madvillain 0 Posted May 28, 2019 Posted May 28, 2019 Bonjour à tous, Lorsque j'ajoute une médiathèque avec un Type de contenu "TV" ( je précise que j'utilise un NAS en partage de type \\192.168.x.x\SERIES) cela fonctionne dans la grande majorité des cas. Sauf pour certaines séries pour une raison que j'ignore totalement. Exemple : Taboo ou encore il y a quelques minutes la série Happy!Après avoir ajouter mon contenu comme à mon habitude je reviens sur mon Dashboard en laissant le temps à Emby de bien synchroniser les métadonnées et lorsque je viens cliquer sur le contenu de mon dossier ce dernier est vide une idée du pourquoi du comment ? Merci d'avance
Luke 42239 Posted May 28, 2019 Posted May 28, 2019 Hi there, can you please go over an example? What is the folder structure? What does it look like in Emby? Thanks !
madvillain 0 Posted May 29, 2019 Author Posted May 29, 2019 Of course,here is two examples. One working fine and the other don't. The result on "Chernobyl" folder the content still empty Both folder are using .avi extension and some others using .mkv without any problems. Thx for your feedback
Luke 42239 Posted June 1, 2019 Posted June 1, 2019 Hi, please try creating the library based on the \Series folder rather than \Series\AnimalKindgom. Please let us know if this helps. Thanks.
madvillain 0 Posted June 4, 2019 Author Posted June 4, 2019 It seems to work, but that have no sens for me
madvillain 0 Posted June 17, 2019 Author Posted June 17, 2019 (edited) What's the differents between \\192.168.x.x\SERIES and \\192.168.x.x\SERIES\serie_name ? Edited June 17, 2019 by madvillain
Luke 42239 Posted June 17, 2019 Posted June 17, 2019 This is the folder containing all series: \\ 192.168.xx \ SERIES This is the folder containing one specific series: \\ 192.168.xx \ SERIES\seriesname The library should be based on the top folder containing all series. Does this answer your question?
