Luke 42237 Posted July 2, 2019 Posted July 2, 2019 Funny you should say that. Can't find the specific one I used in the plugin list anymore. If you're talking about a server plugin, it's probably failing to load due to rolling back the server.
jboydude 14 Posted July 2, 2019 Posted July 2, 2019 (edited) What plugin is that? It might be auto box sets but it basically created a collections entry in my library settings. I can delete them and test if it makes any difference. it basically created an xml file to assoicate the collections. The collections are listed and are working. But I was thinking it might be why my movie list in emc is freezing. Edited July 2, 2019 by jboydude
jboydude 14 Posted July 3, 2019 Posted July 3, 2019 Deleted my TV series library entry and my collections, upgraded back to sever beta, deleted library.db, rebuilt my library. Now my library structure is fine. Tried scrolling without the collections no issue. Something about my collections is eroding when loading the list?
jboydude 14 Posted July 3, 2019 Posted July 3, 2019 So are you saying everything is fine now? I even put back on the auto box sets. A this point it could have been a library problem that started with the update. Downgrading and re-updating required me to delete the library file and now things that have been watched are unwatched. Such a shame I had to do the extreme to fix it myself.
Luke 42237 Posted July 3, 2019 Posted July 3, 2019 Thanks for the feedback. Apologies for the disruption.
