dmtg 11 Posted July 26, 2022 Posted July 26, 2022 is not possible when the movie play turn off the ligths?
BillOatman 597 Posted July 27, 2022 Author Posted July 27, 2022 14 hours ago, dmtg said: is not possible when the movie play turn off the ligths? Yes it is possible. Create a scene in the hub where all the lights are off, then in the plugin configuration set that scene name.
dmtg 11 Posted July 27, 2022 Posted July 27, 2022 (edited) 11 hours ago, BillOatman said: Yes it is possible. Create a scene in the hub where all the lights are off, then in the plugin configuration set that scene name. In the application philips-hue say cannot create a scene with all lights off I need one lights on. Solved with hue essentials app. Thanks Edited July 28, 2022 by dmtg
BillOatman 597 Posted July 29, 2022 Author Posted July 29, 2022 On 7/27/2022 at 5:57 PM, dmtg said: In the application philips-hue say cannot create a scene with all lights off I need one lights on. Solved with hue essentials app. Thanks Glad you got it sorted out. Various apps do things in quirky ways. At one point, one well known app didn't allow scene creation.
jhoff80 94 Posted September 5, 2022 Posted September 5, 2022 (edited) This was working great for a while, but seems to have gotten broken lately. In the settings, I see "Connection Ok" but it no longer sees any scenes to add. Anyone else seeing similar? I'll try re-adding the hub when I've got some time to mess around with it. Edit: Never mind, false alarm. My Hue Hub IP address had changed on the network. Reconnecting fixed it. Edited September 6, 2022 by jhoff80
BillOatman 597 Posted September 11, 2022 Author Posted September 11, 2022 On 9/5/2022 at 3:07 PM, jhoff80 said: This was working great for a while, but seems to have gotten broken lately. In the settings, I see "Connection Ok" but it no longer sees any scenes to add. Anyone else seeing similar? I'll try re-adding the hub when I've got some time to mess around with it. Edit: Never mind, false alarm. My Hue Hub IP address had changed on the network. Reconnecting fixed it. Might want to assign it a static IP
echan42 0 Posted October 7, 2022 Posted October 7, 2022 (edited) Hey! Just started using emby this week, I used to run Kodi with yeelight plugin. Just a quick question regarding this plugin's future, do you have a roadmap or a list of features you intend to add? I'd love to see the following 2 features added in the future: - Individual room control -an "off" scene (sorry I just saw you answered this a few messages prior) How does one create a "all lights off scene" Edited October 7, 2022 by echan42
BillOatman 597 Posted October 7, 2022 Author Posted October 7, 2022 2 hours ago, echan42 said: Hey! Just started using emby this week, I used to run Kodi with yeelight plugin. Just a quick question regarding this plugin's future, do you have a roadmap or a list of features you intend to add? I'd love to see the following 2 features added in the future: - Individual room control -an "off" scene (sorry I just saw you answered this a few messages prior) How does one create a "all lights off scene" Hi. Everything is done with scenes, and specific to a particular emby client. So you should be able to get the "Individual room control" you are looking for, Some of the scene creation apps do not allow for a scene to set a light all the way. Probably need to try different software. I believe if you search this thread you'll see messages about that. I don't have any feature plans. But it's open source so the sky is the limit
echan42 0 Posted October 8, 2022 Posted October 8, 2022 10 hours ago, BillOatman said: Hi. Everything is done with scenes, and specific to a particular emby client. So you should be able to get the "Individual room control" you are looking for, Some of the scene creation apps do not allow for a scene to set a light all the way. Probably need to try different software. I believe if you search this thread you'll see messages about that. I don't have any feature plans. But it's open source so the sky is the limit Gotcha! Thank you so much for your response! I've got some catching up to do, thank you for your great work.
AsheAshe 8 Posted January 5, 2023 Posted January 5, 2023 I want to set this up but when I look in the catalogue I can't see it anywhere? Do I have to add it manually?
AsheAshe 8 Posted January 5, 2023 Posted January 5, 2023 23 minutes ago, AsheAshe said: I want to set this up but when I look in the catalogue I can't see it anywhere? Do I have to add it manually? Scratch that, I located the plug-in on desktop client I've pushed the push link button on my hue hub but it seems stuck on "starting discovery" with a blue spinning circle. I tried rebooting hub and even using a software to trigger the push link to no avail. I've reinstalled the plugin, tried using an older version but it auto updated, not sure what else I can try?
BillOatman 597 Posted January 5, 2023 Author Posted January 5, 2023 3 hours ago, AsheAshe said: Scratch that, I located the plug-in on desktop client I've pushed the push link button on my hue hub but it seems stuck on "starting discovery" with a blue spinning circle. I tried rebooting hub and even using a software to trigger the push link to no avail. I've reinstalled the plugin, tried using an older version but it auto updated, not sure what else I can try? Turn debug logging on and try that again. See if the log shows anything. I'll try and find time to try it myself tonight.
AsheAshe 8 Posted January 5, 2023 Posted January 5, 2023 56 minutes ago, BillOatman said: Turn debug logging on and try that again. See if the log shows anything. I'll try and find time to try it myself tonight. Tried it again an hour later and it's working now!
AsheAshe 8 Posted January 5, 2023 Posted January 5, 2023 Is there any way to set it so there is a time range between functioning? I'd ideally want it to work between 5pm and 11:30pm and after that not control the lights as for our bedroom I dont want lights coming on when I pause etc?
BillOatman 597 Posted January 5, 2023 Author Posted January 5, 2023 (edited) 37 minutes ago, AsheAshe said: Is there any way to set it so there is a time range between functioning? I'd ideally want it to work between 5pm and 11:30pm and after that not control the lights as for our bedroom I dont want lights coming on when I pause etc? All available options are set on the config page. I thought that was an option but I do not remember anymore. EDIT: I tool a look and it looks like it wont set the scene if the time is between a configured start time per hue hub and 6am. Edited January 5, 2023 by BillOatman
AsheAshe 8 Posted January 5, 2023 Posted January 5, 2023 (edited) 29 minutes ago, BillOatman said: All available options are set on the config page. I thought that was an option but I do not remember anymore. EDIT: I tool a look and it looks like it wont set the scene if the time is between a configured start time per hue hub and 6am. Yeah you can set the start time but the end time is fixed at 6am which is fine for a living room but for a bedroom it makes it harder (in that up to a certain time say 11pm, I'd want the lights to function but after that I'd not want brighter lights coming on at 1am if that makes sense?) Edited January 5, 2023 by AsheAshe
BillOatman 597 Posted January 5, 2023 Author Posted January 5, 2023 46 minutes ago, AsheAshe said: Yeah you can set the start time but the end time is fixed at 6am which is fine for a living room but for a bedroom it makes it harder (in that up to a certain time say 11pm, I'd want the lights to function but after that I'd not want brighter lights coming on at 1am if that makes sense?) So what you want changed, you would like different scenes based upon time of day?
AsheAshe 8 Posted January 5, 2023 Posted January 5, 2023 (edited) 1 hour ago, BillOatman said: So what you want changed, you would like different scenes based upon time of day? That would be a good feature, although may be a lot more complexity for you to add and limited people pay use it I guess. It may be simpler to to just have a similar time selection for end time so you can pick when it takes effect? e.g start time 5pm/end time 11pm Edited January 5, 2023 by AsheAshe
BillOatman 597 Posted January 6, 2023 Author Posted January 6, 2023 4 hours ago, AsheAshe said: That would be a good feature, although may be a lot more complexity for you to add and limited people pay use it I guess. It may be simpler to to just have a similar time selection for end time so you can pick when it takes effect? e.g start time 5pm/end time 11pm Its open source so anyone can change it. But I will look into adding that.
echan42 0 Posted January 9, 2023 Posted January 9, 2023 I've been having this issue where when I pause a movie and then resume it the lights sometimes (50% of the time) stay on for 10 seconds before reacting and turning off. Does anybody else have a similar issue? What can I do on my end do diagnose or solve this?
AsheAshe 8 Posted January 9, 2023 Posted January 9, 2023 6 minutes ago, echan42 said: I've been having this issue where when I pause a movie and then resume it the lights sometimes (50% of the time) stay on for 10 seconds before reacting and turning off. Does anybody else have a similar issue? What can I do on my end do diagnose or solve this? I have similar experience if I leave it paused a while and push play, it remains in the "pause" lighting stage - I have to pause and quickly unpause to trigger the correct behaviour, else it does it itself after 10 seconds or so it seems to be if I leave it paused maybe 2 minutes or more I've just timed it with Alexa and if I pause it for 1 minute 30 seconds it behaves normally, 1 minute 45 same experience but 2 minutes or more it does the delayed reaction.
BillOatman 597 Posted January 9, 2023 Author Posted January 9, 2023 2 hours ago, echan42 said: I've been having this issue where when I pause a movie and then resume it the lights sometimes (50% of the time) stay on for 10 seconds before reacting and turning off. Does anybody else have a similar issue? What can I do on my end do diagnose or solve this? You can get it to do that bad behavior with debug logging turned on and post the log along with what happened and what time you did it.
BillOatman 597 Posted January 9, 2023 Author Posted January 9, 2023 On 1/5/2023 at 3:09 PM, AsheAshe said: That would be a good feature, although may be a lot more complexity for you to add and limited people pay use it I guess. It may be simpler to to just have a similar time selection for end time so you can pick when it takes effect? e.g start time 5pm/end time 11pm I have some code ready for this that I should get to the owner to look at and release today or tomorrow.
AsheAshe 8 Posted January 9, 2023 Posted January 9, 2023 (edited) 1 hour ago, BillOatman said: You can get it to do that bad behavior with debug logging turned on and post the log along with what happened and what time you did it. 023-01-09 15:59:25.268 Info Phillips Hue: Phillips Hue Reports Playback Started 2023-01-09 15:59:25.268 Info Phillips Hue: Phillips Hue Found Profile Device: SHIELD 2023-01-09 15:59:25.268 Info Phillips Hue: Phillips Hue Reports Episode will trigger Playback Started Scene on SHIELD 2023-01-09 15:59:25.268 Info HttpClient: PUT http://192.168.1.137/api/hkPKJ1tC3iIi1FwloUYOEwzinIjXlUH-pUatR96S/groups/0/action 2023-01-09 15:59:25.268 Info Server: http/1.1 Response 204 to host4. Time: 2ms. http://host2:8096/emby/Sessions/Playing 2023-01-09 15:59:25.268 Info Phillips Hue: Phillips Hue Reports Scene Trigger Success 2023-01-09 15:59:25.378 Info Server: http/1.1 GET http://host2:8096/emby/videos/5234/stream.mkv?DeviceId=517e14e6137dade6&MediaSourceId=c40969d85ccc6c823ea211544f9df80d&Static=true&PlaySessionId=0be5adc28b104be48b806ad7e3ea8d1b. Connection=keep-alive, Host=192.168.1.167:8096, User-Agent=Emby/2.0.83g (Linux;Android 11) ExoPlayerLib/2.16.1, Accept-Encoding=identity, Icy-MetaData=1 2023-01-09 15:59:25.381 Debug Server: http/1.1 GET http://host2:8096/emby/Items/5234/ThumbnailSet?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 15:59:25.385 Debug Server: http/1.1 Response 200 to host4. Time: 2ms. http://host2:8096/emby/Items/5234/ThumbnailSet?format=json 2023-01-09 15:59:25.489 Info Server: http/1.1 Response 200 to host4. Time: 111ms. http://host2:8096/emby/videos/5234/stream.mkv?DeviceId=517e14e6137dade6&MediaSourceId=c40969d85ccc6c823ea211544f9df80d&Static=true&PlaySessionId=0be5adc28b104be48b806ad7e3ea8d1b 2023-01-09 15:59:25.491 Info Server: http/1.1 GET http://host2:8096/emby/videos/5234/stream.mkv?DeviceId=517e14e6137dade6&MediaSourceId=c40969d85ccc6c823ea211544f9df80d&Static=true&PlaySessionId=0be5adc28b104be48b806ad7e3ea8d1b. Connection=keep-alive, Host=192.168.1.167:8096, User-Agent=Emby/2.0.83g (Linux;Android 11) ExoPlayerLib/2.16.1, Accept-Encoding=identity, Range=bytes=3515505194-, Icy-MetaData=1 2023-01-09 15:59:25.493 Info Server: http/1.1 Response 206 to host4. Time: 2ms. http://host2:8096/emby/videos/5234/stream.mkv?DeviceId=517e14e6137dade6&MediaSourceId=c40969d85ccc6c823ea211544f9df80d&Static=true&PlaySessionId=0be5adc28b104be48b806ad7e3ea8d1b 2023-01-09 15:59:25.502 Info Server: http/1.1 GET http://host2:8096/emby/videos/5234/stream.mkv?DeviceId=517e14e6137dade6&MediaSourceId=c40969d85ccc6c823ea211544f9df80d&Static=true&PlaySessionId=0be5adc28b104be48b806ad7e3ea8d1b. Connection=keep-alive, Host=192.168.1.167:8096, User-Agent=Emby/2.0.83g (Linux;Android 11) ExoPlayerLib/2.16.1, Accept-Encoding=identity, Range=bytes=5911-, Icy-MetaData=1 2023-01-09 15:59:25.856 Debug Server: http/1.1 GET http://host2:8096/emby/DisplayPreferences/5234?client=ATV&userId=2e5ed6b0ef644d22ae910356dc7d06c1&format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 15:59:25.857 Debug Server: http/1.1 Response 200 to host4. Time: 1ms. http://host2:8096/emby/DisplayPreferences/5234?client=ATV&userId=2e5ed6b0ef644d22ae910356dc7d06c1&format=json 2023-01-09 15:59:25.976 Info Server: http/1.1 Response 206 to host4. Time: 474ms. http://host2:8096/emby/videos/5234/stream.mkv?DeviceId=517e14e6137dade6&MediaSourceId=c40969d85ccc6c823ea211544f9df80d&Static=true&PlaySessionId=0be5adc28b104be48b806ad7e3ea8d1b 2023-01-09 15:59:25.982 Info Server: http/1.1 GET http://host2:8096/emby/videos/5234/stream.mkv?DeviceId=517e14e6137dade6&MediaSourceId=c40969d85ccc6c823ea211544f9df80d&Static=true&PlaySessionId=0be5adc28b104be48b806ad7e3ea8d1b. Connection=keep-alive, Host=192.168.1.167:8096, User-Agent=Emby/2.0.83g (Linux;Android 11) ExoPlayerLib/2.16.1, Accept-Encoding=identity, Range=bytes=1649167862-, Icy-MetaData=1 2023-01-09 15:59:26.267 Info Phillips Hue: Phillips Hue Reports Playback UnPaused... 2023-01-09 15:59:26.267 Info Phillips Hue: Phillips Hue Found Profile Device: SHIELD 2023-01-09 15:59:26.267 Info Phillips Hue: Phillips Hue Reports Episode will trigger Playback UnPaused Scene for SHIELD 2023-01-09 15:59:26.267 Info HttpClient: PUT http://192.168.1.137/api/hkPKJ1tC3iIi1FwloUYOEwzinIjXlUH-pUatR96S/groups/0/action 2023-01-09 15:59:26.267 Info Phillips Hue: Phillips Hue Reports Scene Trigger Success 2023-01-09 15:59:26.641 Info Server: http/1.1 POST http://host2:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 15:59:26.642 Debug SessionManager: OnPlaybackProgress TimeUpdate 0be5adc28b104be48b806ad7e3ea8d1b 2023-01-09 15:59:26.642 Info Server: http/1.1 Response 204 to host4. Time: 2ms. http://host2:8096/emby/Sessions/Playing/Progress 2023-01-09 15:59:36.629 Info Server: http/1.1 POST http://host2:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 15:59:36.630 Debug SessionManager: OnPlaybackProgress TimeUpdate 0be5adc28b104be48b806ad7e3ea8d1b 2023-01-09 15:59:36.631 Info Server: http/1.1 Response 204 to host4. Time: 2ms. http://host2:8096/emby/Sessions/Playing/Progress 2023-01-09 15:59:46.645 Info Server: http/1.1 POST http://host2:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 15:59:46.646 Debug SessionManager: OnPlaybackProgress TimeUpdate 0be5adc28b104be48b806ad7e3ea8d1b 2023-01-09 15:59:46.647 Info Server: http/1.1 Response 204 to host4. Time: 2ms. http://host2:8096/emby/Sessions/Playing/Progress 2023-01-09 15:59:56.650 Info Server: http/1.1 POST http://host2:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 15:59:56.651 Debug SessionManager: OnPlaybackProgress TimeUpdate 0be5adc28b104be48b806ad7e3ea8d1b 2023-01-09 15:59:56.651 Info Server: http/1.1 Response 204 to host4. Time: 1ms. http://host2:8096/emby/Sessions/Playing/Progress 2023-01-09 16:00:00.065 Debug Server: http/1.1 GET http://host2:8096/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Items/Latest?Limit=12&ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805. UserAgent: axios/0.27.2 2023-01-09 16:00:00.139 Debug SqliteItemRepository: GetInternalId from f137a2dd-21bb-c1b9-9aa5-c0f6bf02a805 2023-01-09 16:00:00.142 Debug Server: http/1.1 Response 200 to host6. Time: 76ms. http://host2:8096/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Items/Latest?Limit=12&ParentId=f137a2dd21bbc1b99aa5c0f6bf02a805 2023-01-09 16:00:00.178 Debug Server: http/1.1 Response 200 to host6. Time: 12ms. http://host2:8096/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Items/10039 2023-01-09 16:00:00.179 Debug Server: http/1.1 Response 200 to host6. Time: 13ms. http://host2:8096/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Items/10149 2023-01-09 16:00:00.180 Debug SqliteItemRepository: Public GetItemLinks 2023-01-09 16:00:00.185 Debug Server: http/1.1 Response 200 to host6. Time: 24ms. http://host2:8096/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Items/10610 2023-01-09 16:00:00.185 Debug SqliteItemRepository: Public GetItemLinks 2023-01-09 16:00:00.186 Debug Server: http/1.1 Response 200 to host6. Time: 19ms. http://host2:8096/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Items/10309 2023-01-09 16:00:04.342 Debug Server: http/1.1 GET http://host2:8096/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Items/Latest?Limit=12&ParentId=6c2a057148b4d7c20a207c789aba6d07. UserAgent: axios/0.27.2 2023-01-09 16:00:04.343 Debug SqliteItemRepository: GetInternalId from 6c2a0571-48b4-d7c2-0a20-7c789aba6d07 2023-01-09 16:00:04.356 Debug Server: http/1.1 Response 200 to host6. Time: 14ms. http://host2:8096/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Items/Latest?Limit=12&ParentId=6c2a057148b4d7c20a207c789aba6d07 2023-01-09 16:00:04.363 Debug Server: http/1.1 GET http://host2:8096/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Items/10991. UserAgent: axios/0.27.2 2023-01-09 16:00:04.363 Debug Server: http/1.1 GET http://host2:8096/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Items/11071. UserAgent: axios/0.27.2 2023-01-09 16:00:04.363 Debug Server: http/1.1 GET http://host2:8096/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Items/9893. UserAgent: axios/0.27.2 2023-01-09 16:00:04.366 Debug Server: http/1.1 GET http://host2:8096/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Items/8672. UserAgent: axios/0.27.2 2023-01-09 16:00:04.366 Debug Server: http/1.1 GET http://host2:8096/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Items/9592. UserAgent: axios/0.27.2 2023-01-09 16:00:04.366 Debug Server: http/1.1 GET http://host2:8096/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Items/6941. UserAgent: axios/0.27.2 2023-01-09 16:00:04.366 Debug Server: http/1.1 GET http://host2:8096/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Items/10906. UserAgent: axios/0.27.2 2023-01-09 16:00:04.366 Debug Server: http/1.1 GET http://host2:8096/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Items/11131. UserAgent: axios/0.27.2 2023-01-09 16:00:04.366 Debug Server: http/1.1 GET http://host2:8096/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Items/4311. UserAgent: axios/0.27.2 2023-01-09 16:00:04.366 Debug Server: http/1.1 GET http://host2:8096/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Items/7066. UserAgent: axios/0.27.2 2023-01-09 16:00:04.371 Debug Server: http/1.1 Response 200 to host6. Time: 5ms. http://host2:8096/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Items/9592 2023-01-09 16:00:04.371 Debug Server: http/1.1 GET http://host2:8096/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Items/5248. UserAgent: axios/0.27.2 2023-01-09 16:00:04.378 Debug Server: http/1.1 Response 200 to host6. Time: 15ms. http://host2:8096/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Items/9893 2023-01-09 16:00:04.378 Debug Server: http/1.1 GET http://host2:8096/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Items/40. UserAgent: axios/0.27.2 2023-01-09 16:00:04.380 Debug Server: http/1.1 Response 200 to host6. Time: 14ms. http://host2:8096/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Items/8672 2023-01-09 16:00:04.381 Debug Server: http/1.1 Response 200 to host6. Time: 15ms. http://host2:8096/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Items/11131 2023-01-09 16:00:04.381 Debug Server: http/1.1 Response 200 to host6. Time: 15ms. http://host2:8096/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Items/4311 2023-01-09 16:00:04.383 Debug Server: http/1.1 Response 200 to host6. Time: 5ms. http://host2:8096/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Items/40 2023-01-09 16:00:04.389 Debug Server: http/1.1 Response 200 to host6. Time: 26ms. http://host2:8096/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Items/11071 2023-01-09 16:00:04.389 Debug Server: http/1.1 Response 200 to host6. Time: 23ms. http://host2:8096/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Items/10906 2023-01-09 16:00:04.390 Debug Server: http/1.1 Response 200 to host6. Time: 24ms. http://host2:8096/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Items/7066 2023-01-09 16:00:04.390 Debug Server: http/1.1 Response 200 to host6. Time: 27ms. http://host2:8096/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Items/10991 2023-01-09 16:00:04.390 Debug Server: http/1.1 Response 200 to host6. Time: 19ms. http://host2:8096/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Items/5248 2023-01-09 16:00:04.391 Debug Server: http/1.1 Response 200 to host6. Time: 25ms. http://host2:8096/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Items/6941 2023-01-09 16:00:04.415 Debug Server: http/1.1 GET http://host2:8096/Shows/9893/Seasons. UserAgent: axios/0.27.2 2023-01-09 16:00:04.415 Debug Server: http/1.1 GET http://host2:8096/Shows/9592/Seasons. UserAgent: axios/0.27.2 2023-01-09 16:00:04.416 Debug Server: http/1.1 GET http://host2:8096/Shows/8672/Seasons. UserAgent: axios/0.27.2 2023-01-09 16:00:04.416 Debug Server: http/1.1 Response 200 to host6. Time: 1ms. http://host2:8096/Shows/9893/Seasons 2023-01-09 16:00:04.416 Debug Server: http/1.1 Response 200 to host6. Time: 1ms. http://host2:8096/Shows/9592/Seasons 2023-01-09 16:00:04.416 Debug Server: http/1.1 Response 200 to host6. Time: 1ms. http://host2:8096/Shows/8672/Seasons 2023-01-09 16:00:04.429 Debug Server: http/1.1 GET http://host2:8096/Shows/10906/Seasons. UserAgent: axios/0.27.2 2023-01-09 16:00:04.430 Debug Server: http/1.1 Response 200 to host6. Time: 1ms. http://host2:8096/Shows/10906/Seasons 2023-01-09 16:00:04.432 Debug Server: http/1.1 GET http://host2:8096/Shows/9893/Episodes?seasonId=9905. UserAgent: axios/0.27.2 2023-01-09 16:00:04.432 Debug Server: http/1.1 GET http://host2:8096/Shows/9592/Episodes?seasonId=9593. UserAgent: axios/0.27.2 2023-01-09 16:00:04.432 Debug Server: http/1.1 GET http://host2:8096/Shows/8672/Episodes?seasonId=8673. UserAgent: axios/0.27.2 2023-01-09 16:00:04.433 Debug Server: http/1.1 Response 200 to host6. Time: 2ms. http://host2:8096/Shows/9592/Episodes?seasonId=9593 2023-01-09 16:00:04.434 Debug Server: http/1.1 Response 200 to host6. Time: 2ms. http://host2:8096/Shows/9893/Episodes?seasonId=9905 2023-01-09 16:00:04.434 Debug Server: http/1.1 GET http://host2:8096/Shows/10906/Episodes?seasonId=10907. UserAgent: axios/0.27.2 2023-01-09 16:00:04.434 Debug Server: http/1.1 Response 200 to host6. Time: 3ms. http://host2:8096/Shows/8672/Episodes?seasonId=8673 2023-01-09 16:00:04.435 Debug Server: http/1.1 Response 200 to host6. Time: 1ms. http://host2:8096/Shows/10906/Episodes?seasonId=10907 2023-01-09 16:00:04.440 Debug Server: http/1.1 GET http://host2:8096/Shows/9893/Seasons. UserAgent: axios/0.27.2 2023-01-09 16:00:04.441 Debug Server: http/1.1 Response 200 to host6. Time: 1ms. http://host2:8096/Shows/9893/Seasons 2023-01-09 16:00:04.453 Debug Server: http/1.1 GET http://host2:8096/Shows/9893/Episodes?seasonId=10618. UserAgent: axios/0.27.2 2023-01-09 16:00:04.455 Debug Server: http/1.1 Response 200 to host6. Time: 2ms. http://host2:8096/Shows/9893/Episodes?seasonId=10618 2023-01-09 16:00:04.457 Debug Server: http/1.1 GET http://host2:8096/Shows/11131/Seasons. UserAgent: axios/0.27.2 2023-01-09 16:00:04.458 Debug Server: http/1.1 Response 200 to host6. Time: 1ms. http://host2:8096/Shows/11131/Seasons 2023-01-09 16:00:04.541 Debug Server: http/1.1 GET http://host2:8096/Shows/11131/Episodes?seasonId=11132. UserAgent: axios/0.27.2 2023-01-09 16:00:04.543 Debug Server: http/1.1 Response 200 to host6. Time: 2ms. http://host2:8096/Shows/11131/Episodes?seasonId=11132 2023-01-09 16:00:04.628 Debug Server: http/1.1 GET http://host2:8096/Shows/4311/Seasons. UserAgent: axios/0.27.2 2023-01-09 16:00:04.628 Debug Server: http/1.1 GET http://host2:8096/Shows/11071/Seasons. UserAgent: axios/0.27.2 2023-01-09 16:00:04.628 Debug Server: http/1.1 GET http://host2:8096/Shows/7066/Seasons. UserAgent: axios/0.27.2 2023-01-09 16:00:04.629 Debug Server: http/1.1 Response 200 to host6. Time: 1ms. http://host2:8096/Shows/7066/Seasons 2023-01-09 16:00:04.629 Debug Server: http/1.1 Response 200 to host6. Time: 1ms. http://host2:8096/Shows/4311/Seasons 2023-01-09 16:00:04.629 Debug Server: http/1.1 GET http://host2:8096/Shows/40/Seasons. UserAgent: axios/0.27.2 2023-01-09 16:00:04.629 Debug Server: http/1.1 GET http://host2:8096/Shows/10991/Seasons. UserAgent: axios/0.27.2 2023-01-09 16:00:04.630 Debug Server: http/1.1 Response 200 to host6. Time: 2ms. http://host2:8096/Shows/11071/Seasons 2023-01-09 16:00:04.630 Debug Server: http/1.1 GET http://host2:8096/Shows/5248/Seasons. UserAgent: axios/0.27.2 2023-01-09 16:00:04.630 Debug Server: http/1.1 Response 200 to host6. Time: 1ms. http://host2:8096/Shows/40/Seasons 2023-01-09 16:00:04.630 Debug Server: http/1.1 Response 200 to host6. Time: 1ms. http://host2:8096/Shows/10991/Seasons 2023-01-09 16:00:04.630 Debug Server: http/1.1 GET http://host2:8096/Shows/6941/Seasons. UserAgent: axios/0.27.2 2023-01-09 16:00:04.631 Debug Server: http/1.1 Response 200 to host6. Time: 1ms. http://host2:8096/Shows/5248/Seasons 2023-01-09 16:00:04.631 Debug Server: http/1.1 Response 200 to host6. Time: 1ms. http://host2:8096/Shows/6941/Seasons 2023-01-09 16:00:04.633 Debug Server: http/1.1 GET http://host2:8096/Shows/7066/Episodes?seasonId=7067. UserAgent: axios/0.27.2 2023-01-09 16:00:04.635 Debug Server: http/1.1 Response 200 to host6. Time: 2ms. http://host2:8096/Shows/7066/Episodes?seasonId=7067 2023-01-09 16:00:04.637 Debug Server: http/1.1 GET http://host2:8096/Shows/4311/Episodes?seasonId=4314. UserAgent: axios/0.27.2 2023-01-09 16:00:04.637 Debug Server: http/1.1 GET http://host2:8096/Shows/40/Episodes?seasonId=412. UserAgent: axios/0.27.2 2023-01-09 16:00:04.639 Debug Server: http/1.1 Response 200 to host6. Time: 2ms. http://host2:8096/Shows/40/Episodes?seasonId=412 2023-01-09 16:00:04.639 Debug Server: http/1.1 GET http://host2:8096/Shows/11071/Episodes?seasonId=11072. UserAgent: axios/0.27.2 2023-01-09 16:00:04.639 Debug Server: http/1.1 GET http://host2:8096/Shows/10991/Seasons. UserAgent: axios/0.27.2 2023-01-09 16:00:04.639 Debug Server: http/1.1 Response 200 to host6. Time: 3ms. http://host2:8096/Shows/4311/Episodes?seasonId=4314 2023-01-09 16:00:04.641 Debug Server: http/1.1 Response 200 to host6. Time: 2ms. http://host2:8096/Shows/11071/Episodes?seasonId=11072 2023-01-09 16:00:04.641 Debug Server: http/1.1 GET http://host2:8096/Shows/6941/Episodes?seasonId=6942. UserAgent: axios/0.27.2 2023-01-09 16:00:04.641 Debug Server: http/1.1 Response 200 to host6. Time: 2ms. http://host2:8096/Shows/10991/Seasons 2023-01-09 16:00:04.642 Debug Server: http/1.1 Response 200 to host6. Time: 3ms. http://host2:8096/Shows/5248/Episodes?seasonId=5249 2023-01-09 16:00:04.642 Debug Server: http/1.1 GET http://host2:8096/Shows/40/Seasons. UserAgent: axios/0.27.2 2023-01-09 16:00:04.645 Debug Server: http/1.1 Response 200 to host6. Time: 4ms. http://host2:8096/Shows/6941/Episodes?seasonId=6942 2023-01-09 16:00:04.646 Debug Server: http/1.1 Response 200 to host6. Time: 4ms. http://host2:8096/Shows/40/Seasons 2023-01-09 16:00:04.653 Debug Server: http/1.1 GET http://host2:8096/Shows/10991/Seasons. UserAgent: axios/0.27.2 2023-01-09 16:00:04.653 Debug Server: http/1.1 GET http://host2:8096/Shows/5248/Seasons. UserAgent: axios/0.27.2 2023-01-09 16:00:04.654 Debug Server: http/1.1 Response 200 to host6. Time: 1ms. http://host2:8096/Shows/10991/Seasons 2023-01-09 16:00:04.655 Debug Server: http/1.1 Response 200 to host6. Time: 2ms. http://host2:8096/Shows/5248/Seasons 2023-01-09 16:00:04.656 Debug Server: http/1.1 GET http://host2:8096/Shows/40/Episodes?seasonId=413. UserAgent: axios/0.27.2 2023-01-09 16:00:04.657 Debug Server: http/1.1 Response 200 to host6. Time: 2ms. http://host2:8096/Shows/40/Episodes?seasonId=413 2023-01-09 16:00:04.663 Debug Server: http/1.1 GET http://host2:8096/Shows/10991/Seasons. UserAgent: axios/0.27.2 2023-01-09 16:00:04.663 Debug Server: http/1.1 GET http://host2:8096/Shows/5248/Episodes?seasonId=5250. UserAgent: axios/0.27.2 2023-01-09 16:00:04.665 Debug Server: http/1.1 Response 200 to host6. Time: 2ms. http://host2:8096/Shows/10991/Seasons 2023-01-09 16:00:04.667 Debug Server: http/1.1 Response 200 to host6. Time: 4ms. http://host2:8096/Shows/5248/Episodes?seasonId=5250 2023-01-09 16:00:04.668 Debug Server: http/1.1 GET http://host2:8096/Shows/10991/Episodes?seasonId=10992. UserAgent: axios/0.27.2 2023-01-09 16:00:04.670 Debug Server: http/1.1 Response 200 to host6. Time: 2ms. http://host2:8096/Shows/10991/Episodes?seasonId=10992 2023-01-09 16:00:04.670 Debug Server: http/1.1 GET http://host2:8096/Shows/5248/Seasons. UserAgent: axios/0.27.2 2023-01-09 16:00:04.671 Debug Server: http/1.1 Response 200 to host6. Time: 1ms. http://host2:8096/Shows/5248/Seasons 2023-01-09 16:00:04.727 Debug Server: http/1.1 GET http://host2:8096/Shows/5248/Episodes?seasonId=5251. UserAgent: axios/0.27.2 2023-01-09 16:00:04.730 Debug Server: http/1.1 Response 200 to host6. Time: 3ms. http://host2:8096/Shows/5248/Episodes?seasonId=5251 2023-01-09 16:00:04.732 Debug Server: http/1.1 GET http://host2:8096/Shows/5248/Seasons. UserAgent: axios/0.27.2 2023-01-09 16:00:04.733 Debug Server: http/1.1 Response 200 to host6. Time: 1ms. http://host2:8096/Shows/5248/Seasons 2023-01-09 16:00:04.735 Debug Server: http/1.1 GET http://host2:8096/Shows/5248/Episodes?seasonId=5252. UserAgent: axios/0.27.2 2023-01-09 16:00:04.742 Debug Server: http/1.1 Response 200 to host6. Time: 7ms. http://host2:8096/Shows/5248/Episodes?seasonId=5252 2023-01-09 16:00:06.654 Info Server: http/1.1 POST http://host2:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 16:00:06.655 Debug SessionManager: OnPlaybackProgress TimeUpdate 0be5adc28b104be48b806ad7e3ea8d1b 2023-01-09 16:00:06.656 Info Server: http/1.1 Response 204 to host4. Time: 2ms. http://host2:8096/emby/Sessions/Playing/Progress 2023-01-09 16:00:16.653 Info Server: http/1.1 POST http://host2:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 16:00:16.654 Debug SessionManager: OnPlaybackProgress TimeUpdate 0be5adc28b104be48b806ad7e3ea8d1b 2023-01-09 16:00:16.654 Info Server: http/1.1 Response 204 to host4. Time: 2ms. http://host2:8096/emby/Sessions/Playing/Progress 2023-01-09 16:00:26.636 Info Server: http/1.1 POST http://host2:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 16:00:26.637 Debug SessionManager: OnPlaybackProgress TimeUpdate 0be5adc28b104be48b806ad7e3ea8d1b 2023-01-09 16:00:26.637 Info Server: http/1.1 Response 204 to host4. Time: 2ms. http://host2:8096/emby/Sessions/Playing/Progress 2023-01-09 16:00:36.668 Info Server: http/1.1 POST http://host2:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 16:00:36.669 Debug SessionManager: OnPlaybackProgress TimeUpdate 0be5adc28b104be48b806ad7e3ea8d1b 2023-01-09 16:00:36.669 Info Server: http/1.1 Response 204 to host4. Time: 2ms. http://host2:8096/emby/Sessions/Playing/Progress 2023-01-09 16:00:46.668 Info Server: http/1.1 POST http://host2:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 16:00:46.669 Debug SessionManager: OnPlaybackProgress TimeUpdate 0be5adc28b104be48b806ad7e3ea8d1b 2023-01-09 16:00:46.670 Info Server: http/1.1 Response 204 to host4. Time: 1ms. http://host2:8096/emby/Sessions/Playing/Progress 2023-01-09 16:00:56.674 Info Server: http/1.1 POST http://host2:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 16:00:56.675 Debug SessionManager: OnPlaybackProgress TimeUpdate 0be5adc28b104be48b806ad7e3ea8d1b 2023-01-09 16:00:56.676 Info Server: http/1.1 Response 204 to host4. Time: 2ms. http://host2:8096/emby/Sessions/Playing/Progress 2023-01-09 16:01:06.656 Info Server: http/1.1 POST http://host2:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 16:01:06.657 Debug SessionManager: OnPlaybackProgress TimeUpdate 0be5adc28b104be48b806ad7e3ea8d1b 2023-01-09 16:01:06.657 Info Server: http/1.1 Response 204 to host4. Time: 2ms. http://host2:8096/emby/Sessions/Playing/Progress 2023-01-09 16:01:16.678 Info Server: http/1.1 POST http://host2:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 16:01:16.679 Debug SessionManager: OnPlaybackProgress TimeUpdate 0be5adc28b104be48b806ad7e3ea8d1b 2023-01-09 16:01:16.679 Info Server: http/1.1 Response 204 to host4. Time: 2ms. http://host2:8096/emby/Sessions/Playing/Progress 2023-01-09 16:01:26.682 Info Server: http/1.1 POST http://host2:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 16:01:26.683 Debug SessionManager: OnPlaybackProgress TimeUpdate 0be5adc28b104be48b806ad7e3ea8d1b 2023-01-09 16:01:26.684 Info Server: http/1.1 Response 204 to host4. Time: 1ms. http://host2:8096/emby/Sessions/Playing/Progress 2023-01-09 16:01:36.688 Info Server: http/1.1 POST http://host2:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 16:01:36.689 Debug SessionManager: OnPlaybackProgress TimeUpdate 0be5adc28b104be48b806ad7e3ea8d1b 2023-01-09 16:01:36.690 Info Server: http/1.1 Response 204 to host4. Time: 2ms. http://host2:8096/emby/Sessions/Playing/Progress 2023-01-09 16:01:46.687 Info Server: http/1.1 POST http://host2:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 16:01:46.688 Debug SessionManager: OnPlaybackProgress TimeUpdate 0be5adc28b104be48b806ad7e3ea8d1b 2023-01-09 16:01:46.720 Info Server: http/1.1 Response 204 to host4. Time: 33ms. http://host2:8096/emby/Sessions/Playing/Progress 2023-01-09 16:01:47.363 Info Server: http/1.1 POST http://host2:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 16:01:47.364 Debug SessionManager: OnPlaybackProgress Pause 0be5adc28b104be48b806ad7e3ea8d1b ================ 2023-01-09 16:01:47.365 Info Phillips Hue: Phillips Hue Reports Playback Paused... 2023-01-09 16:01:47.365 Info Phillips Hue: Phillips Hue Found Session Device: SHIELD 2023-01-09 16:01:47.365 Info HttpClient: PUT http://192.168.1.137/api/hkPKJ1tC3iIi1FwloUYOEwzinIjXlUH-pUatR96S/groups/0/action 2023-01-09 16:01:47.365 Info Phillips Hue: Phillips Hue Reports Scene Trigger Success ================ # this is the initial pause 2023-01-09 16:01:47.365 Info Server: http/1.1 Response 204 to host4. Time: 2ms. http://host2:8096/emby/Sessions/Playing/Progress 2023-01-09 16:01:56.674 Info Server: http/1.1 POST http://host2:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 16:01:56.675 Debug SessionManager: OnPlaybackProgress TimeUpdate 0be5adc28b104be48b806ad7e3ea8d1b 2023-01-09 16:01:56.676 Info Server: http/1.1 Response 204 to host4. Time: 2ms. http://host2:8096/emby/Sessions/Playing/Progress 2023-01-09 16:02:06.682 Info Server: http/1.1 POST http://host2:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 16:02:06.683 Debug SessionManager: OnPlaybackProgress TimeUpdate 0be5adc28b104be48b806ad7e3ea8d1b 2023-01-09 16:02:06.683 Info Server: http/1.1 Response 204 to host4. Time: 2ms. http://host2:8096/emby/Sessions/Playing/Progress 2023-01-09 16:02:16.701 Info Server: http/1.1 POST http://host2:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 16:02:16.704 Debug SessionManager: OnPlaybackProgress TimeUpdate 0be5adc28b104be48b806ad7e3ea8d1b 2023-01-09 16:02:16.732 Info Server: http/1.1 Response 204 to host4. Time: 31ms. http://host2:8096/emby/Sessions/Playing/Progress 2023-01-09 16:02:26.690 Info Server: http/1.1 POST http://host2:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 16:02:26.751 Debug SessionManager: OnPlaybackProgress TimeUpdate 0be5adc28b104be48b806ad7e3ea8d1b 2023-01-09 16:02:26.778 Info Server: http/1.1 Response 204 to host4. Time: 88ms. http://host2:8096/emby/Sessions/Playing/Progress 2023-01-09 16:02:36.682 Info Server: http/1.1 POST http://host2:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 16:02:36.683 Debug SessionManager: OnPlaybackProgress TimeUpdate 0be5adc28b104be48b806ad7e3ea8d1b 2023-01-09 16:02:36.685 Info Server: http/1.1 Response 204 to host4. Time: 2ms. http://host2:8096/emby/Sessions/Playing/Progress 2023-01-09 16:02:46.710 Info Server: http/1.1 POST http://host2:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 16:02:46.711 Debug SessionManager: OnPlaybackProgress TimeUpdate 0be5adc28b104be48b806ad7e3ea8d1b 2023-01-09 16:02:46.727 Info Server: http/1.1 Response 204 to host4. Time: 18ms. http://host2:8096/emby/Sessions/Playing/Progress 2023-01-09 16:02:56.713 Info Server: http/1.1 POST http://host2:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 16:02:56.714 Debug SessionManager: OnPlaybackProgress TimeUpdate 0be5adc28b104be48b806ad7e3ea8d1b 2023-01-09 16:02:56.742 Info Server: http/1.1 Response 204 to host4. Time: 29ms. http://host2:8096/emby/Sessions/Playing/Progress 2023-01-09 16:03:06.715 Info Server: http/1.1 POST http://host2:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 16:03:06.716 Debug SessionManager: OnPlaybackProgress TimeUpdate 0be5adc28b104be48b806ad7e3ea8d1b 2023-01-09 16:03:06.742 Info Server: http/1.1 Response 204 to host4. Time: 27ms. http://host2:8096/emby/Sessions/Playing/Progress 2023-01-09 16:03:16.696 Info Server: http/1.1 POST http://host2:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 16:03:16.697 Debug SessionManager: OnPlaybackProgress TimeUpdate 0be5adc28b104be48b806ad7e3ea8d1b 2023-01-09 16:03:16.698 Info Server: http/1.1 Response 204 to host4. Time: 2ms. http://host2:8096/emby/Sessions/Playing/Progress 2023-01-09 16:03:26.683 Info Server: http/1.1 POST http://host2:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 16:03:26.684 Debug SessionManager: OnPlaybackProgress TimeUpdate 0be5adc28b104be48b806ad7e3ea8d1b 2023-01-09 16:03:26.685 Info Server: http/1.1 Response 204 to host4. Time: 1ms. http://host2:8096/emby/Sessions/Playing/Progress 2023-01-09 16:03:36.700 Info Server: http/1.1 POST http://host2:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 16:03:36.701 Debug SessionManager: OnPlaybackProgress TimeUpdate 0be5adc28b104be48b806ad7e3ea8d1b 2023-01-09 16:03:36.702 Info Server: http/1.1 Response 204 to host4. Time: 2ms. http://host2:8096/emby/Sessions/Playing/Progress 2023-01-09 16:03:46.717 Info Server: http/1.1 POST http://host2:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 16:03:46.718 Debug SessionManager: OnPlaybackProgress TimeUpdate 0be5adc28b104be48b806ad7e3ea8d1b 2023-01-09 16:03:46.718 Info Server: http/1.1 Response 204 to host4. Time: 2ms. http://host2:8096/emby/Sessions/Playing/Progress 2023-01-09 16:03:56.693 Info Server: http/1.1 POST http://host2:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 16:03:56.694 Debug SessionManager: OnPlaybackProgress TimeUpdate 0be5adc28b104be48b806ad7e3ea8d1b 2023-01-09 16:03:56.695 Info Server: http/1.1 Response 204 to host4. Time: 2ms. http://host2:8096/emby/Sessions/Playing/Progress 2023-01-09 16:04:03.345 Info Server: http/1.1 POST http://host2:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 16:04:03.346 Debug SessionManager: OnPlaybackProgress TimeUpdate 0be5adc28b104be48b806ad7e3ea8d1b ================ 2023-01-09 16:04:03.347 Info Phillips Hue: Phillips Hue Reports Playback UnPaused... 2023-01-09 16:04:03.347 Info Phillips Hue: Phillips Hue Found Profile Device: SHIELD 2023-01-09 16:04:03.347 Info Phillips Hue: Phillips Hue Reports Episode will trigger Playback UnPaused Scene for SHIELD 2023-01-09 16:04:03.347 Info HttpClient: PUT http://192.168.1.137/api/hkPKJ1tC3iIi1FwloUYOEwzinIjXlUH-pUatR96S/groups/0/action 2023-01-09 16:04:03.347 Info Phillips Hue: Phillips Hue Reports Scene Trigger Success 2023-01-09 16:04:03.347 Info Server: http/1.1 Response 204 to host4. Time: 2ms. http://host2:8096/emby/Sessions/Playing/Progress 2023-01-09 16:04:03.367 Info Server: http/1.1 POST http://host2:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 16:04:03.368 Debug SessionManager: OnPlaybackProgress Unpause 0be5adc28b104be48b806ad7e3ea8d1b 2023-01-09 16:04:03.369 Info Phillips Hue: Phillips Hue Reports Playback Paused... 2023-01-09 16:04:03.369 Info Phillips Hue: Phillips Hue Found Session Device: SHIELD 2023-01-09 16:04:03.369 Info HttpClient: PUT http://192.168.1.137/api/hkPKJ1tC3iIi1FwloUYOEwzinIjXlUH-pUatR96S/groups/0/action 2023-01-09 16:04:03.369 Info Phillips Hue: Phillips Hue Reports Scene Trigger Success ================ # this is where I unpaused it after 2 minutes, it seems there is an almost instant pause retrigger though.... then 10 seconds later: 2023-01-09 16:04:03.369 Info Server: http/1.1 Response 204 to host4. Time: 1ms. http://host2:8096/emby/Sessions/Playing/Progress 2023-01-09 16:04:13.374 Info Server: http/1.1 POST http://host2:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 16:04:13.375 Debug SessionManager: OnPlaybackProgress TimeUpdate 0be5adc28b104be48b806ad7e3ea8d1b 2023-01-09 16:04:13.375 Info Phillips Hue: Phillips Hue Reports Playback UnPaused... 2023-01-09 16:04:13.375 Info Phillips Hue: Phillips Hue Found Profile Device: SHIELD 2023-01-09 16:04:13.375 Info Phillips Hue: Phillips Hue Reports Episode will trigger Playback UnPaused Scene for SHIELD 2023-01-09 16:04:13.375 Info HttpClient: PUT http://192.168.1.137/api/hkPKJ1tC3iIi1FwloUYOEwzinIjXlUH-pUatR96S/groups/0/action 2023-01-09 16:04:13.376 Info Phillips Hue: Phillips Hue Reports Scene Trigger Success ================ # this triggers the lights normal behaviour. Will include rest of logs below in case of anything relevant 2023-01-09 16:04:13.376 Info Server: http/1.1 Response 204 to host4. Time: 2ms. http://host2:8096/emby/Sessions/Playing/Progress 2023-01-09 16:04:18.692 Info Server: http/1.1 Response 206 to host4. Time: 292711ms. http://host2:8096/emby/videos/5234/stream.mkv?DeviceId=517e14e6137dade6&MediaSourceId=c40969d85ccc6c823ea211544f9df80d&Static=true&PlaySessionId=0be5adc28b104be48b806ad7e3ea8d1b 2023-01-09 16:04:18.814 Info Server: http/1.1 POST http://host2:8096/emby/Sessions/Playing/Stopped. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 16:04:18.815 Debug App: ReportPlaybackStopped PlaySessionId: 0be5adc28b104be48b806ad7e3ea8d1b 2023-01-09 16:04:18.815 Info SessionManager: Playback stopped reported by app AndroidTv 2.0.83g playing Playtime. Stopped at 1387293 ms 2023-01-09 16:04:18.815 Debug App: InfuseSync received user data for item 'Playtime' of type 'Episode' Guid 'c40969d8-5ccc-6c82-3ea2-11544f9df80d' ItemID '5234' 2023-01-09 16:04:18.815 Debug App: InfuseSync will save user data for item c40969d8-5ccc-6c82-3ea2-11544f9df80d user 2e5ed6b0-ef64-4d22-ae91-0356dc7d06c1 2023-01-09 16:04:18.815 Info Phillips Hue: Phillips Hue Reports Playback Stopped 2023-01-09 16:04:18.815 Info Phillips Hue: Phillips Hue Found Profile Device: SHIELD 2023-01-09 16:04:18.815 Info Phillips Hue: Phillips Hue Reports Episode will trigger Playback Stopped Scene on SHIELD 2023-01-09 16:04:18.815 Info Server: http/1.1 Response 204 to host4. Time: 1ms. http://host2:8096/emby/Sessions/Playing/Stopped 2023-01-09 16:04:18.815 Info HttpClient: PUT http://192.168.1.137/api/hkPKJ1tC3iIi1FwloUYOEwzinIjXlUH-pUatR96S/groups/0/action 2023-01-09 16:04:18.815 Info Phillips Hue: Phillips Hue Reports Scene Trigger Success 2023-01-09 16:04:18.836 Debug Server: http/1.1 GET http://host2:8096/emby/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Items/5234?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; SHIELD Android TV Build/RQ1A.210105.003) 2023-01-09 16:04:18.838 Debug SqliteItemRepository: Public GetItemLinks 2023-01-09 16:04:18.839 Debug Server: http/1.1 Response 200 to host4. Time: 3ms. http://host2:8096/emby/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Items/5234?format=json 2023-01-09 16:04:48.366 Debug Server: http/1.1 GET http://host2:8096/emby/system/info/public. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 Edg/108.0.1462.54 2023-01-09 16:04:48.367 Debug Server: http/1.1 Response 200 to host5. Time: 0ms. http://host2:8096/emby/system/info/public 2023-01-09 16:04:48.374 Debug Server: http/1.1 GET http://host2:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 Edg/108.0.1462.54 2023-01-09 16:04:48.439 Debug Server: http/1.1 Response 200 to host5. Time: 65ms. http://host2:8096/emby/System/Info 2023-01-09 16:04:48.443 Debug Server: http/1.1 GET http://host2:8096/emby/DisplayPreferences/usersettings?userId=2e5ed6b0ef644d22ae910356dc7d06c1&client=emby&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=7e251541-4000-4ef4-8e3d-00a669153f5e&X-Emby-Client-Version=4.7.11.0&X-Emby-Language=en-gb. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 Edg/108.0.1462.54 2023-01-09 16:04:48.444 Debug Server: http/1.1 Response 200 to host5. Time: 1ms. http://host2:8096/emby/DisplayPreferences/usersettings?userId=2e5ed6b0ef644d22ae910356dc7d06c1&client=emby&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=7e251541-4000-4ef4-8e3d-00a669153f5e&X-Emby-Client-Version=4.7.11.0&X-Emby-Language=en-gb 2023-01-09 16:04:48.489 Info Server: http/1.1 POST http://host2:8096/emby/Sessions/Capabilities/Full?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=7e251541-4000-4ef4-8e3d-00a669153f5e&X-Emby-Client-Version=4.7.11.0&X-Emby-Language=en-gb&reqformat=json. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 Edg/108.0.1462.54 2023-01-09 16:04:48.490 Debug AuthenticationRepository: UpdateCapabilities id: 23 2023-01-09 16:04:48.491 Info Server: http/1.1 Response 204 to host5. Time: 1ms. http://host2:8096/emby/Sessions/Capabilities/Full?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=7e251541-4000-4ef4-8e3d-00a669153f5e&X-Emby-Client-Version=4.7.11.0&X-Emby-Language=en-gb&reqformat=json 2023-01-09 16:04:48.496 Debug Server: http/1.1 GET http://host2:8096/emby/Users/2e5ed6b0ef644d22ae910356dc7d06c1?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=7e251541-4000-4ef4-8e3d-00a669153f5e&X-Emby-Client-Version=4.7.11.0&X-Emby-Language=en-gb. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 Edg/108.0.1462.54 2023-01-09 16:04:48.497 Debug Server: http/1.1 Response 200 to host5. Time: 1ms. http://host2:8096/emby/Users/2e5ed6b0ef644d22ae910356dc7d06c1?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=7e251541-4000-4ef4-8e3d-00a669153f5e&X-Emby-Client-Version=4.7.11.0&X-Emby-Language=en-gb 2023-01-09 16:04:48.500 Debug Server: http/1.1 GET http://host2:8096/emby/Users/2e5ed6b0ef644d22ae910356dc7d06c1?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=7e251541-4000-4ef4-8e3d-00a669153f5e&X-Emby-Client-Version=4.7.11.0&X-Emby-Language=en-gb. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 Edg/108.0.1462.54 2023-01-09 16:04:48.500 Debug Server: http/1.1 Response 200 to host5. Time: 1ms. http://host2:8096/emby/Users/2e5ed6b0ef644d22ae910356dc7d06c1?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=7e251541-4000-4ef4-8e3d-00a669153f5e&X-Emby-Client-Version=4.7.11.0&X-Emby-Language=en-gb 2023-01-09 16:04:48.524 Debug Server: http/1.1 GET http://host2:8096/emby/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Views?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=7e251541-4000-4ef4-8e3d-00a669153f5e&X-Emby-Client-Version=4.7.11.0&X-Emby-Language=en-gb. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 Edg/108.0.1462.54 2023-01-09 16:04:48.524 Debug Server: http/1.1 GET http://host2:8096/emby/System/Configuration?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=7e251541-4000-4ef4-8e3d-00a669153f5e&X-Emby-Client-Version=4.7.11.0&X-Emby-Language=en-gb. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 Edg/108.0.1462.54 2023-01-09 16:04:48.525 Debug Server: http/1.1 GET http://host2:8096/emby/System/Logs/Query?SortBy=SortName&SortOrder=Ascending&Fields=BasicSyncInfo,CanDelete,Container,PrimaryImageAspectRatio,ProductionYear,Status,EndDate,CommunityRating,OfficialRating,CriticRating&StartIndex=0&EnableImageTypes=Primary,Backdrop,Thumb&ImageTypeLimit=1&Limit=30&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=7e251541-4000-4ef4-8e3d-00a669153f5e&X-Emby-Client-Version=4.7.11.0&X-Emby-Language=en-gb. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 Edg/108.0.1462.54 2023-01-09 16:04:48.525 Debug Server: http/1.1 GET http://host2:8096/emby/web/configurationpages?PageType=PluginConfiguration&UserId=2e5ed6b0ef644d22ae910356dc7d06c1&EnableInMainMenu=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=7e251541-4000-4ef4-8e3d-00a669153f5e&X-Emby-Client-Version=4.7.11.0&X-Emby-Language=en-gb. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 Edg/108.0.1462.54 2023-01-09 16:04:48.526 Debug Server: http/1.1 Response 200 to host5. Time: 1ms. http://host2:8096/emby/web/configurationpages?PageType=PluginConfiguration&UserId=2e5ed6b0ef644d22ae910356dc7d06c1&EnableInMainMenu=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=7e251541-4000-4ef4-8e3d-00a669153f5e&X-Emby-Client-Version=4.7.11.0&X-Emby-Language=en-gb 2023-01-09 16:04:48.526 Debug Server: http/1.1 Response 200 to host5. Time: 1ms. http://host2:8096/emby/System/Logs/Query?SortBy=SortName&SortOrder=Ascending&Fields=BasicSyncInfo,CanDelete,Container,PrimaryImageAspectRatio,ProductionYear,Status,EndDate,CommunityRating,OfficialRating,CriticRating&StartIndex=0&EnableImageTypes=Primary,Backdrop,Thumb&ImageTypeLimit=1&Limit=30&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=7e251541-4000-4ef4-8e3d-00a669153f5e&X-Emby-Client-Version=4.7.11.0&X-Emby-Language=en-gb 2023-01-09 16:04:48.526 Debug Server: http/1.1 Response 200 to host5. Time: 2ms. http://host2:8096/emby/Users/2e5ed6b0ef644d22ae910356dc7d06c1/Views?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=7e251541-4000-4ef4-8e3d-00a669153f5e&X-Emby-Client-Version=4.7.11.0&X-Emby-Language=en-gb 2023-01-09 16:04:48.526 Debug Server: http/1.1 Response 200 to host5. Time: 2ms. http://host2:8096/emby/System/Configuration?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=7e251541-4000-4ef4-8e3d-00a669153f5e&X-Emby-Client-Version=4.7.11.0&X-Emby-Language=en-gb 2023-01-09 16:04:55.921 Debug Server: http/1.1 GET http://host2:8096/emby/System/Logs/embyserver.txt/Lines?SortBy=SortName&SortOrder=Ascending&Fields=BasicSyncInfo,CanDelete,Container,PrimaryImageAspectRatio,ProductionYear,Status,EndDate,CommunityRating,OfficialRating,CriticRating&StartIndex=0&EnableImageTypes=Primary,Backdrop,Thumb&ImageTypeLimit=1&Sanitize=true&Limit=100&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=7e251541-4000-4ef4-8e3d-00a669153f5e&X-Emby-Client-Version=4.7.11.0&X-Emby-Language=en-gb. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 Edg/108.0.1462.54 This is my logs from running it. It looks like when I unpause it there is a pause command almost immediately after, and then it unpauses it again 10 seconds later? Edited January 9, 2023 by AsheAshe
AsheAshe 8 Posted January 9, 2023 Posted January 9, 2023 50 minutes ago, BillOatman said: I have some code ready for this that I should get to the owner to look at and release today or tomorrow. Great, thankyou! v
