x88dually 9 Posted May 23, 2019 Author Posted May 23, 2019 Roku cant log onto v3.5.3 to send you anything. That was 1 of the problems i started with the other day. I try to click on that server, it tells me invalid username or password. Please try again. Heres the thing, i dont have any usernames or passwords.There is only admin as user ? No matter who gets into emby, its just the server/username at the top, and all shows for everyone. Anyone can pick up a remote control, click on emby, and choose a server, then goto home screen.
x88dually 9 Posted May 23, 2019 Author Posted May 23, 2019 Primary is v4.1.1.0, initial scanning at 90.7 %. This will take weeks. Secondary is v3.5.3, and will stay that way until counters come back to v4.xxx. But still cant watch emby from a roku.
Luke 42219 Posted May 23, 2019 Posted May 23, 2019 I thought I saw you enabled the Thumbnail feature. If you disable that your scan should complete faster.
x88dually 9 Posted May 23, 2019 Author Posted May 23, 2019 (edited) yes, if i turn it off, then when does it make thumbnails, at next scan or just in the background ? once this crazy long scan is done, do you have any idea how long its gonna take me to make tv shows mimic each other on both servers ? probably 4 days. Each time a episode gets watched from either server, it has to be duplicated on other server so they match. i spend 2 hrs a night doin this crap, and we're only 4 people. Still cant watch roku with v3.5.3 Edited May 23, 2019 by x88dually
x88dually 9 Posted May 24, 2019 Author Posted May 24, 2019 (edited) a problem poppped up on tv show listing, stats and reports say v4.1.1.0 has 2123 shows, but v3.5.3. says 2033. a screenshot, tv shows "the affair, africa and afterlife are blank doubles, nothing in the folders but a folder showing. I'm sure theres close to a hundred more, i should only have 2033 shows. But scanning is at 92.0 % thumbnails off Edited May 24, 2019 by x88dually
Happy2Play 9806 Posted May 24, 2019 Posted May 24, 2019 a problem poppped up on tv show listing, stats and reports say v4.1.1.0 has 2123 shows, but v3.5.3. says 2033. a screenshot, tv shows "the affair, africa and afterlife are blank doubles, nothing in the folders but a folder showing. I'm sure theres close to a hundred more, i should only have 2033 shows. But scanning is at 92.0 % thumbnails off Screenshot_2019-05-23 Emby.png And what is the exact structure of those items? Do the paths for those items appear the same?
Happy2Play 9806 Posted May 24, 2019 Posted May 24, 2019 on the hard drives ? Sure. my guess is something in the folder structure, as 4.1 is not as forgiving as 3.5.
x88dually 9 Posted May 24, 2019 Author Posted May 24, 2019 (edited) root/media/tv/show name/season xx/episode just checked drives on both servers, exactly the same only show "the affair 2014" has a year in structure Edited May 24, 2019 by x88dually
x88dually 9 Posted May 24, 2019 Author Posted May 24, 2019 root/media/tv/show name/season xx/episode just checked drives on both servers, exactly the same only show "the affair 2014" has a year in structure
Happy2Play 9806 Posted May 24, 2019 Posted May 24, 2019 Does selecting edit metadata on the series show the same path (from the library)? Are they duplicated in the Metadata Manager with the same path?
x88dually 9 Posted May 24, 2019 Author Posted May 24, 2019 whewwww, refreshing metadata is clearing things up. Thx for your help
Happy2Play 9806 Posted May 24, 2019 Posted May 24, 2019 Just a guess but It could be a side effect of starting and stopping initial scans also.
