itschrisonline 2 Posted June 2, 2019 Posted June 2, 2019 Hi All, for some reason when I connect from external; through a reverse proxy it does not pick up that there is a key registered but when i use a computer connected to the lan it work Any help would be great, Cheers Chris
ebr 16338 Posted June 3, 2019 Posted June 3, 2019 Hi. It sounds like something is blocking validation of the key when using the reverse proxy. The client app needs access to validate as well. My Emby Key Says it is Invalid or Missing
itschrisonline 2 Posted June 3, 2019 Author Posted June 3, 2019 I thought that would be the case? How come I thought server side validation wold work. and the connection i was using for client side does not allow ip address. is that what the validation server is using? or is there any other way to validate
ebr 16338 Posted June 3, 2019 Posted June 3, 2019 Hi. The client needs to be able to access mb3admin.com. Can it do that?
itschrisonline 2 Posted June 5, 2019 Author Posted June 5, 2019 @@Luke Wont know until tomorrow will keep you updated. Issue is I would like to watch live TV and there is a block on it
itschrisonline 2 Posted June 6, 2019 Author Posted June 6, 2019 @@Luke still has a problem looks like mb3admin.com has been blocked
ebr 16338 Posted June 6, 2019 Posted June 6, 2019 @@Luke still has a problem looks like mb3admin.com has been blocked You will need to allow access to it for the validation to work. Thanks.
itschrisonline 2 Posted June 6, 2019 Author Posted June 6, 2019 Unable to do so as it is a corporate network any way to redirect back through the server so it can use its internet connection or a proxy?
ebr 16338 Posted June 7, 2019 Posted June 7, 2019 Sorry, not at this time (unless you can do so at a network level). I suspect this is exactly the kind of activity your corporate network is trying to avoid .
