groenator 13 Posted June 8, 2019 Posted June 8, 2019 (edited) So today I decided to move my EPG to iptv-epg.com. I add my provider, selected my channels, prepared everything for emby. After configuring LiveTV with the new feed for m3u and xml, now emby is not playing the feed on the web interface and on the android tv is playing the feed but terminates the feed after 60 seconds. Sometime even earlier. I thought maybe there is a problem with the feed so I tested the feed with VLC locally. Everything works well. Afterwards, I created another docker instance for xteve and configure the IPTV-EPG feeds there. Same thing with xteve, the feed either work on android TV for a bit or don't work at all. On web I get this error: Playback Error No compatible streams are currently available. Please try again later or contact your system administrator for details. Can someone please advise what m3u format does the feed need to have? Until moving to the new EPG everything worked well. Regards, Edited June 8, 2019 by groenator
groenator 13 Posted June 8, 2019 Author Posted June 8, 2019 This thread can be closed. I did few more tests and eventually everything works as normal. Not sure what just happen, I am glad everything works well now.
