entity279 0 Posted June 9, 2019 Posted June 9, 2019 (edited) Hi, I'm using a hegel HD30 DLNA&airplay-capable DAC. Server is running on FreeNAS I'd like to push music from my Android Phone to play on the DAC. Where to start from? can you please point me to any helpful resource, perhaps?. Problem is I've never used DLNA before at all and I don't know how would one go about it. I do not see my Hegel listed in the devices list (only my browser or my phone appear there). Is it normal? Must I create a custom profile for the connection to work? From the DAC itself there's little to do since it only has limited display capabilities. I 've only selected the ethernet input for it and can confirm that is visible in my home network Edit : Actually i found these relevant entries in the logs : 2019-06-09 01:52:32.543 Info HttpServer: HTTP SUBSCRIBE http://192.168.1.13:8096/dlna/effa8ceac669409d9c10e8978ab295c0/contentdirectory/events. UserAgent: 2019-06-09 01:52:32.543 Info HttpServer: HTTP Response 200 to 192.168.1.2. Time: 0ms. http://192.168.1.13:8096/dlna/effa8ceac669409d9c10e8978ab295c0/contentdirectory/events 192.168.1.2 is my Hegel HD30 Edited June 9, 2019 by entity279
Luke 42238 Posted June 9, 2019 Posted June 9, 2019 Hi, hopefully you don't need a custom profile. Ideally it is just a matter of turning on the dlna device and then emby server will detect it. Then you can select it using the cast button in the upper right of most apps. Please let us know if this helps. Thanks.
entity279 0 Posted June 9, 2019 Author Posted June 9, 2019 Then you can select it using the cast button in the upper right of most apps. Never pressed that button up till now. Because the text hint on my browser is confusingly "Display on another screen" instead of somtehing like "cast to" Yes, seems to work effortlessly actually. So yay, thanks !
