Thuzad 50 Posted May 22, 2019 Posted May 22, 2019 Hello, Is it possible to disable the lowest qualities to force a user to have a minimum bit rate of 1 mb/s? This would be to reduce the load on my server.
Luke 42221 Posted May 22, 2019 Posted May 22, 2019 Hi, no, but curious, how would this reduce the load?
Thuzad 50 Posted May 22, 2019 Author Posted May 22, 2019 Some of my users we define the minimum quality (144p) without valid reason I would have wanted to force them not to use low qualities.If I understood correctly if I transcode a file with a good quality to a very bad (144p) one it will use more resource?While if it transcodes from 720p to 2/3 mb / s transcoding will use less resource.Of course if it is in direct reading no problem at the CPU.I would like to do this because when there is a lot of simultaneous stream the server has trouble following.
Luke 42221 Posted May 22, 2019 Posted May 22, 2019 If I understood correctly if I transcode a file with a good quality to a very bad (144p) one it will use more resource?While if it transcodes from 720p to 2/3 mb / s transcoding will use less resource. No, that really should not be any different. Transcoding to lower resolution will in fact use less resources.
Thuzad 50 Posted May 22, 2019 Author Posted May 22, 2019 (edited) Another question why I do not have information about transcoding on the dashboard? Similar to that Edited May 22, 2019 by Floflobel
Thuzad 50 Posted May 22, 2019 Author Posted May 22, 2019 (edited) Testing in web app on chrome and firefox and iOS application Emby server version: 4.1.1.0 Edited May 22, 2019 by Floflobel
Thuzad 50 Posted May 28, 2019 Author Posted May 28, 2019 (edited) Hey, have you been able to analyze the problem? Edited May 28, 2019 by Floflobel
Luke 42221 Posted May 28, 2019 Posted May 28, 2019 Nothing obvious jumps out but I'm keeping an eye out for it. Thanks.
Thuzad 50 Posted May 28, 2019 Author Posted May 28, 2019 For information I sometimes have the details on the application with my iPhone and sometimes not.
Thuzad 50 Posted June 4, 2019 Author Posted June 4, 2019 I try to remove the plugin playback reporting and it doesn't works... I send log to PM
Thuzad 50 Posted June 4, 2019 Author Posted June 4, 2019 Another question why I do not have information about transcoding on the dashboard? Similar to that This still does not work it's the same display as on my screenshot by removing the PlaybackReporting plugin. I tested under chrome and Firefox
Luke 42221 Posted June 4, 2019 Posted June 4, 2019 Make sure to restart the server after removing it.
Thuzad 50 Posted June 5, 2019 Author Posted June 5, 2019 Email plugin doesn't exist on my Emby, hue control has been removed. The problem is already present.
