BillOatman 597 Posted December 1, 2020 Author Posted December 1, 2020 (edited) @chefMight not need to be higher. In fact might not be needed at all after swapping those 2 statements. I'll try this one out tonight and test it without the delay as well when I can. I have a old V1 hub though. The only reason I know that is Philips crippled it in April. It can't connect to the Philips server and won't get any more updates. Still works locally though (or so they say, I'll check tonight ). I was very annoyed when I noticed the globe led (internet) was blinking and spent an hour Fing with it until I saw a post about Philips doing that. Edited December 1, 2020 by BillOatman 1
altairr 16 Posted December 1, 2020 Posted December 1, 2020 15 hours ago, chef said: I'd love to know if the new version in the catalogue fixes the issue. Sadly it doesn't seem to fix it. Here is a short video with the latest version of the plug-in to illustrate perhaps more clearly the problem. VID_20201201_203450.mp4 1
chef 3811 Posted December 1, 2020 Posted December 1, 2020 3 hours ago, BillOatman said: @chefMight not need to be higher. In fact might not be needed at all after swapping those 2 statements. I'll try this one out tonight and test it without the delay as well when I can. I have a old V1 hub though. The only reason I know that is Philips crippled it in April. It can't connect to the Philips server and won't get any more updates. Still works locally though (or so they say, I'll check tonight ). I was very annoyed when I noticed the globe led (internet) was blinking and spent an hour Fing with it until I saw a post about Philips doing that. Seem like it does need to be higher. Should we test 1000? Or higher?
BillOatman 597 Posted December 1, 2020 Author Posted December 1, 2020 34 minutes ago, chef said: Seem like it does need to be higher. Should we test 1000? Or higher? What do you have now, 150ms? I'd crank it up to a second like you are suggesting. If that doesn't take care of it then what we are thinking is happening, probably isn't. 1
chef 3811 Posted December 1, 2020 Posted December 1, 2020 4 minutes ago, BillOatman said: What do you have now, 150ms? I'd crank it up to a second like you are suggesting. If that doesn't take care of it then what we are thinking is happening, probably isn't. Will do! Could also be rouge session IDs in the paused list... Should probably check that too. If all else fails, we could probably use a boolean. 1
BillOatman 597 Posted December 2, 2020 Author Posted December 2, 2020 (edited) @chefYou are using Task.Delay() but not asynchronously. Not sure if that is even delaying at all the way you have it. This link explains the difference between that task delay and sleeping the thread including sample code using it asynchronously. I think you want to use Sleep() here. This if (PausedSessionsIds.Exists(s => s.Equals(e.Session.Id))) { PausedSessionsIds.RemoveAll(s => s.Equals(e.Session.Id)); Task.Delay(150); PlaybackUnPaused(e, config, config.SavedHueEmbyProfiles.FirstOrDefault(p => p.DeviceName.Equals(e.Session.DeviceName))); } To if (PausedSessionsIds.Exists(s => s.Equals(e.Session.Id))) { PausedSessionsIds.RemoveAll(s => s.Equals(e.Session.Id)); System.Threading.Thread.Sleep(1000); PlaybackUnPaused(e, config, config.SavedHueEmbyProfiles.FirstOrDefault(p => p.DeviceName.Equals(e.Session.DeviceName))); } Edited December 2, 2020 by BillOatman 1
BillOatman 597 Posted December 4, 2020 Author Posted December 4, 2020 Hey @chefI think I noticed the plugin updated yesterday but didn't get a chance to test it. Should @altairr test it out? 1
chef 3811 Posted December 4, 2020 Posted December 4, 2020 1 minute ago, BillOatman said: Hey @chefI think I noticed the plugin updated yesterday but didn't get a chance to test it. Should @altairr test it out? Yes, it was late when I finally got to the change. We should definitely see if changing the task delay fixes anything.
BillOatman 597 Posted December 4, 2020 Author Posted December 4, 2020 If you check in the code I can play with it this weekend if it still doesn't work. 1
altairr 16 Posted December 6, 2020 Posted December 6, 2020 On 04/12/2020 at 15:04, chef said: Yes, it was late when I finally got to the change. We should definitely see if changing the task delay fixes anything. I did some tests last night and it doesn't seem to fix the issue. I do get the impression that it occurs less frequently but I can't confirm yet. I'll try to test more thoroughly in the next few days. I'll keep you posted! 1
chef 3811 Posted December 7, 2020 Posted December 7, 2020 12 hours ago, altairr said: I did some tests last night and it doesn't seem to fix the issue. I do get the impression that it occurs less frequently but I can't confirm yet. I'll try to test more thoroughly in the next few days. I'll keep you posted! Sorry for the late reply here. I can up the threshold on task.delay if it isn't work properly. looking forward to hearing back 2
altairr 16 Posted December 8, 2020 Posted December 8, 2020 Not sure what changed but it definetly didn't fixed the issue and I actually don't believe the frequency changed. In the log below, I unpaused a video, the lights switched rapidly but kept the paused scene although the video was still playing and after a few seconds the lights switched to the unpaused scene. 2020-12-09 00:06:27.079 Info Phillips Hue: Phillips Hue Reports Playback UnPaused... 2020-12-09 00:06:27.079 Info Phillips Hue: Phillips Hue Found Profile Device: SHIELD 2020-12-09 00:06:27.080 Info Phillips Hue: Phillips Hue Reports Episode will trigger Playback UnPaused Scene for SHIELD 2020-12-09 00:06:27.080 Info HttpClient: PUT http://192.168.1.230/api/yd7yxGuGVpPrazao7uVP0DAZ7Zlyq1sPZARtOZrr/groups/0/action 2020-12-09 00:06:27.080 Info Phillips Hue: Phillips Hue Reports Scene Trigger Success 2020-12-09 00:06:27.080 Info Server: http/1.1 Response 204 to 192.168.1.145. Time: 3ms. http://192.168.1.239:8096/emby/Sessions/Playing/Progress 2020-12-09 00:06:27.103 Info Server: http/1.1 POST http://192.168.1.239:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-12-09 00:06:27.105 Info Phillips Hue: Phillips Hue Reports Playback Paused... 2020-12-09 00:06:27.105 Info Phillips Hue: Phillips Hue Found Session Device: SHIELD 2020-12-09 00:06:27.105 Info HttpClient: PUT http://192.168.1.230/api/yd7yxGuGVpPrazao7uVP0DAZ7Zlyq1sPZARtOZrr/groups/0/action 2020-12-09 00:06:27.105 Info Phillips Hue: Phillips Hue Reports Scene Trigger Success 2020-12-09 00:06:27.105 Info Server: http/1.1 Response 204 to 192.168.1.145. Time: 3ms. http://192.168.1.239:8096/emby/Sessions/Playing/Progress 2020-12-09 00:06:37.113 Info Server: http/1.1 POST http://192.168.1.239:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-12-09 00:06:37.115 Info Phillips Hue: Phillips Hue Reports Playback UnPaused... 2020-12-09 00:06:37.115 Info Phillips Hue: Phillips Hue Found Profile Device: SHIELD 2020-12-09 00:06:37.115 Info Phillips Hue: Phillips Hue Reports Episode will trigger Playback UnPaused Scene for SHIELD 2020-12-09 00:06:37.115 Info HttpClient: PUT http://192.168.1.230/api/yd7yxGuGVpPrazao7uVP0DAZ7Zlyq1sPZARtOZrr/groups/0/action 2020-12-09 00:06:37.115 Info Phillips Hue: Phillips Hue Reports Scene Trigger Success 2020-12-09 00:06:37.116 Info Server: http/1.1 Response 204 to 192.168.1.145. Time: 3ms. http://192.168.1.239:8096/emby/Sessions/Playing/Progress
chef 3811 Posted December 9, 2020 Posted December 9, 2020 Okay we need to task.Delay each of the events, and also the progressEventArgs. I'll post something tonight.
BillOatman 597 Posted December 10, 2020 Author Posted December 10, 2020 @altairrNot sure I understand that log. At 6:27 you unpaused, and you never touched the buttons again through the 6:37 events?
altairr 16 Posted December 10, 2020 Posted December 10, 2020 (edited) 18 minutes ago, BillOatman said: @altairrNot sure I understand that log. At 6:27 you unpaused, and you never touched the buttons again through the 6:37 events? That's right, I didn't press a single button after I unpaused the video. The video I posted the other day illustrates that behavior. Btw I reinstalled my Emby server to the latest stable version (4.5.3.0), I'll test tonight if the issue persists. Edited December 10, 2020 by altairr
BillOatman 597 Posted December 10, 2020 Author Posted December 10, 2020 2 hours ago, altairr said: That's right, I didn't press a single button after I unpaused the video. The video I posted the other day illustrates that behavior. Btw I reinstalled my Emby server to the latest stable version (4.5.3.0), I'll test tonight if the issue persists. Yeah @chefI don't get how this is a delay resolved issue, but I trust you
altairr 16 Posted December 10, 2020 Posted December 10, 2020 Watched some content tonight using the stable version of emby server and same result as the beta.. If it's only me having the problem perhaps some network issues even though everything is on my lan? Can anyone else reproduce the issue?
chef 3811 Posted December 11, 2020 Posted December 11, 2020 10 minutes ago, altairr said: Watched some content tonight using the stable version of emby server and same result as the beta.. If it's only me having the problem perhaps some network issues even though everything is on my lan? Can anyone else reproduce the issue? I don't think it is only you. I think Bill and I both can't test it because we don't have the hardware. That being said, if it is happening in your setup it is most likely happening in all the setups, but the plugin might not be in wide use. I have time tomorrow to work on this. We'll fix it, and appreciate your time here in this thread. 1
muppet4k 10 Posted December 23, 2020 Posted December 23, 2020 So Chef wie tested and no reply so I can’t understand that lights rooms are used in the hue plug-in like Philips it created in the app So make this Plugin no sense to be used
muppet4k 10 Posted December 23, 2020 Posted December 23, 2020 On 6/15/2020 at 9:02 PM, muppet4k said: so it updated the drop down list but i thought its at the end of the list, but its in the middle somewhere That he is dublicating the scenes is normal and your plugin works correct. Maybe one example for better understanding: First in the App is to create a room/zone: Than you can add the lights which do you want: And than you have some standart scenes from philips which you see double , three times and more in your drop down list. And also create some new Scene based on the room/zone. Alle (is the zone id in this example) Hope thats more clear about hue App working. Sorry that some scenes are in german to Add some extra data between the scenes would be nice, if itisnt difficult So nobody is using in this way ?
chef 3811 Posted December 23, 2020 Posted December 23, 2020 I've got the project open here. I'm going to figure it out today.
chef 3811 Posted December 23, 2020 Posted December 23, 2020 I've updated the plugin. Instead of relying on the progress event to tell us which session is paused, we now read the session through the session manager. There is also a delay before reading the next event. If you guys find that the delay causes the paused and unpaused commands to act unexpectedly. Let me know and they can be removed. They're pretty much there to slow down the progress event on the plugin thread, and only last one second. Version 1.1.0.4 in the catalog. 1
BillOatman 597 Posted December 24, 2020 Author Posted December 24, 2020 @chef I just tested it out. It worked pretty well, but not perfect, form movies. It works badly for TV Series. This section of the log was when I unpaused a TV series, but the light is still in paused state 5 minutes later. 2020-12-24 10:52:37.136 Info Phillips Hue: Phillips Hue Reports Playback Paused... 2020-12-24 10:52:37.136 Info Phillips Hue: Phillips Hue Found Session Device: LivingRoom 2020-12-24 10:52:37.136 Info HttpClient: PUT http://192.168.1.228/api/PNJLwkFvcxtvRIvDhbFvBPGmHJ-XhL97txhL6RgM/groups/0/action 2020-12-24 10:52:37.138 Info Phillips Hue: Phillips Hue Reports Scene Trigger Success 2020-12-24 10:52:37.138 Info Server: http/1.1 Response 204 to 192.168.1.40. Time: 4ms. http://192.168.1.42:8096/emby/Sessions/Playing/Progress 2020-12-24 10:52:46.112 Info Server: http/1.1 POST http://192.168.1.42:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-12-24 10:52:46.115 Info Server: http/1.1 Response 204 to 192.168.1.40. Time: 3ms. http://192.168.1.42:8096/emby/Sessions/Playing/Progress 2020-12-24 10:52:51.686 Info Server: http/1.1 POST http://192.168.1.42:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-12-24 10:52:51.686 Info Server: http/1.1 Response 204 to 192.168.1.40. Time: 1ms. http://192.168.1.42:8096/emby/Sessions/Playing/Progress 2020-12-24 10:52:51.695 Info Server: http/1.1 POST http://192.168.1.42:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-12-24 10:52:51.696 Info Phillips Hue: Phillips Hue Reports Playback UnPaused... 2020-12-24 10:52:51.696 Info Phillips Hue: Phillips Hue Found Profile Device: LivingRoom 2020-12-24 10:52:51.696 Info Phillips Hue: Phillips Hue Reports Episode will trigger Playback UnPaused Scene for LivingRoom 2020-12-24 10:52:51.696 Info HttpClient: PUT http://192.168.1.228/api/PNJLwkFvcxtvRIvDhbFvBPGmHJ-XhL97txhL6RgM/groups/0/action 2020-12-24 10:52:51.696 Info Phillips Hue: Phillips Hue Reports Scene Trigger Success 2020-12-24 10:52:51.696 Info Server: http/1.1 Response 204 to 192.168.1.40. Time: 1ms. http://192.168.1.42:8096/emby/Sessions/Playing/Progress 2020-12-24 10:53:01.675 Info Server: http/1.1 POST http://192.168.1.42:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-12-24 10:53:01.677 Info Server: http/1.1 Response 204 to 192.168.1.40. Time: 3ms. http://192.168.1.42:8096/emby/Sessions/Playing/Progress 2020-12-24 10:53:11.699 Info Server: http/1.1 POST http://192.168.1.42:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-12-24 10:53:11.702 Info Server: http/1.1 Response 204 to 192.168.1.40. Time: 3ms. http://192.168.1.42:8096/emby/Sessions/Playing/Progress 2020-12-24 10:53:21.718 Info Server: http/1.1 POST http://192.168.1.42:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-12-24 10:53:21.721 Info Server: http/1.1 Response 204 to 192.168.1.40. Time: 3ms. http://192.168.1.42:8096/emby/Sessions/Playing/Progress 2020-12-24 10:53:28.888 Info Server: http/1.1 GET http://localhost:8096/emby/Users/d063f08a14564602852a2d932adf2d23?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY5LjAuMzQ5Ny4xMDAgU2FmYXJpLzUzNy4zNnwxNTQwMDYxNDYxNTEw&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-24 10:53:28.889 Info Server: http/1.1 Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/Users/d063f08a14564602852a2d932adf2d23?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY5LjAuMzQ5Ny4xMDAgU2FmYXJpLzUzNy4zNnwxNTQwMDYxNDYxNTEw&X-Emby-Client-Version=4.5.4.0 2020-12-24 10:53:29.022 Info Server: http/1.1 GET http://localhost:8096/emby/System/Configuration?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY5LjAuMzQ5Ny4xMDAgU2FmYXJpLzUzNy4zNnwxNTQwMDYxNDYxNTEw&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-24 10:53:29.027 Info Server: http/1.1 GET http://localhost:8096/emby/System/Logs?SortBy=IsFolder,SortName&SortOrder=Ascending&Fields=BasicSyncInfo,CanDelete&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&StartIndex=0&Limit=50&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY5LjAuMzQ5Ny4xMDAgU2FmYXJpLzUzNy4zNnwxNTQwMDYxNDYxNTEw&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-24 10:53:29.029 Info Server: http/1.1 Response 200 to ::1. Time: 2ms. http://localhost:8096/emby/System/Logs?SortBy=IsFolder,SortName&SortOrder=Ascending&Fields=BasicSyncInfo,CanDelete&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&StartIndex=0&Limit=50&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY5LjAuMzQ5Ny4xMDAgU2FmYXJpLzUzNy4zNnwxNTQwMDYxNDYxNTEw&X-Emby-Client-Version=4.5.4.0 2020-12-24 10:53:29.029 Info Server: http/1.1 Response 200 to ::1. Time: 7ms. http://localhost:8096/emby/System/Configuration?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY5LjAuMzQ5Ny4xMDAgU2FmYXJpLzUzNy4zNnwxNTQwMDYxNDYxNTEw&X-Emby-Client-Version=4.5.4.0 2020-12-24 10:53:31.716 Info Server: http/1.1 POST http://192.168.1.42:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-12-24 10:53:31.719 Info Server: http/1.1 Response 204 to 192.168.1.40. Time: 3ms. http://192.168.1.42:8096/emby/Sessions/Playing/Progress 2020-12-24 10:53:41.732 Info Server: http/1.1 POST http://192.168.1.42:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-12-24 10:53:41.735 Info Server: http/1.1 Response 204 to 192.168.1.40. Time: 2ms. http://192.168.1.42:8096/emby/Sessions/Playing/Progress 2020-12-24 10:53:43.217 Info Server: http/1.1 GET http://localhost:8096/emby/System/Logs/embyserver.txt. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 Sometimes for movies when you unpause it takes 10-20 seconds for the scene to actually run, but it does get there eventually This is the log after I stopped the TV series above. The light is still in its paused state. 2020-12-24 11:01:23.813 Info Server: http/1.1 POST http://192.168.1.42:8096/emby/Sessions/Playing/Stopped. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-12-24 11:01:23.814 Info SessionManager: Playback stopped reported by app AndroidTv 1.8.54g playing Who is Anonymous?. Stopped at 565748 ms 2020-12-24 11:01:23.815 Info Server: http/1.1 Response 204 to 192.168.1.40. Time: 1ms. http://192.168.1.42:8096/emby/Sessions/Playing/Stopped 2020-12-24 11:01:23.815 Info Phillips Hue: Phillips Hue Reports Playback Stopped 2020-12-24 11:01:23.815 Info Phillips Hue: Phillips Hue Found Profile Device: LivingRoom 2020-12-24 11:01:23.815 Info Phillips Hue: Phillips Hue Reports Episode will trigger Playback Stopped Scene on LivingRoom 2020-12-24 11:01:23.815 Info HttpClient: PUT http://192.168.1.228/api/PNJLwkFvcxtvRIvDhbFvBPGmHJ-XhL97txhL6RgM/groups/0/action 2020-12-24 11:01:23.816 Info Phillips Hue: Phillips Hue Reports Scene Trigger Success 2020-12-24 11:01:24.448 Info Server: http/1.1 GET http://192.168.1.42:8096/emby/Users/d063f08a14564602852a2d932adf2d23/Items/1132?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-12-24 11:01:24.449 Info Server: http/1.1 GET http://192.168.1.42:8096/emby/Users/d063f08a14564602852a2d932adf2d23/Items/1133?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-12-24 11:01:24.456 Info Server: http/1.1 Response 200 to 192.168.1.40. Time: 8ms. http://192.168.1.42:8096/emby/Users/d063f08a14564602852a2d932adf2d23/Items/1132?format=json 2020-12-24 11:01:24.456 Info Server: http/1.1 Response 200 to 192.168.1.40. Time: 8ms. http://192.168.1.42:8096/emby/Users/d063f08a14564602852a2d932adf2d23/Items/1133?format=json 2020-12-24 11:01:24.500 Info Server: http/1.1 GET http://192.168.1.42:8096/emby/Shows/NextUp?Fields=PrimaryImageAspectRatio%2CLocationType&SeriesId=1133&UserId=d063f08a14564602852a2d932adf2d23&EnableTotalRecordCount=false&format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-12-24 11:01:24.505 Info Server: http/1.1 Response 200 to 192.168.1.40. Time: 5ms. http://192.168.1.42:8096/emby/Shows/NextUp?Fields=PrimaryImageAspectRatio%2CLocationType&SeriesId=1133&UserId=d063f08a14564602852a2d932adf2d23&EnableTotalRecordCount=false&format=json 2020-12-24 11:02:01.731 Info Server: http/1.1 GET http://localhost:8096/emby/Users/d063f08a14564602852a2d932adf2d23?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY5LjAuMzQ5Ny4xMDAgU2FmYXJpLzUzNy4zNnwxNTQwMDYxNDYxNTEw&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-24 11:02:01.732 Info Server: http/1.1 Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/Users/d063f08a14564602852a2d932adf2d23?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY5LjAuMzQ5Ny4xMDAgU2FmYXJpLzUzNy4zNnwxNTQwMDYxNDYxNTEw&X-Emby-Client-Version=4.5.4.0 2020-12-24 11:02:01.865 Info Server: http/1.1 GET http://localhost:8096/emby/Notifications/Types?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY5LjAuMzQ5Ny4xMDAgU2FmYXJpLzUzNy4zNnwxNTQwMDYxNDYxNTEw&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-24 11:02:01.867 Info Server: http/1.1 Response 200 to ::1. Time: 2ms. http://localhost:8096/emby/Notifications/Types?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY5LjAuMzQ5Ny4xMDAgU2FmYXJpLzUzNy4zNnwxNTQwMDYxNDYxNTEw&X-Emby-Client-Version=4.5.4.0 2020-12-24 11:02:02.937 Info Server: http/1.1 GET http://localhost:8096/emby/System/Configuration?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY5LjAuMzQ5Ny4xMDAgU2FmYXJpLzUzNy4zNnwxNTQwMDYxNDYxNTEw&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-24 11:02:02.937 Info Server: http/1.1 Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/System/Configuration?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY5LjAuMzQ5Ny4xMDAgU2FmYXJpLzUzNy4zNnwxNTQwMDYxNDYxNTEw&X-Emby-Client-Version=4.5.4.0 2020-12-24 11:02:02.977 Info Server: http/1.1 GET http://localhost:8096/emby/System/Logs?SortBy=IsFolder,SortName&SortOrder=Ascending&Fields=BasicSyncInfo,CanDelete&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&StartIndex=0&Limit=50&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY5LjAuMzQ5Ny4xMDAgU2FmYXJpLzUzNy4zNnwxNTQwMDYxNDYxNTEw&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-24 11:02:02.979 Info Server: http/1.1 Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/System/Logs?SortBy=IsFolder,SortName&SortOrder=Ascending&Fields=BasicSyncInfo,CanDelete&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&StartIndex=0&Limit=50&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY5LjAuMzQ5Ny4xMDAgU2FmYXJpLzUzNy4zNnwxNTQwMDYxNDYxNTEw&X-Emby-Client-Version=4.5.4.0 2020-12-24 11:02:07.424 Info Server: http/1.1 GET http://localhost:8096/emby/System/Logs/embyserver.txt. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 If you want to post the source I can try and see whats wrong with it.
chef 3811 Posted December 25, 2020 Posted December 25, 2020 8 hours ago, BillOatman said: @chef I just tested it out. It worked pretty well, but not perfect, form movies. It works badly for TV Series. This section of the log was when I unpaused a TV series, but the light is still in paused state 5 minutes later. 2020-12-24 10:52:37.136 Info Phillips Hue: Phillips Hue Reports Playback Paused... 2020-12-24 10:52:37.136 Info Phillips Hue: Phillips Hue Found Session Device: LivingRoom 2020-12-24 10:52:37.136 Info HttpClient: PUT http://192.168.1.228/api/PNJLwkFvcxtvRIvDhbFvBPGmHJ-XhL97txhL6RgM/groups/0/action 2020-12-24 10:52:37.138 Info Phillips Hue: Phillips Hue Reports Scene Trigger Success 2020-12-24 10:52:37.138 Info Server: http/1.1 Response 204 to 192.168.1.40. Time: 4ms. http://192.168.1.42:8096/emby/Sessions/Playing/Progress 2020-12-24 10:52:46.112 Info Server: http/1.1 POST http://192.168.1.42:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-12-24 10:52:46.115 Info Server: http/1.1 Response 204 to 192.168.1.40. Time: 3ms. http://192.168.1.42:8096/emby/Sessions/Playing/Progress 2020-12-24 10:52:51.686 Info Server: http/1.1 POST http://192.168.1.42:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-12-24 10:52:51.686 Info Server: http/1.1 Response 204 to 192.168.1.40. Time: 1ms. http://192.168.1.42:8096/emby/Sessions/Playing/Progress 2020-12-24 10:52:51.695 Info Server: http/1.1 POST http://192.168.1.42:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-12-24 10:52:51.696 Info Phillips Hue: Phillips Hue Reports Playback UnPaused... 2020-12-24 10:52:51.696 Info Phillips Hue: Phillips Hue Found Profile Device: LivingRoom 2020-12-24 10:52:51.696 Info Phillips Hue: Phillips Hue Reports Episode will trigger Playback UnPaused Scene for LivingRoom 2020-12-24 10:52:51.696 Info HttpClient: PUT http://192.168.1.228/api/PNJLwkFvcxtvRIvDhbFvBPGmHJ-XhL97txhL6RgM/groups/0/action 2020-12-24 10:52:51.696 Info Phillips Hue: Phillips Hue Reports Scene Trigger Success 2020-12-24 10:52:51.696 Info Server: http/1.1 Response 204 to 192.168.1.40. Time: 1ms. http://192.168.1.42:8096/emby/Sessions/Playing/Progress 2020-12-24 10:53:01.675 Info Server: http/1.1 POST http://192.168.1.42:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-12-24 10:53:01.677 Info Server: http/1.1 Response 204 to 192.168.1.40. Time: 3ms. http://192.168.1.42:8096/emby/Sessions/Playing/Progress 2020-12-24 10:53:11.699 Info Server: http/1.1 POST http://192.168.1.42:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-12-24 10:53:11.702 Info Server: http/1.1 Response 204 to 192.168.1.40. Time: 3ms. http://192.168.1.42:8096/emby/Sessions/Playing/Progress 2020-12-24 10:53:21.718 Info Server: http/1.1 POST http://192.168.1.42:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-12-24 10:53:21.721 Info Server: http/1.1 Response 204 to 192.168.1.40. Time: 3ms. http://192.168.1.42:8096/emby/Sessions/Playing/Progress 2020-12-24 10:53:28.888 Info Server: http/1.1 GET http://localhost:8096/emby/Users/d063f08a14564602852a2d932adf2d23?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY5LjAuMzQ5Ny4xMDAgU2FmYXJpLzUzNy4zNnwxNTQwMDYxNDYxNTEw&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-24 10:53:28.889 Info Server: http/1.1 Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/Users/d063f08a14564602852a2d932adf2d23?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY5LjAuMzQ5Ny4xMDAgU2FmYXJpLzUzNy4zNnwxNTQwMDYxNDYxNTEw&X-Emby-Client-Version=4.5.4.0 2020-12-24 10:53:29.022 Info Server: http/1.1 GET http://localhost:8096/emby/System/Configuration?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY5LjAuMzQ5Ny4xMDAgU2FmYXJpLzUzNy4zNnwxNTQwMDYxNDYxNTEw&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-24 10:53:29.027 Info Server: http/1.1 GET http://localhost:8096/emby/System/Logs?SortBy=IsFolder,SortName&SortOrder=Ascending&Fields=BasicSyncInfo,CanDelete&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&StartIndex=0&Limit=50&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY5LjAuMzQ5Ny4xMDAgU2FmYXJpLzUzNy4zNnwxNTQwMDYxNDYxNTEw&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-24 10:53:29.029 Info Server: http/1.1 Response 200 to ::1. Time: 2ms. http://localhost:8096/emby/System/Logs?SortBy=IsFolder,SortName&SortOrder=Ascending&Fields=BasicSyncInfo,CanDelete&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&StartIndex=0&Limit=50&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY5LjAuMzQ5Ny4xMDAgU2FmYXJpLzUzNy4zNnwxNTQwMDYxNDYxNTEw&X-Emby-Client-Version=4.5.4.0 2020-12-24 10:53:29.029 Info Server: http/1.1 Response 200 to ::1. Time: 7ms. http://localhost:8096/emby/System/Configuration?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY5LjAuMzQ5Ny4xMDAgU2FmYXJpLzUzNy4zNnwxNTQwMDYxNDYxNTEw&X-Emby-Client-Version=4.5.4.0 2020-12-24 10:53:31.716 Info Server: http/1.1 POST http://192.168.1.42:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-12-24 10:53:31.719 Info Server: http/1.1 Response 204 to 192.168.1.40. Time: 3ms. http://192.168.1.42:8096/emby/Sessions/Playing/Progress 2020-12-24 10:53:41.732 Info Server: http/1.1 POST http://192.168.1.42:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-12-24 10:53:41.735 Info Server: http/1.1 Response 204 to 192.168.1.40. Time: 2ms. http://192.168.1.42:8096/emby/Sessions/Playing/Progress 2020-12-24 10:53:43.217 Info Server: http/1.1 GET http://localhost:8096/emby/System/Logs/embyserver.txt. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 Sometimes for movies when you unpause it takes 10-20 seconds for the scene to actually run, but it does get there eventually This is the log after I stopped the TV series above. The light is still in its paused state. 2020-12-24 11:01:23.813 Info Server: http/1.1 POST http://192.168.1.42:8096/emby/Sessions/Playing/Stopped. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-12-24 11:01:23.814 Info SessionManager: Playback stopped reported by app AndroidTv 1.8.54g playing Who is Anonymous?. Stopped at 565748 ms 2020-12-24 11:01:23.815 Info Server: http/1.1 Response 204 to 192.168.1.40. Time: 1ms. http://192.168.1.42:8096/emby/Sessions/Playing/Stopped 2020-12-24 11:01:23.815 Info Phillips Hue: Phillips Hue Reports Playback Stopped 2020-12-24 11:01:23.815 Info Phillips Hue: Phillips Hue Found Profile Device: LivingRoom 2020-12-24 11:01:23.815 Info Phillips Hue: Phillips Hue Reports Episode will trigger Playback Stopped Scene on LivingRoom 2020-12-24 11:01:23.815 Info HttpClient: PUT http://192.168.1.228/api/PNJLwkFvcxtvRIvDhbFvBPGmHJ-XhL97txhL6RgM/groups/0/action 2020-12-24 11:01:23.816 Info Phillips Hue: Phillips Hue Reports Scene Trigger Success 2020-12-24 11:01:24.448 Info Server: http/1.1 GET http://192.168.1.42:8096/emby/Users/d063f08a14564602852a2d932adf2d23/Items/1132?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-12-24 11:01:24.449 Info Server: http/1.1 GET http://192.168.1.42:8096/emby/Users/d063f08a14564602852a2d932adf2d23/Items/1133?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-12-24 11:01:24.456 Info Server: http/1.1 Response 200 to 192.168.1.40. Time: 8ms. http://192.168.1.42:8096/emby/Users/d063f08a14564602852a2d932adf2d23/Items/1132?format=json 2020-12-24 11:01:24.456 Info Server: http/1.1 Response 200 to 192.168.1.40. Time: 8ms. http://192.168.1.42:8096/emby/Users/d063f08a14564602852a2d932adf2d23/Items/1133?format=json 2020-12-24 11:01:24.500 Info Server: http/1.1 GET http://192.168.1.42:8096/emby/Shows/NextUp?Fields=PrimaryImageAspectRatio%2CLocationType&SeriesId=1133&UserId=d063f08a14564602852a2d932adf2d23&EnableTotalRecordCount=false&format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011) 2020-12-24 11:01:24.505 Info Server: http/1.1 Response 200 to 192.168.1.40. Time: 5ms. http://192.168.1.42:8096/emby/Shows/NextUp?Fields=PrimaryImageAspectRatio%2CLocationType&SeriesId=1133&UserId=d063f08a14564602852a2d932adf2d23&EnableTotalRecordCount=false&format=json 2020-12-24 11:02:01.731 Info Server: http/1.1 GET http://localhost:8096/emby/Users/d063f08a14564602852a2d932adf2d23?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY5LjAuMzQ5Ny4xMDAgU2FmYXJpLzUzNy4zNnwxNTQwMDYxNDYxNTEw&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-24 11:02:01.732 Info Server: http/1.1 Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/Users/d063f08a14564602852a2d932adf2d23?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY5LjAuMzQ5Ny4xMDAgU2FmYXJpLzUzNy4zNnwxNTQwMDYxNDYxNTEw&X-Emby-Client-Version=4.5.4.0 2020-12-24 11:02:01.865 Info Server: http/1.1 GET http://localhost:8096/emby/Notifications/Types?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY5LjAuMzQ5Ny4xMDAgU2FmYXJpLzUzNy4zNnwxNTQwMDYxNDYxNTEw&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-24 11:02:01.867 Info Server: http/1.1 Response 200 to ::1. Time: 2ms. http://localhost:8096/emby/Notifications/Types?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY5LjAuMzQ5Ny4xMDAgU2FmYXJpLzUzNy4zNnwxNTQwMDYxNDYxNTEw&X-Emby-Client-Version=4.5.4.0 2020-12-24 11:02:02.937 Info Server: http/1.1 GET http://localhost:8096/emby/System/Configuration?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY5LjAuMzQ5Ny4xMDAgU2FmYXJpLzUzNy4zNnwxNTQwMDYxNDYxNTEw&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-24 11:02:02.937 Info Server: http/1.1 Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/System/Configuration?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY5LjAuMzQ5Ny4xMDAgU2FmYXJpLzUzNy4zNnwxNTQwMDYxNDYxNTEw&X-Emby-Client-Version=4.5.4.0 2020-12-24 11:02:02.977 Info Server: http/1.1 GET http://localhost:8096/emby/System/Logs?SortBy=IsFolder,SortName&SortOrder=Ascending&Fields=BasicSyncInfo,CanDelete&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&StartIndex=0&Limit=50&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY5LjAuMzQ5Ny4xMDAgU2FmYXJpLzUzNy4zNnwxNTQwMDYxNDYxNTEw&X-Emby-Client-Version=4.5.4.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 2020-12-24 11:02:02.979 Info Server: http/1.1 Response 200 to ::1. Time: 1ms. http://localhost:8096/emby/System/Logs?SortBy=IsFolder,SortName&SortOrder=Ascending&Fields=BasicSyncInfo,CanDelete&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&StartIndex=0&Limit=50&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzY5LjAuMzQ5Ny4xMDAgU2FmYXJpLzUzNy4zNnwxNTQwMDYxNDYxNTEw&X-Emby-Client-Version=4.5.4.0 2020-12-24 11:02:07.424 Info Server: http/1.1 GET http://localhost:8096/emby/System/Logs/embyserver.txt. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 If you want to post the source I can try and see whats wrong with it. Will do. I'll update git. I think that by using session manager instead if the event session, we probably don't need the extra wait in the task. I had a feeling that that would be the outcome. Merry Christmas!
NSBrad 1 Posted January 12, 2021 Posted January 12, 2021 On 12/10/2020 at 4:52 PM, altairr said: Watched some content tonight using the stable version of emby server and same result as the beta.. If it's only me having the problem perhaps some network issues even though everything is on my lan? Can anyone else reproduce the issue? Sorry, I haven't read the forums in a bit. I run into this issue at times too. It doesn't happen all the time though. I've gotten used to working around it a bit by pausing and unpausing quickly a 2nd time. That usually sends my lights to the playing state. It seemed like it was a little less frequent for awhile but I know I've run into it the last couple nights. I'll try to grab my logs on it if needed the next time it happens.
