ebr 16334 Posted June 11, 2014 Author Posted June 11, 2014 Sorry I must've missed that post. Thanks for the explanation. I was looking for a box to put a check in that would put them all in one channel We may have to do something like that eventually but, at this point, putting them under a "Channel" heading is going to cause more strife for users because they are going to ask "where did trailers and podcasts go?". As channels grow, we'll have to figure out a way to allow the user to organize them - or, maybe not. Maybe people won't all end up installing every single channel that is out there. We'll see, but I don't necessarily think lumping them all under one "Channels" entry makes sense.
ebr 16334 Posted June 11, 2014 Author Posted June 11, 2014 Personally I think I'd prefer the option of keeping them all together. I already have 10ish headings, adding channels to this would be unworkable Sent from my iPad using Tapatalk That may very well come but, for the early going, when most people just have the Podcasts and Trailers that have been in the main menu, I didn't want to hide those under an arbitrary option based on nothing but their technical implementation.
Spaceboy 2573 Posted June 11, 2014 Posted June 11, 2014 Personally I think I'd prefer the option of keeping them all together. I already have 10ish headings, adding channels to this would be unworkable Sent from my iPad using Tapatalk
Spaceboy 2573 Posted June 11, 2014 Posted June 11, 2014 Understood, I was just adding my 2p on the final position Sent from my iPad using Tapatalk
DGMayor 90 Posted June 11, 2014 Posted June 11, 2014 Sorry for the delay.. 179 fired right up for me too. The only time I was having that delay was after each new version, then it would level out. So having it fire right up after the install of 179 is a good sign! And yes, I have hide empty folders on. There is currently no way to get recent items out of the new channel architecture. That is being worked on in the server. Hopefully that will get straightened out soon. Without new trailers populating the RAL, I'd never watch a trailer! What can I say, I'm busy and need things handed to me. I need new content to smack me in the face lol. 1
techywarrior 689 Posted June 11, 2014 Posted June 11, 2014 That may very well come but, for the early going, when most people just have the Podcasts and Trailers that have been in the main menu, I didn't want to hide those under an arbitrary option based on nothing but their technical implementation. Ebr, If it's something that will most likely happen tho it may be better to do it now before even more people have channels, they get used to it and then they are moved. Although I imagine you would make it an option anyway.
DGMayor 90 Posted June 11, 2014 Posted June 11, 2014 Good day @@DGMayor, Buddy, you test Ebr suggestion: My best I'm not having the issue with 179. If it makes you feel better, when I switch to Chocolate, I'm also no longer having the issue 1
CBers 7554 Posted June 11, 2014 Posted June 11, 2014 (edited) That may very well come but, for the early going, when most people just have the Podcasts and Trailers that have been in the main menu, I didn't want to hide those under an arbitrary option based on nothing but their technical implementation.I currently have 2 Trailers on my EHS, one is the normal Trailers and the other is the Channels version. Edited June 11, 2014 by CBers
ebr 16334 Posted June 11, 2014 Author Posted June 11, 2014 I thought Luke had already taken the Normal one away but maybe he's waiting until I release the new version of MBC so current people on release don't lose them.
DGMayor 90 Posted June 11, 2014 Posted June 11, 2014 Grouping/removing channels works as intended. I'd almost be willing to leave them removed if I could keep Trailers the way it is (I know, I'm always difficult and don't want to let go of the "old way"). I'm not overly familiar with the rules of overscan...I will say when I make the numbers smaller (minus) the screen stretches, and when I make them bigger it gets smaller. I would think it would be reverse, but I dunno. Couldn't test the player part, have guests coming over in a few minutes. 1
Cheesegeezer 3106 Posted June 12, 2014 Posted June 12, 2014 Overscan is working fine Eric. I tested it out and overscan is working good for me.
ebr 16334 Posted June 12, 2014 Author Posted June 12, 2014 build 180: Fix chapter bindings in classic theme Add options for Channels Fix overscan problems in custom player Add overscan adjustments to config page Please test two major things for me: 1) That under/overscan is properly adhered to in the new custom player interface. Probably most obvious on a 360. 2) That adjusting these values in the advanced config panel works properly Thanks. If I can get confirmation that all that is okay, I'll promote this to Beta. 2
CashMoney 94 Posted June 12, 2014 Posted June 12, 2014 (edited) Seconded on overscan. I reset my TV's input from PC to SAT which removes the 1:1, and I was able to use your overscan options to adjust the picture to the correct size. Thanks for the Channel options as well. I and one of my customers very much dislike having the channels all mixed in with the other headings on the EHS, so being able to put them under the one heading is great! Stupid question time tho, how do I give this "channels" heading a folder image? I've looked through everything under user/Appdata/Roaming/MediaBrowser-Server/ImagesByName including the channels folder (added a folder.png, doesn't show in MBC's EHS under Chocolate) and can't find the proper location to put one. I'm guessing because it doesn't have a default I need to create a location for it? If so, what location is that? Edit - Found it: ImagesByName/General/Channels (I created the Channels folder and put my folder.png image in there) Edited June 12, 2014 by CashMoney
Abobader 3485 Posted June 13, 2014 Posted June 13, 2014 Good day Ebr, Is it possible to add "collections" same as the server web client at the EHS? My best
DGMayor 90 Posted June 13, 2014 Posted June 13, 2014 Good day Ebr, Is it possible to add "collections" same as the server web client at the EHS? My best It's been an option for a while. Did you turn it off and forget it?
Abobader 3485 Posted June 13, 2014 Posted June 13, 2014 It's been an option for a while. Did you turn it off and forget it? Good day buddy, I am not talking regarding this: But this: My best
Abobader 3485 Posted June 13, 2014 Posted June 13, 2014 Good day Ebr, 1 - From build 179 to latest one, mbc when enter any library, is too slow, and browsing the titles is somehow sluggish in mouse / keyboard movement, too lagged. Here the mbc logs with all that oprtional: http://paste2.org/WzwBnxWE http://paste2.org/KFZ9A2J8 2 - This option seem not working here: Enable or disable, same issue, and I restart mbc every time I change the option. My best
ebr 16334 Posted June 13, 2014 Author Posted June 13, 2014 Abo, there is a "Collections" item on the EHS - if it is enabled at the server for the current user. Also, I just checked and my collapse functionality is working as well. Can anyone else confirm these issues Abo is having?
Abobader 3485 Posted June 13, 2014 Posted June 13, 2014 Good day Ebr, Abo, there is a "Collections" item on the EHS - if it is enabled at the server for the current user. Sorry, where that option at the mb server to enable that? Also, I just checked and my collapse functionality is working as well. Can anyone else confirm these issues Abo is having? Maybe I misunderstand the function, care to explain it to me? Thanks in advanced. My best
DGMayor 90 Posted June 13, 2014 Posted June 13, 2014 (edited) Sorry Abo, I swear I thought there was an option in that first column for it along with the favorites and music genre. I've had a Collections on my EHS for months now..thought that was where I enabled it! On the server under Users, your user, Library Tab, I have "Collections" in the list and it's checkmarked. It is not a media folder that I created under the main Library section, so this must be what EBR is referring to. Edited June 13, 2014 by DGMayor
ebr 16334 Posted June 13, 2014 Author Posted June 13, 2014 DG is correct. The option is in the library access on the server - not MBC.
Abobader 3485 Posted June 13, 2014 Posted June 13, 2014 Good day, I know about all that guys: If you referring to the plugin, I do not use it, if you referring to the a library folder called "collections" I do not use that as well, so ? My best
Abobader 3485 Posted June 13, 2014 Posted June 13, 2014 And my request still stand correct my friends
Xzener 729 Posted June 16, 2014 Posted June 16, 2014 With most recent build, the full screen video backdrop issue has been fixed. Awesome work Ebr, keep it up. 1
