Clangrijan 19 Posted May 5, 2023 Posted May 5, 2023 I'm also attaching the plugin configuration, just in case it's needed. GenreCleaner.xml
Luke 42255 Posted May 6, 2023 Posted May 6, 2023 How did you add the second genre? @ebrare you sure this has ever been supported? Looking at the plugin code that actually utilizes the options, I'm not sure.
Clangrijan 19 Posted May 6, 2023 Posted May 6, 2023 16 minutes ago, Luke said: How did you add the second genre? @ebrare you sure this has ever been supported? Looking at the plugin code that actually utilizes the options, I'm not sure. I did it from the plugin itself. First, I added one, and then the other. Could that be it? Is it possible that it doesn't support mapping two or more genres to another?
ebr 16346 Posted May 7, 2023 Posted May 7, 2023 15 hours ago, Luke said: are you sure this has ever been supported? Yes, it originally could map multiple sources to a single target.
Luke 42255 Posted May 7, 2023 Posted May 7, 2023 On 5/5/2023 at 10:19 AM, Clangrijan said: Hi. I'm attaching the log. I'm not sure if this is what you're looking for. Thanks a lot. embyserver.txt 3.5 MB · 1 download @Clangrijanwhat item did you refresh during the time of this log? What example should we be looking at?
Clangrijan 19 Posted May 8, 2023 Posted May 8, 2023 10 hours ago, Luke said: @Clangrijanwhat item did you refresh during the time of this log? What example should we be looking at? I refreshed my movie library and wanted the genres "Aventura" and "Adventure" to map to "Aventuras". The movies with the genre "Aventura" were mapped correctly at the time, but those with the genre "Adventure" were not. Examples of movies with the "Adventure" genre are: Ant-Man y la Avispa Quantumanía, Avatar El sentido del agua, Momias.... I'm sorry if I didn't explain myself well. Another option I have is to remove the double mapping and do them one by one.
Clangrijan 19 Posted May 10, 2023 Posted May 10, 2023 I think I've found where the problem is. I don't know why some movies have the "Genre" field locked so it can't be changed when updating metadata. If I unlock it, then the plugin works correctly. The problem is removing this lock one by one for each movie. Is there a way to remove it in bulk? Thank you very much. 1
Luke 42255 Posted May 10, 2023 Posted May 10, 2023 8 hours ago, Clangrijan said: I think I've found where the problem is. I don't know why some movies have the "Genre" field locked so it can't be changed when updating metadata. If I unlock it, then the plugin works correctly. The problem is removing this lock one by one for each movie. Is there a way to remove it in bulk? Thank you very much. When you manually edit they get automatically locked to prevent your changes from being lost. 1
Clangrijan 19 Posted May 10, 2023 Posted May 10, 2023 13 minutes ago, Luke said: Cuando edita manualmente, se bloquean automáticamente para evitar que se pierdan los cambios . Ok, I understand. Thank you very much for your help. 1
b3nZol 2 Posted September 28, 2023 Posted September 28, 2023 (edited) I cant get this to work either. Tried it serveral times now. I now deleted GenreCleaner.xml, restarted Emby and for testing purposes i mapped "Abenteuer" to "Adventure" (as i want Adventure only) and deleted "TV-Film". Saved an ran a scan. I can see several entrys in log with "BaseGenreCleaner reports change to" but everything remains as its been before. Fields are not locked. Edited September 28, 2023 by b3nZol
b3nZol 2 Posted September 28, 2023 Posted September 28, 2023 (edited) https://pastebin.com/tS36KYEA I dont use nfo files, metadata are stores in emby directories Edited September 28, 2023 by b3nZol
ebr 16346 Posted September 28, 2023 Posted September 28, 2023 3 hours ago, b3nZol said: Saved an ran a scan Hi. Did you try refreshing metadata?
b3nZol 2 Posted September 28, 2023 Posted September 28, 2023 (edited) Is there a way to update certain Metadata, in this case "Genres", only? 8k+ movies... thats why i am asking. Edit: Yep, thats the trick. Thank you. Edited September 28, 2023 by b3nZol 1
Luke 42255 Posted September 28, 2023 Posted September 28, 2023 Hi, sorry, there is currently no way to update only genres.
b3nZol 2 Posted September 28, 2023 Posted September 28, 2023 (edited) Maybe you should update the plugins description that a meta refresh is needed, not only a rescan. Works perfectly after refreshing metadata, thank you Edited September 28, 2023 by b3nZol
ebr 16346 Posted September 28, 2023 Posted September 28, 2023 40 minutes ago, b3nZol said: Maybe you should update the plugins description that a meta refresh is needed, not only a rescan. Works perfectly after refreshing metadata, thank you Hi. I guess we thought it was evident as genres are metadata but perhaps we should be more specific. Thanks.
b3nZol 2 Posted September 28, 2023 Posted September 28, 2023 It offers rescanning after saving and that is what it does. It does not say 'refresh metadata' nor does it do that But no problem, i am satisfied now
b3nZol 2 Posted September 29, 2023 Posted September 29, 2023 Weird. For Series a normal scan was enough to remap. Only movies needed meta refresh
Luke 42255 Posted October 1, 2023 Posted October 1, 2023 We'll look at improving this. Thanks for the feedback.
