dovedescent7 3 Posted May 30, 2019 Posted May 30, 2019 @@ebr I've had emby premiere now for 6 months running on Xpenology. Specs are latest dsm, haswell xeon e3-1225 v3 16gb ddr3 supermicro x10sll-f Hdhomerun feeds ota tv and using The Players Klub for IPTV so i've got 2 tv souces for live tv. 99% of the time we watch Emby on Shield TV latest FW Using Emby Android TV App. Problem: OTA channels are loading much slower than they used to, recordings are intermittent(whether they record or not) and it just seems a bit sluggish. I also notice when watching ota TV that during a show, the sound will cut out for 5 seconds quite often which is really annoying. Things I've tried: Getting better OTA signal to the HDHomerun by getting great new antenna, and having it professionally mounted with stronger signal now. Should i try using the emby app for my LG Oled or try just sideload the Android Emby app to Shield(vs android tv app) ? Or should i get better hardware for my Xpenology, something recent with DDR4 and Latest Intel? Or is there a cache i should clean somewhere?
Luke 42246 Posted June 5, 2019 Posted June 5, 2019 Hi, @@ebr can help with the TV app but I would not necessarily suggest side loading the mobile app as the layout is currently not optimized for 10ft TV usage.
ebr 16338 Posted June 5, 2019 Posted June 5, 2019 Hi. I don't think any of your issues are necessarily app-related. How does the tuning speed compare to Chrome, for instance? As for the sound drop-outs, is this with bitstreamed DD? Any interruption in the stream will cause most audio processors to mute the stream for a few seconds until it comes back.
