inzi2u 1 Posted November 10, 2021 Posted November 10, 2021 @darkside40 I've installed your plugin on Emby Server 4.6.4.0 , Testing the plugin sends the message to the Telegram channel. But i dont recieve any updates to the telegram channel. mind you, I am using autoscan docker to scan stuff in to emby, to prevent running a full scan every single time. Could this be the issue? thankx
darkside40 108 Posted November 10, 2021 Posted November 10, 2021 Could you provide a link to that docker? The Telegram Plugin does only work if you use the Emby internal notification system.
inzi2u 1 Posted November 13, 2021 Posted November 13, 2021 @darkside40 THank you.. once that was enabled things started working
