HansWurst 16 Posted June 28, 2021 Posted June 28, 2021 Yes I can. Even if there are two threads on the same topic.
Leryra 0 Posted May 16, 2022 Posted May 16, 2022 I just had the same issue on the ios app, but it's definitely transferring stuff in the background: my WiFi router shows it got 25gb of data, but not a single episode available in the iPad app... 25gb of transfer should definitely have successfully transferred at least one episode at the 8mbps quality... It does show the "converting" status correctly, but somehow struggles with the transfer afterwards. Saying "Transferring 0%" or "Ready to transfer". Maybe make it so that instead of transferring a bit of everything it focuses on a single file at a time?
Luke 42243 Posted June 7, 2022 Posted June 7, 2022 On 5/16/2022 at 7:26 AM, Leryra said: I just had the same issue on the ios app, but it's definitely transferring stuff in the background: my WiFi router shows it got 25gb of data, but not a single episode available in the iPad app... 25gb of transfer should definitely have successfully transferred at least one episode at the 8mbps quality... It does show the "converting" status correctly, but somehow struggles with the transfer afterwards. Saying "Transferring 0%" or "Ready to transfer". Maybe make it so that instead of transferring a bit of everything it focuses on a single file at a time? Hi, yes we are working on improving the in-app status display. Thanks.
