abescalamis 88 Posted June 13, 2019 Posted June 13, 2019 (edited) @@Luke I been recording shows from live TV, those shows get save as .ts files, and I thought on saving some space by using the convert feature of emby. Issue/Cause: The issue is when I select the "automatically convert new content" in the convert feature options, then Emby detects the show that it is still recording on "live TV" and starts to convert the .ts video right away when the show hasn't even finish recording, the result is a corrupted file. Solution: Emby has to wait for the "Live TV" recording to finish before it starts convert. Important: Emby did successfully convert videos that were already recorded. Edited June 13, 2019 by abescalamis
Luke 42221 Posted June 14, 2019 Posted June 14, 2019 Hi there, please attach the emby server log, thanks.
abescalamis 88 Posted June 14, 2019 Author Posted June 14, 2019 Hi there, please attach the emby server log, thanks. Will the log show the problem, because emby doesn't have a convert issue, the problem is a combination of this two options: 1) In the library settings I have selected the option "enable real time monitoring" . 2) in the Convert options I have enable "automatically convert new content". By enabling the two options above Emby detects the episode when it starts to record and it also starts to convert. I won't provide a log for this, I only wanted to let you know, I'm just not using the converting feature anymore, as is not something I really need.
Luke 42221 Posted June 14, 2019 Posted June 14, 2019 It's been resolved for the next release, thanks.
