emveepee 133 Posted June 20, 2019 Author Posted June 20, 2019 By the way, its recording (theoretically) at the moment - should it show anything in the dashboard in connection with that ? An Emby user would have to tell you that. I don't know the theory. Martin
sub3 64 Posted June 20, 2019 Posted June 20, 2019 Yes, for live tv, I've convinced myself (correctly I think) v4 started in about 7 seconds whereas v5 is about 20, but yes I'll send some logs over. If you open the stream in VLC, how long does it take to see it? ie, open a network stream with url like http://ipaddress:8866/live?channel=1
pünktchen 1410 Posted June 20, 2019 Posted June 20, 2019 By the way, its recording (theoretically) at the moment - should it show anything in the dashboard in connection with that ? An Emby user would have to tell you that. I don't know the theory. Martin It does with Emby's core live tv, it's brocken for live tv plugins since Emby 4.x.x
arrbee99 1836 Posted June 20, 2019 Posted June 20, 2019 If you open the stream in VLC, how long does it take to see it? ie, open a network stream with url like http://ipaddress:8866/live?channel=1 Should finish recording in about 20min, will have a look then.
arrbee99 1836 Posted June 20, 2019 Posted June 20, 2019 It does with Emby's core live tv, it's brocken for live tv plugins since Emby 4.x.x Yes, haven't seen it for quite a while (possibly years actually for me), and don't record very much anyway, but it would be nice if it could.
arrbee99 1836 Posted June 20, 2019 Posted June 20, 2019 (edited) If you open the stream in VLC, how long does it take to see it? ie, open a network stream with url like http://ipaddress:8866/live?channel=1 They are a little bit closer than I thought. In vlc channels are 9-10 sec starting, in Chrome (localhost:8866) they are 17-18sec starting. Don't know if transcoding might come in there somewhere. Will try as well in nextpvr.exe and Emby Theater if you like. P.S recording seemed fine. Two channels from the same mux at the same time seemed successful, just having a quick skim through. Edited June 20, 2019 by arrbee99
sub3 64 Posted June 20, 2019 Posted June 20, 2019 They are a little bit closer than I thought. In vlc channels are 9-10 sec starting, in Chrome (localhost:8866) they are 17-18sec starting. Don't know if transcoding might come in there somewhere. Will try as well in nextpvr.exe and Emby Theater if you like. What source are you using? With an IPTV source, I see video in 3 seconds in VLC. With a Hauppauge WinTV-dualHD DVB-T, I see video in 3 seconds in VLC. With a Hauppauge WinTV-HVR5525 DVB-S, I see video in 4 seconds in VLC.
arrbee99 1836 Posted June 20, 2019 Posted June 20, 2019 What source are you using? With an IPTV source, I see video in 3 seconds in VLC. With a Hauppauge WinTV-dualHD DVB-T, I see video in 3 seconds in VLC. With a Hauppauge WinTV-HVR5525 DVB-S, I see video in 4 seconds in VLC. Its a Hauppauge Win TV HVR-3300 standard def DVB-S. Freeview.
sub3 64 Posted June 20, 2019 Posted June 20, 2019 If you can post logs over at the NextPVR forums, I'll take a look.
arrbee99 1836 Posted June 20, 2019 Posted June 20, 2019 If you can post logs over at the NextPVR forums, I'll take a look. Roger wilco
emveepee 133 Posted June 20, 2019 Author Posted June 20, 2019 Yes, haven't seen it for quite a while (possibly years actually for me), and don't record very much anyway, but it would be nice if it could. Did you notice the recording notification popups? I do get these? I didn't disable them but I would if I really used Emby. Martin
arrbee99 1836 Posted June 20, 2019 Posted June 20, 2019 Did you notice the recording notification popups? I do get these? I didn't disable them but I would if I really used Emby. Martin If you mean under 'Activity', no, nothing showed up.
arrbee99 1836 Posted June 20, 2019 Posted June 20, 2019 Oh. No nothing, but haven't seen one of those for years either. Thought they were got rid of actually.
emveepee 133 Posted June 20, 2019 Author Posted June 20, 2019 Oh. No nothing, but haven't seen one of those for years either. Thought they were got rid of actually. I definitely get them Martin
arrbee99 1836 Posted June 20, 2019 Posted June 20, 2019 Not here. Not for a long time. Like I say I don't actually record a lot, and I think you said something about it not applying to plugins anyway... Did used to get similar stuff when I added new media and it popped up to say found new episodes of The Flash or something like that.
emveepee 133 Posted June 20, 2019 Author Posted June 20, 2019 Not me, I am only running the plugin right now. It's coming from the browser though so perhaps you turned notifications off. Martin
arrbee99 1836 Posted June 21, 2019 Posted June 21, 2019 No idea. I see a whole list of notifications - any idea which one might / would apply to recordings ? I see I've apparently disabled New Content Added, will probably turn that back on. Actually, would that be it, new content being a new recording ?
emveepee 133 Posted June 21, 2019 Author Posted June 21, 2019 I don't think so because I have that disabled too. As I posted earlier I don't know what setting this is. Martin
sub3 64 Posted June 21, 2019 Posted June 21, 2019 They are a little bit closer than I thought. In vlc channels are 9-10 sec starting, in Chrome (localhost:8866) they are 17-18sec starting. Don't know if transcoding might come in there somewhere. Will try as well in nextpvr.exe and Emby Theater if you like. P.S recording seemed fine. Two channels from the same mux at the same time seemed successful, just having a quick skim through. For anyone else that was following this, I've made some changes in the most recent NextPVR v5 build, which got arrbee99 down to about a second to get live streams in VLC (and about 8 seconds in web app - still working on improvements in that area). Here was a video of me start streams, and changing channels etc. Definitely less than a second to get the stream on my machine. [VIDEO] [/VIDEO]
arrbee99 1836 Posted June 21, 2019 Posted June 21, 2019 FYI in connection with the above from sub3, so far in Chrome (hence transcoding for me) start up times have improved to about 9 seconds and in Theater they've dropped to an awesome 2 seconds Never been that fast since I started using Emby / NextPVR. Will have to have a go on Shield / Fire TV soon.
emveepee 133 Posted July 1, 2019 Author Posted July 1, 2019 Not here. Not for a long time. Like I say I don't actually record a lot, and I think you said something about it not applying to plugins anyway... Did used to get similar stuff when I added new media and it popped up to say found new episodes of The Flash or something like that. The likely reason you haven't got any notifications is the plugin you are using is not compatible with the beta Emby server and you are not able to login to NextPVR. The stale data in your database will allow you to play live tv and that is about it. I will get that corrected shortly. I think you will like the EPG refresh speed in the current Emby beta. Martin
arrbee99 1836 Posted July 1, 2019 Posted July 1, 2019 Well refresh speed is very good at the moment - 4 seconds. That could be because I presume its not doing much with that login thing you mentioned. And looking forward to the updated plugin I should probably just rebuild the whole database in the meantime to get rid of those old channels. I guess I just stop Emby server, rename library.db to library.db.old or something and just start the server again ?
emveepee 133 Posted July 2, 2019 Author Posted July 2, 2019 I have updated post # with a change that should work on 4.1 and 4.2 version of the Emby server. There are also improvements in the recording update logic and made some efficiency in getting art using the latest version of NextPVR Martin
arrbee99 1836 Posted July 3, 2019 Posted July 3, 2019 Just downloaded. Installs fine. Updated guide fine. Seems to play dvb-s channels fine. Once it didn't play a channel (spinning circle) but thats just after a 5 minute play. Artwork seems a bit sparse, but that might be a result of there not being much for obscure New Zealand daytime television stuff. Haven't tried recording yet.
