Bambu Utila 9 Posted September 11, 2020 Posted September 11, 2020 Just now, chef said: Okay, I'll take a look at the code, but scenes should only run after 6:30pm. That isn't happening? Nope, sadly enough not. I tied to start a movie and tv series after 6pm but before 12am and it doesn't work, after 12am also still doesn't work for me
BillOatman 597 Posted September 11, 2020 Author Posted September 11, 2020 (edited) return (DateTime.Now.TimeOfDay >= TimeSpan.Parse(profile.Schedule + ":00") && DateTime.Now.TimeOfDay <= TimeSpan.Parse("6:00:00")); @chef so configured time is 6:30pm at 7pm DateTime.Now.TimeOfDay >= TimeSpan.Parse(profile.Schedule + ":00" is true but DateTime.Now.TimeOfDay <= TimeSpan.Parse("6:00:00") is false and the logic is AND You need to include the date component, not just the time This is what I had using sunrise/sunset /// <summary> /// Check if it is currently daylight in the supplied location. /// </summary> /// <param name="latitude"></param> /// <param name="longitude"></param> /// <param name="offset">The offset (+/-) from sunset, in hours, to use to determine when to start setting light scenes.</param> /// <returns>True if during daylight hours, else false.</returns> public static bool isDaytime(double latitude, double longitude, int offset) { DateTime now = DateTime.Now.ToLocalTime(); DateTime sunrise = GetSunrise(now, latitude, longitude); DateTime sunset = GetSunset(now, latitude, longitude); // SimpleLog.Info("isDaytime: offset: " + offset.ToString() + " sunrise: " + sunrise.TimeOfDay.ToString() + " sunset: " + sunset.TimeOfDay.ToString() + " sunset adjusted: " + sunset.AddHours(offset).TimeOfDay.ToString()); if (now.TimeOfDay >= sunrise.TimeOfDay && now.TimeOfDay < sunset.AddHours(offset).TimeOfDay) return true; return false; } So anything not daytime, the scenes were used. Edited September 11, 2020 by BillOatman 1
BillOatman 597 Posted September 11, 2020 Author Posted September 11, 2020 (edited) Maybe that's what you do @chef Define 2 times that give the range of when not to trigger scenes like sunrise and sunset and use the logic above but with your configured times. DST becomes a nuisance, but it was already with your current configuration. Edited September 11, 2020 by BillOatman 1
chef 3811 Posted September 11, 2020 Posted September 11, 2020 (edited) It took a moment but this seems to be it here: private static bool ScheduleAllowScene(PhillipsHueSceneEmbyProfile profile) { if (string.IsNullOrEmpty(profile.Schedule)) return true; return (DateTime.Now.TimeOfDay >= TimeSpan.Parse(profile.Schedule + ":00") || DateTime.Now.TimeOfDay <= TimeSpan.Parse("6:00:00")); } Time is: 8:00pm = 20:00 Schedule Time is set: 7:00pm = 19:00 Time is greater then the scheduled time -> This is "true" or Time is less than 06:00 (6:00am) -> This is "false" (but condition is already "true"). at 24:00 (12:00am) condition is already "true", is greater then 19:00 at 01:00 (1:00am) is greater then scheduled time (19:00) -> This is "false"... but is less then 06:00 -> This is "true" Both conditions on either side of the OR statement before 19:00 hrs will return "false", after 06:00 hrs. Edited September 11, 2020 by chef 1
BillOatman 597 Posted September 11, 2020 Author Posted September 11, 2020 56 minutes ago, chef said: It took a moment but this seems to be it here: private static bool ScheduleAllowScene(PhillipsHueSceneEmbyProfile profile) { if (string.IsNullOrEmpty(profile.Schedule)) return true; return (DateTime.Now.TimeOfDay >= TimeSpan.Parse(profile.Schedule + ":00") || DateTime.Now.TimeOfDay <= TimeSpan.Parse("6:00:00")); } Time is: 8:00pm = 20:00 Schedule Time is set: 7:00pm = 19:00 Time is greater then the scheduled time -> This is "true" or Time is less than 06:00 (6:00am) -> This is "false" (but condition is already "true"). at 24:00 (12:00am) condition is already "true", is greater then 19:00 at 01:00 (1:00am) is greater then scheduled time (19:00) -> This is "false"... but is less then 06:00 -> This is "true" Both conditions on either side of the OR statement before 19:00 hrs will return "false", after 06:00 hrs. Heh, I usually see the simple solution first but not this time, well played
Bambu Utila 9 Posted September 12, 2020 Posted September 12, 2020 YES! It's working! I've downloaded the new version 1.1.0.1 and tried to start something before and after 12am, both are working as expected now! Thanks you for fixing this!
BillOatman 597 Posted September 12, 2020 Author Posted September 12, 2020 @chef Don't forget to update GIT 1
chef 3811 Posted September 12, 2020 Posted September 12, 2020 (edited) We could have also used De Morgan's Law, of Inversion ("!") to inverse the && (and) truth table to get the exact same outcome. De Morgan's Law in Computer science says that by inverting an inverse && we get an || and vice versa, using the "bang" ("!"). "!(!bollean.value && ! boolean.value) == boolean.value || boolean.value" Which is just Crazy right! Edited September 12, 2020 by chef 1
NSBrad 1 Posted September 18, 2020 Posted September 18, 2020 On 8/24/2020 at 5:16 PM, NSBrad said: Love the plugin. It was exactly what I as looking for in Hue support. I'm having an issue though where it randomly stops working. I haven't found any pattern to it. Last night it happened when a video I was watching ended and and when I hit play on the next episode it stayed in my stopped scene and didn't go to the playing scene. I've had this happen to me a number of times over the last few months. When it happens the configuration page doesn't list any of my scenes when I select any of the states in the configuration screen. The only fix I've found so far is to reboot the server. Are there any logs or anything that I can check or send in to try to figure out what's causing it? I'm running the Emby server on a Synology NAS btw if that makes a difference. Is this issue not happening for anyone else? I ran into it again last night.
BillOatman 597 Posted September 20, 2020 Author Posted September 20, 2020 On 9/18/2020 at 5:43 PM, NSBrad said: Is this issue not happening for anyone else? I ran into it again last night. @NSBrad If your plugin config screen does not list any scenes that would imply that your Emby server cannot communicate with your hue hub. If it's a problem with the hub or the server is anyones guess, but if a server reboot corrects the situation, it would imply a server issue of some sort, either the server itself or Emby. Maybe the Emby logs could shed some light on it.
marciodantas 0 Posted October 18, 2020 Posted October 18, 2020 On 3/6/2020 at 3:55 PM, BillOatman said: If you go to the dashboard get the server log. And make note in your post here the time you tried it. Hey @BillOatman sorry to bump this, but here in my place we watch every movie through Chromecast. Would you mind taking a look at my server log and checking if you can enable Chromecast as a device in the plugin configuration? As @zackidack pointed before, it does show as an "active device" in dashboard even tough it's not shown as a "pickable" device in Hue plugin. I started casting ~ 23:55 embyserver.txt
BillOatman 597 Posted October 18, 2020 Author Posted October 18, 2020 (edited) @marciodantas The hue commands originate from the server not the client, so not the chromecast in your case. There must be something wrong in the plugin configuration screen that isn't allowing the chromecast to be selected., @chef largely rewrote that code, but between he and I we should be able to figure it out. But I do not have a chromecast device to test with and I do not know if @chef does or not. Also is this a older chromecast or one of the new ones? Edited October 18, 2020 by BillOatman
chef 3811 Posted October 18, 2020 Posted October 18, 2020 Chromecast is a strange one. That device doesn't report playback. It is possible that the device which instantiated the playback to chromecast would trigger the event.
BillOatman 597 Posted October 18, 2020 Author Posted October 18, 2020 1 minute ago, chef said: Chromecast is a strange one. That device doesn't report playback. It is possible that the device which instantiated the playback to chromecast would trigger the event. Yeah the older ones only operate when something "casts" to them. The new ones are more like shields and run android tv. Thats why I asked old or new chromecast. @marciodantas If it is a older chromecast is the device that is casting to it in the plugin list? 1
marciodantas 0 Posted October 19, 2020 Posted October 19, 2020 (edited) On 10/18/2020 at 1:22 PM, BillOatman said: Yeah the older ones only operate when something "casts" to them. The new ones are more like shields and run android tv. Thats why I asked old or new chromecast. @marciodantas If it is a older chromecast is the device that is casting to it in the plugin list? Yes guys, it's the old one (Chromecast Ultra) without the Google TV! @BillOatman yes all the device that is casting is in the plugin list. I tried with iPad (native emby app), S20 (Android 10) and through Chrome (OSX).. None of them worked... I'll try again later, but i'm thinking that chromecast makes the connection directly with the server, right? Doesn't seems to me that using the devices would trigger the plugin. On a side note, if you could enable a "Whatever device" in the list, that would defintely works for me! Edited October 19, 2020 by marciodantas
marciodantas 0 Posted October 27, 2020 Posted October 27, 2020 For any1 reading this thread...: On 10/19/2020 at 2:09 PM, marciodantas said: Yes guys, it's the old one (Chromecast Ultra) without the Google TV! @BillOatman yes all the device that is casting is in the plugin list. I tried with iPad (native emby app), S20 (Android 10) and through Chrome (OSX).. None of them worked... I'll try again later, but i'm thinking that chromecast makes the connection directly with the server, right? Doesn't seems to me that using the devices would trigger the plugin. On a side note, if you could enable a "Whatever device" in the list, that would defintely works for me! Ended up setting a script with ScripterX and ifttt and got it to work! thanks for the support guys!
altairr 16 Posted November 25, 2020 Posted November 25, 2020 Hi, First of all, thanks for the great plugin! It's been some time I've seen the plugin in the Catalog and finally made the switch to Hue recently. I observed some weird behavior when I pause and un-pause a TV show or a movie. It's not happening all the time though.. When I pause the scene changes correctly. Sometimes however when I un-pause, the scene goes to unpaused and right after at the same second back to paused scene. 2020-11-25 19:37:32.712 Info Phillips Hue: Phillips Hue Reports Playback UnPaused... 2020-11-25 19:37:32.712 Info Phillips Hue: Phillips Hue Found Profile Device: SHIELD 2020-11-25 19:37:32.712 Info Phillips Hue: Phillips Hue Reports Episode will trigger Playback UnPaused Scene for SHIELD 2020-11-25 19:37:32.712 Info HttpClient: PUT http://192.168.1.230/api/yd7yxGuGVpPrazao7uVP0DAZ7Zlyq1sPZARtOZrr/groups/0/action 2020-11-25 19:37:32.712 Info Phillips Hue: Phillips Hue Reports Scene Trigger Success 2020-11-25 19:37:32.713 Info Server: http/1.1 Response 204 to 192.168.1.145. Time: 3ms. http://192.168.1.239:8096/emby/Sessions/Playing/Progress 2020-11-25 19:37:32.714 Info Phillips Hue: Phillips Hue Reports Playback Paused... 2020-11-25 19:37:32.714 Info Phillips Hue: Phillips Hue Found Session Device: SHIELD 2020-11-25 19:37:32.714 Info HttpClient: PUT http://192.168.1.230/api/yd7yxGuGVpPrazao7uVP0DAZ7Zlyq1sPZARtOZrr/groups/0/action 2020-11-25 19:37:32.716 Info Phillips Hue: Phillips Hue Reports Scene Trigger Success 2020-11-25 19:37:32.717 Info Server: http/1.1 Response 204 to 192.168.1.145. Time: 5ms. http://192.168.1.239:8096/emby/Sessions/Playing/Progress I'm using 4.6.0.6 beta for the server and 1.8.54 (RC5) for Android TV on a Shield Pro. Thanks in advance for your help.
BillOatman 597 Posted November 29, 2020 Author Posted November 29, 2020 (edited) On 11/25/2020 at 1:54 PM, altairr said: Hi, First of all, thanks for the great plugin! It's been some time I've seen the plugin in the Catalog and finally made the switch to Hue recently. I observed some weird behavior when I pause and un-pause a TV show or a movie. It's not happening all the time though.. When I pause the scene changes correctly. Sometimes however when I un-pause, the scene goes to unpaused and right after at the same second back to paused scene. 2020-11-25 19:37:32.712 Info Phillips Hue: Phillips Hue Reports Playback UnPaused... 2020-11-25 19:37:32.712 Info Phillips Hue: Phillips Hue Found Profile Device: SHIELD 2020-11-25 19:37:32.712 Info Phillips Hue: Phillips Hue Reports Episode will trigger Playback UnPaused Scene for SHIELD 2020-11-25 19:37:32.712 Info HttpClient: PUT http://192.168.1.230/api/yd7yxGuGVpPrazao7uVP0DAZ7Zlyq1sPZARtOZrr/groups/0/action 2020-11-25 19:37:32.712 Info Phillips Hue: Phillips Hue Reports Scene Trigger Success 2020-11-25 19:37:32.713 Info Server: http/1.1 Response 204 to 192.168.1.145. Time: 3ms. http://192.168.1.239:8096/emby/Sessions/Playing/Progress 2020-11-25 19:37:32.714 Info Phillips Hue: Phillips Hue Reports Playback Paused... 2020-11-25 19:37:32.714 Info Phillips Hue: Phillips Hue Found Session Device: SHIELD 2020-11-25 19:37:32.714 Info HttpClient: PUT http://192.168.1.230/api/yd7yxGuGVpPrazao7uVP0DAZ7Zlyq1sPZARtOZrr/groups/0/action 2020-11-25 19:37:32.716 Info Phillips Hue: Phillips Hue Reports Scene Trigger Success 2020-11-25 19:37:32.717 Info Server: http/1.1 Response 204 to 192.168.1.145. Time: 5ms. http://192.168.1.239:8096/emby/Sessions/Playing/Progress I'm using 4.6.0.6 beta for the server and 1.8.54 (RC5) for Android TV on a Shield Pro. Thanks in advance for your help. @Altair When this happens the video does not pause? @chef @Luke This would appear to be a Emby bug, but also might explain things that I saw in the past that I attributed to the hue hub ignoring the command. Not sure what the plugin could do except ignore commands within a second maybe. Edited November 29, 2020 by BillOatman
altairr 16 Posted November 30, 2020 Posted November 30, 2020 16 hours ago, BillOatman said: When this happens the video does not pause? No, when I unpause the video plays fine regardless of the scene. What I did as a workaround was to define a transition time of 500ms. There is still a strange thing happenning though. When I unpause a video, the scene switches rapidly and still has the one defined as Paused although the video is playing. After a couple of seconds the scene switches to the one defined as Unpaused. This doesn't happen every time, in some cases it goes directly to the Unpaused scene without the weird change.
chef 3811 Posted November 30, 2020 Posted November 30, 2020 On 11/25/2020 at 1:54 PM, altairr said: Hi, First of all, thanks for the great plugin! It's been some time I've seen the plugin in the Catalog and finally made the switch to Hue recently. I observed some weird behavior when I pause and un-pause a TV show or a movie. It's not happening all the time though.. When I pause the scene changes correctly. Sometimes however when I un-pause, the scene goes to unpaused and right after at the same second back to paused scene. 2020-11-25 19:37:32.712 Info Phillips Hue: Phillips Hue Reports Playback UnPaused... 2020-11-25 19:37:32.712 Info Phillips Hue: Phillips Hue Found Profile Device: SHIELD 2020-11-25 19:37:32.712 Info Phillips Hue: Phillips Hue Reports Episode will trigger Playback UnPaused Scene for SHIELD 2020-11-25 19:37:32.712 Info HttpClient: PUT http://192.168.1.230/api/yd7yxGuGVpPrazao7uVP0DAZ7Zlyq1sPZARtOZrr/groups/0/action 2020-11-25 19:37:32.712 Info Phillips Hue: Phillips Hue Reports Scene Trigger Success 2020-11-25 19:37:32.713 Info Server: http/1.1 Response 204 to 192.168.1.145. Time: 3ms. http://192.168.1.239:8096/emby/Sessions/Playing/Progress 2020-11-25 19:37:32.714 Info Phillips Hue: Phillips Hue Reports Playback Paused... 2020-11-25 19:37:32.714 Info Phillips Hue: Phillips Hue Found Session Device: SHIELD 2020-11-25 19:37:32.714 Info HttpClient: PUT http://192.168.1.230/api/yd7yxGuGVpPrazao7uVP0DAZ7Zlyq1sPZARtOZrr/groups/0/action 2020-11-25 19:37:32.716 Info Phillips Hue: Phillips Hue Reports Scene Trigger Success 2020-11-25 19:37:32.717 Info Server: http/1.1 Response 204 to 192.168.1.145. Time: 5ms. http://192.168.1.239:8096/emby/Sessions/Playing/Progress I'm using 4.6.0.6 beta for the server and 1.8.54 (RC5) for Android TV on a Shield Pro. Thanks in advance for your help. Seems like perhaps the Progress event is happening so fast we are unable to remove the paused scene from our persistent list before it is registering the unpaused action. @BillOatman should we Task.Delay? Only side effect, is in some instances, the unpaused scene would seem sightly "laggy" compared to the rest. It would probably stop this behavior though.
BillOatman 597 Posted November 30, 2020 Author Posted November 30, 2020 48 minutes ago, chef said: Seems like perhaps the Progress event is happening so fast we are unable to remove the paused scene from our persistent list before it is registering the unpaused action. @BillOatman should we Task.Delay? Only side effect, is in some instances, the unpaused scene would seem sightly "laggy" compared to the rest. It would probably stop this behavior though. Delaying a second or 2 wouldn't be noticeable. Particularly for those that use a ramp on the light level change. Worth a try I'd say. 1
chef 3811 Posted November 30, 2020 Posted November 30, 2020 57 minutes ago, BillOatman said: Delaying a second or 2 wouldn't be noticeable. Particularly for those that use a ramp on the light level change. Worth a try I'd say. On it! 1
BillOatman 597 Posted November 30, 2020 Author Posted November 30, 2020 @chef You might want to reverse the order here as well. { PlaybackUnPaused(e, config, config.SavedHueEmbyProfiles.FirstOrDefault(p => p.DeviceName.Equals(e.Session.DeviceName))); PausedSessionsIds.RemoveAll(s => s.Equals(e.Session.Id)); }
chef 3811 Posted December 1, 2020 Posted December 1, 2020 4 hours ago, BillOatman said: @chef You might want to reverse the order here as well. { PlaybackUnPaused(e, config, config.SavedHueEmbyProfiles.FirstOrDefault(p => p.DeviceName.Equals(e.Session.DeviceName))); PausedSessionsIds.RemoveAll(s => s.Equals(e.Session.Id)); } Yes this will also cut down on the amount of time it takes. Perfect! Nice catch!
chef 3811 Posted December 1, 2020 Posted December 1, 2020 (edited) @altairr I'd love to know if the new version in the catalogue fixes the issue. The threshold of the delay can be customized, so if you find it still not meeting expectation, please mention it here in this thread. 1. Fixed un-paused session removal - order of operation to beginning of the method 2. Added Task Delay (150) //<- probably could be higher to compensate for altairr's 500ms. Cool! @BillOatman thank you sir! nice to know we're surviving 2020! blah! Edited December 1, 2020 by chef 1
