Posted October 9, 2019 It served it's purpose long ago to mitigate differences across browsers. Today it is no longer needed.
julianb 39 Posted October 14, 2019 Posted October 14, 2019 Just wanted to thank you for the work on this plugin! I've been using it for some weeks now, and it works just perfect! It's easy and a much better solution then what I previously had with CinemaVision. I'm looking for a similar solution for SmartThings, so I can control my blinds etc when a movie starts playing Btw, would be nice if there was a way to adjust the timer for the "credits" scene. I think it kicks in a little too slow for most movies. Anyway, thank you again! You made my "Movie Theater" more complete
BillOatman 597 Posted October 14, 2019 Author Posted October 14, 2019 If you mean the transition time for the credits scene ... all transition times for scenes are configures in the scene itself on the bridge. Or do you mean ow much time before the end of the movie the credits scene is triggered?
julianb 39 Posted October 16, 2019 Posted October 16, 2019 If you mean the transition time for the credits scene ... all transition times for scenes are configures in the scene itself on the bridge. Or do you mean ow much time before the end of the movie the credits scene is triggered? Sorry, yes I mean how much time it takes before it triggers the credits light scene at the end of the movie. Not transition time. Would be nice with an +/- offset button. I think it kicks in a little to slow, no big deal though
BillOatman 597 Posted October 16, 2019 Author Posted October 16, 2019 Sorry, yes I mean how much time it takes before it triggers the credits light scene at the end of the movie. Not transition time. Would be nice with an +/- offset button. I think it kicks in a little to slow, no big deal though I'll try and add that when I have some time. Thanks! 1
limdul 0 Posted December 8, 2019 Posted December 8, 2019 Hi, since I've updated Emby to 4.3.0.30 the settings page is not working, same spinning circle when trying to select device as mentioned from maegibbons & tmb4016
jchh 0 Posted December 9, 2019 Posted December 9, 2019 Just downloaded and installed this plugin - I also get the spinning wheel.
hstamas 179 Posted December 9, 2019 Posted December 9, 2019 Same here. Im sure Bill will get it straightened out.
BillOatman 597 Posted December 9, 2019 Author Posted December 9, 2019 Hi. I have enlisted the help of the mighty @@chef to get this figured out. I suck at that javascript stuff Hopefully I'll have a release within a few days
BillOatman 597 Posted December 11, 2019 Author Posted December 11, 2019 Just an update, we are working on it 1
Pog22 52 Posted December 21, 2019 Posted December 21, 2019 I had this working, then when I tried to change a scene I got the spinner. So I foolishly uninstalled and deleted the .xml and now I can't get it to work again, I can connect to the Hue bridgebut cannot set a scene. Can someone please share with me an .xml template so I can get it working again
tymanthius 18 Posted December 31, 2019 Posted December 31, 2019 Just an update, we are working on it Any further updates? I know the holidays probably ate a lot of time.
pir8radio 1313 Posted January 1, 2020 Posted January 1, 2020 Was there any kid of fix, for the issue when i pause a movie... a few mins later hue thinks i hit stop, brings lights to "stop" position, then when i un-pause, lights stay at stop position.. To fix I have to stop movie and re-play.
chef 3811 Posted January 1, 2020 Posted January 1, 2020 (edited) Was there any kid of fix, for the issue when i pause a movie... a few mins later hue thinks i hit stop, brings lights to "stop" position, then when i un-pause, lights stay at stop position.. To fix I have to stop movie and re-play. Sorry, this is my fault, I've had to start a new source code for the project and I finally have a second to help. Edited January 21, 2020 by chef
chef 3811 Posted January 16, 2020 Posted January 16, 2020 Still nothing new? We finished testing. You want to try it?
