dbowles1975 25 Posted May 25, 2019 Posted May 25, 2019 (edited) I'm prepared to send logs when I get home but I just wanted to start this topic while it was on my mind... I was recently playing a file with DTS audio on my Fire Stick and I started having freezing issues. Of course it was transcoding the audio but it also told me that the audio bitrate had exceeded the limit. The video would freeze every 15-20 seconds for roughly 2-3 seconds. I switched to another file... this one with Dolby Digital. This one did not transcode but it still said the audio bitrate was being exxceeded. It was running at 640 Kbps at the time. I also noticed that the "stats for nerds" info indicated the file was still being transcoded although the dashboard said that it was not. It was also strange that the transcoding percentage continued to climb beyond 100%. Emby Server is running on a very capable Windows PC and at the time this was happening I checked resources and everything looked fine. The Fire Stick is connected wirelessly but within 15' of an AP and all network tests show a rock solid and extremely fast connection. I also tried a wired connection and noticed the same results. Any ideas? Edit: I was able to solve the issue by uninstalling Emby. Edited June 9, 2019 by dbowles1975
kikinjo 294 Posted May 25, 2019 Posted May 25, 2019 I never understanded this "bitrate over the limit" to be honest, i have a android client on 200 mbit fiber connection and he also gets trans-coding most of the times, even he choose 100mbit in max bit-rate settings in android app on firestick 4k. The funny thing is that movie bitrate is like 8-9 Mbit (altogether video and audio). We tried internal access external access, does not matter it just spills bit rate exceeded and transcode. It would be nice that devs make a detailed wiki article about this and explain it...
ebr 16338 Posted May 25, 2019 Posted May 25, 2019 Hi. The Fires don't support DTS at all and only support DD up to 384kb/s (we may need to check some of the newer models to see if they've relaxed this restriction).
dbowles1975 25 Posted May 25, 2019 Author Posted May 25, 2019 Hi. The Fires don't support DTS at all and only support DD up to 384kb/s (we may need to check some of the newer models to see if they've relaxed this restriction). I was aware they didn't support DTS but was unaware of the bitrate restriction. Still, should video be freezing when only the audio is being transcoded? That seems odd to me.
ebr 16338 Posted May 25, 2019 Posted May 25, 2019 Still, should video be freezing when only the audio is being transcoded? That seems odd to me. Without looking at exactly what was happening at the time it is impossible to know. Update the topic when you have the logs. Thanks.
Luke 42246 Posted May 25, 2019 Posted May 25, 2019 Hi, yes, can we please look at an example? thanks !
dbowles1975 25 Posted May 25, 2019 Author Posted May 25, 2019 @@Luke @@ebr Log file attached. This played fine for a few minutes then froze for a few seconds. Shortly after I paused the episode and pulled the log.
dbowles1975 25 Posted May 26, 2019 Author Posted May 26, 2019 (edited) Hi. There is no attachment... I chose the file but forgot to attach it. My bad. It's attached now. Log.txt Edited May 26, 2019 by dbowles1975
ebr 16338 Posted May 27, 2019 Posted May 27, 2019 Interesting, it looks like ffmpeg crashes or something. If you turn off the subtitles, does it still do it? @@softworkz
dbowles1975 25 Posted May 27, 2019 Author Posted May 27, 2019 (edited) Interesting, it looks like ffmpeg crashes or something. If you turn off the subtitles, does it still do it? @@softworkz It doesn't seem to but it's so intermittent it's hard to know for sure. I did notice that playing the exact same file on the exact same device just now it was only transcoding because of unsupported audio and not because the audio was exceeding the bitrate limit. Bitrate was 1.54Mbps. Edited May 27, 2019 by dbowles1975
neik 874 Posted May 27, 2019 Posted May 27, 2019 Hi. The Fires don't support DTS at all and only support DD up to 384kb/s (we may need to check some of the newer models to see if they've relaxed this restriction). Amazon does offer EAC3 sound for some series, do they also only have 384kb/s or is it simply limited on the FTVS? Where did you find that information? I looked at their developer page and couldn't find anything.
ebr 16338 Posted May 28, 2019 Posted May 28, 2019 Amazon does offer EAC3 sound for some series, do they also only have 384kb/s or is it simply limited on the FTVS? Where did you find that information? I looked at their developer page and couldn't find anything. I can't remember if they ever actually documented it but I think it was on their specs page at one point but experience showed us it wasn't supported (as of about a year ago anyway).
neik 874 Posted May 28, 2019 Posted May 28, 2019 I can't remember if they ever actually documented it but I think it was on their specs page at one point but experience showed us it wasn't supported (as of about a year ago anyway). I am not 100% sure but I'm quite sure that my FTVS Gen. 2 does direct play AC3 640kb/s without downmixing if I force it to, by disabling remux/transcode in the user settings. I will give it a try once I'm home and feed back.
neik 874 Posted May 28, 2019 Posted May 28, 2019 I am not 100% sure but I'm quite sure that my FTVS Gen. 2 does direct play AC3 640kb/s without downmixing if I force it to, by disabling remux/transcode in the user settings. I will give it a try once I'm home and feed back. @@ebr, it is exactly like I was thinking. Removing the user permissions the FTVS direct plays the file and AC3 is passed through. With the file direct playing if forced to, I am wondering why it does remux at all?! Shall I provide any logs?
softworkz 5133 Posted May 29, 2019 Posted May 29, 2019 Interesting, it looks like ffmpeg crashes or something. If you turn off the subtitles, does it still do it? @@softworkz I don't think ffmpeg has crashed in this case as the user said he has paused (not stopped) playback while gathering the log. @@Luke - It hasn't created a single vtt segment. We should be able to disable vtt subtitles to verify if the problem is caused by vtt subs.
ebr 16338 Posted May 29, 2019 Posted May 29, 2019 @@ebr, it is exactly like I was thinking. Removing the user permissions the FTVS direct plays the file and AC3 is passed through. With the file direct playing if forced to, I am wondering why it does remux at all?! Shall I provide any logs? In our experience, they will play but usually with problems.
Luke 42246 Posted May 31, 2019 Posted May 31, 2019 Has this answered your questions about why the audio is converting?
dbowles1975 25 Posted May 31, 2019 Author Posted May 31, 2019 Has this answered your questions about why the audio is converting? I have no idea who you're asking. Are you asking me or the guy who hijacked the thread?
dbowles1975 25 Posted June 1, 2019 Author Posted June 1, 2019 @@ebr's responses. His responses were helpful but I don't feel they really resolved the issue. It only seems to fail when subtitles are enabled.Does that help narrow it down at all?
ebr 16338 Posted June 1, 2019 Posted June 1, 2019 Right, there were a couple of items raised and the "why is the audio transcoding" questions are answered but the initial problem in this thread of the stream stopping with subs enabled is still an open issue.
