markand 9 Posted May 17, 2019 Posted May 17, 2019 I'm in the process of migrating from a Mac Pro server to a QNAP, following https://github.com/MediaBrowser/Wiki/wiki/Backup . I'm using the Backup method. It seems like the shows I had marked to record did not get migrated over. Is there any way to get them from one installation to the other?
Luke 42245 Posted May 18, 2019 Posted May 18, 2019 Hi, currently they do not, but it's something we plan to add to the backup plugin in the future. Do you have a large number of scheduled recordings?
markand 9 Posted May 18, 2019 Author Posted May 18, 2019 I had about a dozen shows. The problem is that some of them do not have any showings coming up so I couldn't add them. I was able to add 5 back. But, for example, I couldn't add Arrow because there are no showings, so I'll have to remember to try again.
Luke 42245 Posted May 21, 2019 Posted May 21, 2019 For now I think that would be the best approach. We'll look at getting this into the backup plugin. Thanks.
