Xetec 4 Posted May 29, 2019 Posted May 29, 2019 Tune In failed to load radio stations after login in. I rebooted the server a serval times.
Luke 42255 Posted May 29, 2019 Posted May 29, 2019 Hi there, please attach the emby server log. Thanks.
Xetec 4 Posted May 30, 2019 Author Posted May 30, 2019 Here the server log. I hope you can make anything out of it. log.txt
Luke 42255 Posted May 30, 2019 Posted May 30, 2019 Hi, I don't see any playback activity here. Did you try to play tunein during the time of this log file? Thanks.
Xetec 4 Posted May 30, 2019 Author Posted May 30, 2019 (edited) There no station to play when I was opening this topic. So with not loading stations is there no station to choise from, but I was logged in, Edited May 30, 2019 by Xetec
Luke 42255 Posted May 31, 2019 Posted May 31, 2019 What do you mean by no station? Where did you look?
jachin99 88 Posted May 31, 2019 Posted May 31, 2019 TuneIn nests stations in different categories similar to a folder structure. You have to select something like local, genre etc and then select from subcategories like am, fm, internet. At some point deeper into this kind of folder structure you arrive at a screen that should have radio stations but the stations themselves aren't there. Maybe that is what the OP meant.
Xetec 4 Posted June 1, 2019 Author Posted June 1, 2019 (edited) THere no stations simple as that. Does not load any catagory. And sometimes it does and than only on the music-blues genre are channels. Edited June 1, 2019 by Xetec
Luke 42255 Posted June 1, 2019 Posted June 1, 2019 THere no stations simple as that. Does not load any catagory. And sometimes it does and than only on the music-blues genre are channels. @@Xetec where are you looking for stations?
Xetec 4 Posted June 1, 2019 Author Posted June 1, 2019 In the section music-genres, only local stations are available under local section. Under de music genres sections is only blues available.
Luke 42255 Posted June 1, 2019 Posted June 1, 2019 This is what i see when i click on TuneIn. Is this what you see?
Xetec 4 Posted June 1, 2019 Author Posted June 1, 2019 yes but when selecting music most genres stay empty. No station list.
BillOatman 597 Posted July 17, 2019 Posted July 17, 2019 There is some more info here. https://emby.media/community/index.php?/topic/65368-tunein/?p=760088
