cookemandan 1 Posted June 1, 2019 Posted June 1, 2019 Is anyone else having issues with the new version no longer keeping the time at the top when scrolling past the first page? Also I can no longer see a preview of the show on the guide since the update. I am not sure if that was an intended change or not. I have checked all of the settings and do not see any options of changing. So far the stability of this version is much better since using which is good. Thanks!
Luke 42241 Posted June 1, 2019 Posted June 1, 2019 Is anyone else having issues with the new version no longer keeping the time at the top when scrolling past the first page? Hi, what screen exactly is this happening on?
cookemandan 1 Posted June 1, 2019 Author Posted June 1, 2019 It is happening on the guide screen. My TV is a 2017 Samsung Q7F if that helps. Live TV->Guide
SamES 1084 Posted June 1, 2019 Posted June 1, 2019 (edited) Yes, you can reproduce this on tv.emby as well. Use the arrow keys to navigate down until the guide scrolls. The guide header row scrolls under the page header. If you arrow back up the page you actually lose focus under the page header. Edited June 1, 2019 by SamES
cookemandan 1 Posted June 19, 2019 Author Posted June 19, 2019 Is there a fix for this or will it be on the next release?
