Anixd 9 Posted May 19, 2019 Posted May 19, 2019 I have setup a mixed content library, in the main folder I have different folders like year 2010, 2011, 2012 and so on. Further in side the year folder I have sub-folders festivals, school, trips etc. All have videos in it, I have put poster.jpg in each sub folder which shows up perfectly. But the problem is that the image I want to be backdrop / background never shows up, even if I put them into sub folder or in the year folder I have read and followed all the naming guidelines but could not figure it out, strangely if I do not make sub folders then background image starts to show
Luke 42221 Posted May 19, 2019 Posted May 19, 2019 @@Happy2Play may have some mixed content tips. Thanks.
Happy2Play 9806 Posted May 19, 2019 Posted May 19, 2019 @@Happy2Play may have some mixed content tips. Thanks. Do nested "folders" honor backdrops? Isn't it only the media item that is able to show backdrops?
Luke 42221 Posted May 19, 2019 Posted May 19, 2019 I'm having a hard time visualizing this folder structure. Can you show us an example? Thanks !
Happy2Play 9806 Posted May 19, 2019 Posted May 19, 2019 I'm having a hard time visualizing this folder structure. Can you show us an example? Thanks ! Say you have a nested folder for year, if you have background/fanart it will not be displayed when you enter year folder. I believe actual content applies. Library path .../misc /misc/2010 poster.jpg background.jpg /misc/2010/festivals /misc/2011 /misc/2011/trips
Anixd 9 Posted May 20, 2019 Author Posted May 20, 2019 Yes So background art do not appear in the sub folder structure The visualisation by happy2help is correct Even if I pit separate poster and background, only poster appears not the background. For example - misc is root folder /misc/2011 /misc/2011/trips Poster.jpg Background.jpg
Anixd 9 Posted May 21, 2019 Author Posted May 21, 2019 Videos and one image as backdrop.jpg and another image as poster.jpg
Luke 42221 Posted May 21, 2019 Posted May 21, 2019 Ok, this is something that can be reviewed in a future update. Thanks.
Anixd 9 Posted May 22, 2019 Author Posted May 22, 2019 Is there a way that the trips folder can be treated as seasons of a tv show ?
Luke 42221 Posted May 22, 2019 Posted May 22, 2019 Yes, but you'd have to re-organize so that it follows TV naming conventions.
Anixd 9 Posted May 22, 2019 Author Posted May 22, 2019 I was trying out your suggestion it's working but now trips, festivals etc had to be named as seasons which is weird to view. 2ndly, there are some audio files they are not showing as per tv show conventions, which were earlier showing, So how do I name them ?
Luke 42221 Posted May 22, 2019 Posted May 22, 2019 Unfortunately there isn't a perfect answer to this. TV libraries don't support audio. You may have to move those files out.
Anixd 9 Posted May 25, 2019 Author Posted May 25, 2019 There is no way that we can post seasons with different name or otherwise they appear as folders with no backdrop. As far as audio is concerned when the folder is renamed as seasons then audio does not show but when it remains 'trips' it shows and plays audio fine. A lot of trouble , can there be a update that would enable audio in seasons or in folders view show backdrop like tv shows
Happy2Play 9806 Posted May 25, 2019 Posted May 25, 2019 There is no way that we can post seasons with different name or otherwise they appear as folders with no backdrop. As far as audio is concerned when the folder is renamed as seasons then audio does not show but when it remains 'trips' it shows and plays audio fine. A lot of trouble , can there be a update that would enable audio in seasons or in folders view show backdrop like tv shows I will be additional work but the metadata title can be anything you like. Where the folder needs to be according to supported naming schemes.
Anixd 9 Posted May 26, 2019 Author Posted May 26, 2019 Can you please suggest how ? When I name the sub folder as season 1 - trips , it just shows season 1 and if I change season 1 to trips only then it does not that it as tv show due to which no background appears
Anixd 9 Posted May 26, 2019 Author Posted May 26, 2019 Is there a way that envy could show "season 1 - trips " complete instead of just season 1??
Anixd 9 Posted May 29, 2019 Author Posted May 29, 2019 @@Luke there is no option to increase playback speed to 2x in emby player for Android or ios. Will it be coming to app??
Luke 42221 Posted May 29, 2019 Posted May 29, 2019 Is there a way that envy could show "season 1 - trips " complete instead of just season 1?? Have you tried using the metadata editor to edit the name?
Anixd 9 Posted May 29, 2019 Author Posted May 29, 2019 I changed the folder name but nothing happened
Happy2Play 9806 Posted May 29, 2019 Posted May 29, 2019 (edited) Have you tried using the metadata editor to edit the name? I changed the folder name but nothing happened What do you mean? You can change the metadata to anything you like. We are not talking about the folder itself. Edited May 29, 2019 by Happy2Play
