politby 88 Posted May 22, 2014 Posted May 22, 2014 Server version 3.0.5254.26345. Trailer section is missing. Applies to all clients (MBT, MBC, Win 8) so must be a server issue. Sent from my Nexus 4 using Tapatalk
politby 88 Posted May 22, 2014 Author Posted May 22, 2014 Oops, maybe this should have been posted in the alpha area... Sent from my Nexus 4 using Tapatalk
CBers 7540 Posted May 22, 2014 Posted May 22, 2014 Trailers are now a Channel. Channels need to be added to other clients, but is available in Web client. I take it that you are running MBS dev.
politby 88 Posted May 22, 2014 Author Posted May 22, 2014 Thanks, got it. But how do I get channels visible in MBC/MBT? Or are they not implemented yet?
CBers 7540 Posted May 22, 2014 Posted May 22, 2014 As I said, Channels need adding to other clients, such as MBC/MBT.
politby 88 Posted May 22, 2014 Author Posted May 22, 2014 Okay, when you said "added" I thought you meant plugins. IOW, it has not been implemented yet.
CBers 7540 Posted May 22, 2014 Posted May 22, 2014 Channels are implemented in the latest dev server build, but haven't been added to clients other than the web client.
