TylerV76 84 Posted May 29, 2019 Posted May 29, 2019 Emby guide not populating on a new install. Logs attached. Thanks Log.txt
Luke 42219 Posted May 29, 2019 Posted May 29, 2019 Hi, did you run the refresh guide scheduled task? Did you check the mapping tool to ensure that tuner channels are mapped to guide channels?
TylerV76 84 Posted May 29, 2019 Author Posted May 29, 2019 Hi, did you run the refresh guide scheduled task? Did you check the mapping tool to ensure that tuner channels are mapped to guide channels? I did but upon inspecting the log I noticed a timeout error. Did some digging and found out the power supply just died on my HDHomerun Prime causing a connection error when mapping channels. Gotta order a new one.
