skank 85 Posted May 19, 2019 Posted May 19, 2019 I have movies LOTR Each 3 movies, contain 2 mkv files so the fellowship of the ring, has part 1 and 2 will kodi play part 2 after 1? cause when i start 1, it only lasts for 1:45min how do i make sure it plays the other one too?
Angelblue05 4132 Posted May 19, 2019 Posted May 19, 2019 Since you are using native playback, you can’t. But you can open the context menu > emby play on the first part. That will queue up both parts to play via add-on playback.
skank 85 Posted May 19, 2019 Author Posted May 19, 2019 (edited) i cant use addon playback i need native so it wont work can i "paste" the two mkv to eachtother? or any other options? Edited May 19, 2019 by skank
Angelblue05 4132 Posted May 19, 2019 Posted May 19, 2019 Use the context menu option. As I said, it will play using addon playback, even if you are using native playback.
sualfred 677 Posted May 19, 2019 Posted May 19, 2019 (edited) Just do it right and merge the parts to one mkv. -> https://mkvtoolnix.download/doc/mkvmerge.html -> https://mkvtoolnix.download/downloads.html It's done within a minute. Edited May 19, 2019 by sualfred 1
CharleyVarrick 284 Posted June 15, 2019 Posted June 15, 2019 (edited) can i "paste" the two mkv to eachtother? AVIdemux will merge 2 separate video files into 1, as long as the 2 original video files are of same resolution. Open part 1, then "append" part 2, then save. Make sure to select mkv as output format. If you need more info, just holler Edited June 15, 2019 by jlr19
