Luke 42221 Posted May 27, 2019 Posted May 27, 2019 So for me it ended up bgeing a firewall issue. If I turn off Windows Firewall I am able to connect remote. So I will troubleshoot the firewall tomorrow. Hope that helps anyone else having trouble. Thanks for the feedback !
Michael.D.Pine 4 Posted May 31, 2019 Posted May 31, 2019 Firewall didn't fix it for me, the only way I could get it working was to add the server manually again and use the external IP Address, maybe I missed the instructions that this was required in which case my bad, I assumed by having an Emby Connect account linked to a user on my Emby Server that it would take care of it somehow. Anyway working now with adding the server using the IP address.
Luke 42221 Posted May 31, 2019 Posted May 31, 2019 Firewall didn't fix it for me, the only way I could get it working was to add the server manually again and use the external IP Address, maybe I missed the instructions that this was required in which case my bad, I assumed by having an Emby Connect account linked to a user on my Emby Server that it would take care of it somehow. Anyway working now with adding the server using the IP address. Does your emby server dashboard display the correct remote address?
Michael.D.Pine 4 Posted May 31, 2019 Posted May 31, 2019 Well I assume so, that is where I got it from and it works
