JERRY1 17 Posted May 21, 2019 Posted May 21, 2019 The start of each episode i need to select the audio i want. Shouldn't it remember the audio i selected to begin the series ?
Luke 42234 Posted May 21, 2019 Posted May 21, 2019 Hi, no, but have you configured your audio preferences for your emby user? That will give you what you're looking for
Solution JERRY1 17 Posted May 21, 2019 Author Solution Posted May 21, 2019 (edited) Ok found it i was not in the correct area. I unchecked it , now all is fine. Thanks Edited May 21, 2019 by JERRY1 1
