Transcoding subtitles encoding issue
Hey, I would like to know if there is a way to prevent the server to add -sub_charenc windows-1252 when converting the subtitles to .ass in order to trascode?
The issue is that all my external downloaded subtitles are in UTF-8 and with that flag some characters are displayed incorrectly.
Example:
The character ♪ is displayed as â™ª
The character á is displayed as Ã¡
and so on.. With the default autodetect everything works fine. (I tested running the command manually without the flag and overwriting the .ass in the cache folder).
Thanks
what language are the subs in?
Eng, spa.
Sent from my Nexus 5 using Tapatalk
  • Like 1
  • 1 month later...
Eng, spa.
Hi, do you find a workaround for this issue? Thanks!
  • 1 month later...
