Gilgamesh_48 1243 Posted May 20, 2019 Posted May 20, 2019 I often browse my TV library using the web browser in order to find a series I would like to watch. I use "Next up" to watch TV series and I like to keep the 6-10 or so TV shows I am watching in "Next up" and I watch them in rotation. When I decide I would like to add a show to that rotation it would be good to just add it to "Next up" but I have not found a way to do that other than watching the first episode. Even watching the first 5 minutes of the first episode does not work correctly. That does cause the episode to appear for a time in "Next up" but if another episode from another show is watched the partially watched episode disappears from "Next up." Is there a way to accomplish what I want?
Luke 42219 Posted May 20, 2019 Posted May 20, 2019 Hi, no, there isn't, but you could try watching the previous episode as a way of doing that.
Gilgamesh_48 1243 Posted May 20, 2019 Author Posted May 20, 2019 Hi, no, there isn't, but you could try watching the previous episode as a way of doing that. The problem with that idea, which I know works, is the the first episode of a series has no "previous" episode. This is not really that important as I can watch that first episode from normal browsing. It would just make thinks easier for me and allow me to closer approach a "total Garfield" mode for watching TV. BTW: Can you implement a "Get me a beer" function and a "make popcorn" function for my TV watching.
