Abobader 3485 Posted June 5, 2014 Posted June 5, 2014 What theme were you using? Not using it buddy, just testing, it was Square theme, back to Chocolate theme now. One issue, as I understand it, the Trailers been "temp" as a folder till other clients understand or support "Channels", but MBC / CoverArt do not seem they doing well with channels covers as it now, any plan to support Channels for covers with future build of MBC/CoverArt. Channels: Temp Trailers Folder from mb3 server: My best
AdrianW 1058 Posted June 5, 2014 Posted June 5, 2014 (edited) On Square you need to select "Apps & Settings" on the top menu, and then choose the "Configuration" square - to get to the config screen. Edited June 5, 2014 by AdrianW 1
techywarrior 689 Posted June 5, 2014 Posted June 5, 2014 (edited) Not using it buddy, just testing, it was Square theme, back to Chocolate theme now. If I remember correctly, on the EHS you can scroll to the left in the top nav (1 or 2 screens) to Apps and there should be a config block(button). I think it was the spanner/wrench icon. EDIT: Damn you Adrian, posting just as I started typing the answer Edited June 5, 2014 by techywarrior 2
Abobader 3485 Posted June 5, 2014 Posted June 5, 2014 On Square you need to select "Apps & Settings" on the top menu, and then choose the "Configuration" square - to get to the config screen. If I remember correctly, on the EHS you can scroll to the left in the top nav (1 or 2 screens) to Apps and there should be a config block(button). I think it was the spanner/wrench icon. EDIT: Damn you Adrian, posting just as I started typing the answer Many thanks my friends, but now I just remove it, was testing it for short time. Well done both!
ebr 16334 Posted June 5, 2014 Author Posted June 5, 2014 Yeah, Abo - I haven't had a chance to look at CoverArt with respect to channels yet. 1
genro 4 Posted June 5, 2014 Posted June 5, 2014 Hi Ebr, any chance you can take a look at this (slight) issue when using the new player with Mediacontrol? To be honest I'm not even sure what the answer is, as I know you mentioned you prefer that the player pop up when first starting a movie. I don't know if there is a way to have it pop up but not take precedent/focus? You can set Mediacontrol to auto-detect multiple sub/audio tracks and if so to pop up a context menu when a file is first played that let's you select the ones you want. When I start a movie, It still pops up the context menu but I think it must lose focus to the player since that automatically appears as well when a file is first played. Meaning if I press enter to try to get into the sub selection menu, the new player receives that command instead of the Mediacontrol context menu pop-up. I can work around it but waiting and opening up the context menu manually (it's configurable within Mediacontrol, but I have it mapped to the "Green" button) and I am then able to navigate and select tracks as normal. Again not a major issue but I'm assuming its a focus/precedence issue when a video is first played.
snazy2000 344 Posted June 5, 2014 Posted June 5, 2014 The Revision3 plug-in was causing the error I saw. However, that is probably not what caused you to seem to hang. I'll bet $1 that you have "Hide Empty Folders" checked... @@snazy2000 here is the Revision3 error: 2014-06-05 22:31:48.3158 Error - DtoUtils: ServiceBase<TRequest>::Service Exception Object reference not set to an instance of an object. System.NullReferenceException at MediaBrowser.Plugins.Revision3.Revision3Channel.<GetEpisodes>b__12(Episode i) at System.Linq.Enumerable.WhereSelectListIterator`2.MoveNext() at System.Collections.Generic.List`1..ctor(IEnumerable`1 collection) at System.Linq.Enumerable.ToList[TSource](IEnumerable`1 source) at MediaBrowser.Plugins.Revision3.Revision3Channel.<GetEpisodes>d__14.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Plugins.Revision3.Revision3Channel.<GetChannelItems>d__2.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at MediaBrowser.Server.Implementations.Channels.ChannelManager.<GetChannelItems>d__7f.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task) at MediaBrowser.Server.Implementations.Channels.ChannelManager.<GetChannelItems>d__6f.MoveNext() 2014-06-05 22:31:48.3158 Error - HttpServer: Error processing request for /mediabrowser//Channels/8be71b1d-d5e8-56a0-2c89-a7c31f4da67d/Items?userid=350b3ec5-da2e-8526-7bcb-dd50295e5aaf&folderid=e25558df-f67e-6a1c-1349-80740951fe2e&format=Json Object reference not set to an instance of an object. ServiceStack.HttpError No Stack Trace Available Can you tell me what channel and video you clicked on to get this error.
Xzener 729 Posted June 5, 2014 Posted June 5, 2014 Ebr, liking the player overlay. Question... Why are video backdrops playing full screen when entering the details pages??
Xzener 729 Posted June 5, 2014 Posted June 5, 2014 Yeah, Abo - I haven't had a chance to look at CoverArt with respect to channels yet. I actually kind of like the look... The way they overlap each other. Could be a new view, "Posterlay"...tm.
snazy2000 344 Posted June 5, 2014 Posted June 5, 2014 Not sure why as it works fine on web client. Is anyone else having this issue?
ebr 16334 Posted June 5, 2014 Author Posted June 5, 2014 He didn't click on any. It was recursive-loading them all...
ebr 16334 Posted June 6, 2014 Author Posted June 6, 2014 Adrian - 172 should allow you to turn Hide Empty Folders back on with channels and blank out the RAL for them.
Nathanio 35 Posted June 6, 2014 Posted June 6, 2014 <p> 171 Available: Try to prevent screensaver and sleep with new player interface Fix crash playing local trailer with external player Support Channels Fix problems with playing entire folders Hi ebr. Tried .171 this evening and it looks like its solved my weird screensaver issue. Many thanks Nathan
Yogi 367 Posted June 6, 2014 Posted June 6, 2014 ebr installed the latest and love the channel implentation,all channels populate except for the Twit channel.The channel is there but nothing is populating inside the channel.Shows 0/0. All looks fine on the server side with everything showing.
Redshirt 1487 Posted June 6, 2014 Posted June 6, 2014 Is that channel populating for you on the web client?
bloodtaker 71 Posted June 6, 2014 Posted June 6, 2014 (edited) I am running into an issue in WMC. If I select play all /Play random it defaults to the first movie in the list on the display portions. It only does this on the random option not the unwatched or play all regular Also I can temp fix this by turning off the Playback / Use custom player interface. As when I watch movies I tend to put it on random and let it choose for me most of the time. Edited June 6, 2014 by bloodtaker
ebr 16334 Posted June 6, 2014 Author Posted June 6, 2014 If I select play all /Play random it defaults to the first movie in the list on the display portions. It only does this on the random option not the unwatched or play all regular Sorry, I don't quite follow what the issue is...
ebr 16334 Posted June 6, 2014 Author Posted June 6, 2014 ebr installed the latest and love the channel implentation,all channels populate except for the Twit channel.The channel is there but nothing is populating inside the channel.Shows 0/0. All looks fine on the server side with everything showing. Uhhh...perhaps a MBC log...?
ebr 16334 Posted June 6, 2014 Author Posted June 6, 2014 Ebr, liking the player overlay. Question... Why are video backdrops playing full screen when entering the details pages?? Reported a couple of times in this thread and others. I have pinged and PM'd Radeon and Cheesegeezer but they haven't responded yet.
snazy2000 344 Posted June 6, 2014 Posted June 6, 2014 I have just tested the Rev3 channel in MBC and all works great! Cant wait for the the other clients to get on board and implement channels! Great work @@ebr
Redshirt 1487 Posted June 6, 2014 Posted June 6, 2014 Sorry, I don't quite follow what the issue is... I saw that happen last night as well when I was testing your fixes. Say for example you play random on the folder that contains all your "Alien" movies. Random works like it should, it starts playing Prometheus, but the poster image and metadata shown are from the first movie in the folder - Alien (1979)
ebr 16334 Posted June 6, 2014 Author Posted June 6, 2014 Ah, thanks for the clarification, Red. When it moves on to the next one, does it stay with the information for the first one?
Yogi 367 Posted June 6, 2014 Posted June 6, 2014 Uhhh...perhaps a MBC log...? Sorry log attached MBClassic-7620147a6cbbcfc6b34bfeb51f561756c90377.log
