egandt 3 Posted June 5, 2019 Posted June 5, 2019 Emby plugin for kodi on many movies (where I only I know I have only a single copy shows), that there are two sources, both random UUID's only the second one normally works. I want to know why this is happening and how to eliminate the second copy that is bogus (never plays). Attached is an example of this issue I'm facing, "Emby Theater" does not have the issue nor does the web only the Kodi plugin. I'm on: angelblue05 - 4.0.5 Thanks, ERIC
Solution Angelblue05 4132 Posted June 5, 2019 Solution Posted June 5, 2019 (edited) This is fixed in beta already. This is the source selection for trailers, it’s not supposed to show. A new stable is on the way soon. I just have a few things to work out first. You can either update to beta or simply wait for the fix Edited June 5, 2019 by Angelblue05
egandt 3 Posted June 5, 2019 Author Posted June 5, 2019 Great, any reason you'd suggest not using the beta at the moment? ERIC
Angelblue05 4132 Posted June 6, 2019 Posted June 6, 2019 Not really. Just it is possible there are bugs, but if there are, it is nothing major at this point.
