Issues in Linux setup
eversmannx
Okay, it is actually "Movies" with a capital M.
not sure if you mistyped /nas instead of /nfs, i tried both anyways..
eversmannx@ThinkPad-T410:~$ sudo mount -t nfs -o rw,soft,intr //192.168.0.22:/nas/Movies /nas/movies
mount.nfs: Failed to resolve server //192.168.0.22: Name or service not known
eversmannx@ThinkPad-T410:~$ sudo mount -t nfs -o rw,soft,intr //192.168.0.22:/nfs/Movies /nas/movies
sargenthp
Sorry my bad... It is nfs that it is exporting.
And NFS doesn't use // in front of the server name. [emoji1751]
sudo mount -t nfs -o rw,soft,intr 192.168.0.22:/nfs/Movies /nas/movies
Sent from my PH-1 using Tapatalk
eversmannx
That works! Many Thanks!
eversmannx@ThinkPad-T410:~$ sudo mount -t nfs -o rw,soft,intr 192.168.0.22:/nfs/Movies /nas/movies
[sudo] password for eversmannx:
eversmannx@ThinkPad-T410:~$ cd /nas/movies/
eversmannx@ThinkPad-T410:/nas/movies$ ls
 _MOVIES  'Network Trash Folder'  'Temporary Items'
I will go back and follow your instructions for autofs later.
the nfs mount above did ask for the password - as i have same userid/password for linux account and nas - i wasn't sure which it picked up. But i did create a user called "emby" (with a password) for the nas, and hoping to use that for the autofs process.
eversmannx
Eveyrthings works perfectly now! @@sargenthp - you're a legend! Thank you so much for all your help.
autofs loads the shares as below when i rebooted the computer, and can delete files from Kodi interface now.
eversmannx@ThinkPad-T410:~$ df
192.168.0.22:/nfs/Movies   1941348672 1718503168 222845504  89% /nas/movies
192.168.0.22:/nfs/TV_SHOWS 1941348672 1718503168 222845504  89% /nas/tv
  • Like 1
sargenthp
Sweet!!! Enjoy! [emoji3]
