black0r 1 Posted June 7, 2019 Author Posted June 7, 2019 Sure I can try - yes I have 2 Databases in Emby overall. Movies and Serien behing that are a few Shares- I just Kids has access (under emby profile) Zugang -> Bibliothekenzugriff -> Movies -> Filme/Kids (not Filme/HD Filme and not Filme/SD Filme) also the "Kindersicherung" is set to FSK-6 and "Blockiere Inhalte mit keiner oder nicht erkannter Altersfreigabe:" Filme, Trailer & TV Serien" Maybe my settings and thinging of how it works is not correct ?
pünktchen 1411 Posted June 7, 2019 Posted June 7, 2019 (edited) Sure I can try - yes I have 2 Databases in Emby overall. Movies and Serien behing that are a few Shares- I just Kids has access (under emby profile) Zugang -> Bibliothekenzugriff -> Movies -> Filme/Kids (not Filme/HD Filme and not Filme/SD Filme)also the "Kindersicherung" is set to FSK-6 and "Blockiere Inhalte mit keiner oder nicht erkannter Altersfreigabe:" Filme, Trailer & TV Serien"Maybe my settings and thinging of how it works is not correct ? Die Vermutung von Angelblue05 ist, dass deine beiden Kodi Profile ein und dieselbe Kodi Datenbank nutzen. Deshalb sollst du in Kodi noch einmal ein neues Profil anlegen und Obacht geben, dass du dabei keine Einstellungen vom Kodi Master Profil übernimmst! Edited June 7, 2019 by pünktchen
Angelblue05 4132 Posted June 8, 2019 Posted June 8, 2019 (edited) @@black0r Keep me posted. This is just to test, because the normal behavior is that you have your library in one profile, and a separate library for another user in a different profile. One should not change the other at all. Creating a new kodi profile and sync your kids profile to it and then move to the master profile and see if it has changed. Hopefully, it hasn't. Edited June 8, 2019 by Angelblue05
