bluemonkey07 590 Posted May 20, 2014 Posted May 20, 2014 (edited) Similar to what garbear is working on for the next version of xbmc. libretro is an api for multiple emulator cores. This would allow a number of games systems to be playable from within MBT Edited May 20, 2014 by Vidman
bluemonkey07 590 Posted May 21, 2014 Author Posted May 21, 2014 Does it? I thought you still had to use external emulator programmes
Ghostm 75 Posted May 21, 2014 Posted May 21, 2014 Yea you still have to use external. It is on the roadmap if you check the first post by luke in the official mbt thread at the top of the forum, but i dont know if its being worked on actively yet. From what I heard the focus is live tv, then music, then perhaps libretro? Luke would know better then me.
bluemonkey07 590 Posted May 21, 2014 Author Posted May 21, 2014 Ah so it is.... I tried searching and nothing came up so I just wanted to put it out there;)
